Bosch nexxt 800 washer
The message is saying water level too high on my Bosch vision 800 series washer. The door wont open. I unplugged it/reset it. I also tried to drain/spin and it will not drain the water. How do I get the door open to drain water?
  • 20 Answers
SOURCE: Bosch Nexxt 800 series - washer doesn't always spin dry enough
First inspect the water pump then the pressure switch. Soap buildup can cause this too.
Posted on Feb 10, 2009
farr64
  • 121 Answers
SOURCE: bosch nexxt washer fabric softener not draining
is there a drain on the bottom left corner if so drain the contents its usually under a small panel
Posted on Sep 14, 2009
barkencoa
  • 3463 Answers
SOURCE: Bosch Nexxt 100 series front load washer
You first of all need to check the pump filter.
This should be located at the botom front right of washer.
Look for a drop down flap or cover, once located, unscrew filter anti-clockwise to remove and clean.
The pump itself is directly behind the filter housing, check there is nothing stuck in the housing.
This should solve the prob.
Please leave feedback for my solution.
Thankyou.
Posted on Jan 11, 2010
Testimonial: "I submitted a question and got a very quick response. The response was useful and enabled me to make the repair myself. Thank-you!"
barkencoa
  • 3463 Answers
SOURCE: bosch 100 series will not drain
You need to check and clean the pump filter if you have not already done so.
This is located at the bottom front right of washer.
Unscrew anti-clockwise to remove and clean.
Posted on Mar 15, 2010
SOURCE: Bosch Error Code 13 Washer won't drain
First, unplug your washer. After that find the little round plate below your drum opening on the exterior of the washer. It should have a small hole in it. Use something to gently push trough this hole and twist the cover off, Inside there you will find the drain access. Be careful, if there is water in your drum this will make a mess when you unscrew the drain access. Take the usual precautions and unscrew the drain access slowly until it is off. Remove any obstructions and replace access door and cover. Clean up any mess and plug back in your washer and try again. takes about thirty minutes to an hour depending on how much water is in the drum.
Posted on Sep 21, 2010
I have a Bosch 300 vision washer which wont turn on. The lights are on and there is no error code showing does anyone know what might be wrong?
lights are on, but won't turn on? I don't understand. if it simply won't start turning after filling, this could be the motor brushes. if it isn't starting at all, you may have an issue with the door mechanism.
Dec 08, 2014 | Bosch Vision 300 Series WFVC3300UC
Bosch washer door is locked
Remove the cover on the lower right corner, you will see a white plastic pull cord. Pull the cord and pull open the door. Don't force the door, you could damage it. If that doesn't re-set the door lock you will need to replace the lock.
Pl click if helped.
Mar 08, 2013 | Washing Machines
Can the dryer door be reversed to open the opposite way on the 800 series Bosch?
it is possible . I suggest that you talk to a service repair shop to get details of how to to it if it can be done.
Feb 06, 2013 | Bosch Nexxt 800 Dryer
Front load washer Bosch Vision 300/500/DLX will not drain getting a code of E27 can you help. Can't find the code # in the booklet that came with it.
A code E27 means a problem with the door lock. Try unpluging the machine for an hour and see if it resets the lock.
If not remove the cover on the lower right corner you will see a white plastic pull cord. Pull the cord and pull open the door. If that doesn't reset the door lock you will need to replace the lock.
Nov 22, 2012 | Bosch WFK 2401
E:27 error on bosch 500 series washer
turn the dial to the off position. Hold down both the delayed start and spin select buttons and turn dial to the left one click (cold position). you should then here the door unlatch. let go of the buttons. you will see some other codes p 01, p 02. turn dial to off. it should work fine after this. it worked for me. this should be in the manual.
May 15, 2012 | Bosch WFVC6450UC 500 Series Vision Front...
Bosch Vision 800 Series front loading washer. Flashing "water level is too high". We are not getting any water into machine at all. Is there a way to reset?
We had this same problem last night, although we had just purchased this washer 'new' (bought it at Sears, display model, and it's 9 months old but had not been used). We didn't even get the correct user's manual with it, but after running one cycle without laundry the message went away.
Aug 09, 2010 | Audiovox Bosch 718 World Cellular Phone
Can I get door to open with high water level
door locks automatic to prevent water spill .take hose out of pipe and drain into bowl
Dec 15, 2009 | Bosch Nexxt 300 Series WFMC2201UC
Washing Machines Logo
15 people viewed this question
Top Washing Machines Experts
