Question about GE Refrigerators
Door not dispensing ice
Makes ice, dispenses water. Does not dispense either crushed or cubed ice. Makes solenoid sound when button pushed but i don't think the auger is turning
  • 46 Answers
The auger switch in the door is bad or the auger motor is seized up/ stuck. The door switch is the problem the majority of the time. It's a simple repair. Just be careful with disassembling the plastic parts and use a flash light to find hidden screws in dark places.
Posted on Feb 08, 2014
4 Suggested Answers
fridgetech
  • 473 Answers
SOURCE: Ice dispenser only dispenses crushed ice
Pull out your ice bin. In the back of the bin you will see a rod protruding from one side. That rod goes into an opening in the rear of the freezer. There is a solenoid behind that opening that raises and lowers the arm on the ice bin giving you crushed or cubed ice. Check to see if that solenoid is froze up or if your rod got stuck under it. If all check ok then replace that solenoid.
Posted on Nov 06, 2007
You may not need to replace the solenoid.  If you hear the hum, and not a loud click and don't see then rod move, it may be frozen with ice.  Test it manually with your hand, it should be free  to move up and down.  If not, then it is frozen with ice.  Remove the ice dispenser and let it thaw and dry out.  You should then be able to move to rod and it will work fine, at least until it freezes again.  Anyone know how to prevent it from freezing up? Its a continual problem for me
Posted on Mar 28, 2009
SOURCE: Icemaker problem crushed only not cubes
Whenever the ice tray is removed, you need to reposition the cube/crush selector rod that is attached to the bottom of the ice tray. This rod swivels: down position for crushed, up position for cube. At the back of the freezer, there is an opening to which this rod inserts. It houses the solenoid for cube/crushed operation. For cube position, the horizontal plastic piece is slightly above the center of the opening. Slide out the tray until the rod is past the solenoid. Pry the solenoid down as far as it can go. It is spring loaded and will not break. (If it doesn't feel like it is spring loaded, stop here and call a repair tech.) Now swivel the rod on the tray up and slide back in making sure the end of the rod is ABOVE the solenoid. DONE!!! Now you have cube ice. Good Luck.
Posted on Sep 22, 2009
LG REFRIGERATOR DISPENSER NOT WORKING
x1 sonny ericcson widows mobile 6.1 version i want to change my language to english
Jan 05, 2014 | LG LSC26905TT Side by Side Refrigerator
Hi i have a double door samsung fridge and when i place dispensable ice on cube i still get crushed ice in addition is there any way to increase the speed at which water comes out the dispenser
There is likely a faulty solenoid which switches the ice dispenser between "crush" and "cube" mode.
The water pressure at the water dispenser is proportional to the supply line water pressure. Unless there is a restriction in the supply line or the dispenser line, the only way to increase the water flow is to increase the supply line water pressure -- not an easy proposition.
More info, let me know.
Charlie
Feb 12, 2011 | Samsung RS2630SH Side by Side Refrigerator
Ge gss fridge,ice dispenser problem.
You have a solenoid switch which switches the dispenser back and forth from crushed to cube. The crush position is without the solenoid energized. It could be stuck or not working or the parts connecting it could be disconnected or broken. You will have to observe to see if any parts are moving and if any noise is coming from the solenoid
Your solenoid is part 45 and the linkage to the crusher is 46. The crusher is 41 on this diagram and parts list. http://www.appliancepartspros.com/partsearch/model.aspx?model_id=5150332&diagram_id=1239793#d1239793
Feb 28, 2010 | Frigidaire FRS3R5EMB Side by Side...
Ice Maker Issues-only crushed ice works, cubed comes out crushed
There is a solinoid in the freezer section by the motor that turns the ice auger. Test it by selecting cubes and with the ice bucket out, open the door, hold the door switch so the lights turn out and push the dispenser button. It should make a loud snap and travel upward. If not then I would say you have a bad solinoid. If it does, then I would look at the bucket. the metal rod that runs along the side of the bucket opens a flap in the bucket that is supposed to let the full cubes drop. look for anything that might cause it to be hanging up.
Jan 27, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
Frigidaire Gallery Series Side by Side doesn't crush ice
hi there,
could be that the ice maker arm is getting stuck or may have some frost on it. can you supply the complete model # please?
Sep 25, 2008 | Frigidaire Gallery Series GLHS269ZDB 36"...
Apr 06, 2008 | GE (PSS26MSRSS) Side by Side Refrigerator
Ice maker not working
The icemakers won't make ice if the temperature is not below a certain set point. Varies between manufacturers. Try making the temp colder.
Feb 01, 2008 | Hotpoint HSS25GFP Side by Side...
Nov 05, 2007 | Frigidaire FRS26KF5C Side by Side...
Refrigerators Logo
Top Refrigerators Experts
Sal DeAngelo
Charles T Nevin
Charles T Nevin
Andrew Taylor
Andrew Taylor
