Question about Soyo FreeStyler HS11 Bluetooth Stereo Headset Wireless Headset
Parts replacement foam covers
    Renaissance:
    An user who is expert in 3 categories / brands.
  • 924 Answers
I doubt you will be able to find the original foam ear covers. Try taking your headphones to a Radio Shack or Best Buy and see if they have something that will fit.
Posted on May 11, 2014
Need replacement covers for the headphones.
Unless you post make and model number how can we know which may be compatible
Mar 13, 2017 | The Audio Players & Recorders
Where do I find replacement parts for my radian 80
In the USA, contact Diono at:
Diono LLC, 3104 142nd Ave. East, Suite 105, Sumner, WA 98390, 888-336-7909, www.diono.com
Jul 27, 2014 | Sunshine Kids Radian 80 Convertible Car...
How often should I turn/rotate my memory foam mattress?
Memory foam mattresses should not be flipped at all - they only have memory foam on one side.
Jul 25, 2012 | Furniture
Replacement foam for quinny buzz handlebar
Hello I am making handle bar, bumper bar and frame covers for the bugaboo and can probably help you with a cover.  Contact me at www.bbsprouts.com
Diane
Mar 08, 2010 | Quinny Buzz 3 Sulphur Jogger
Where cai I find the plastic foam (felizol) part
I would suggest that you contact Dorel (manufacturers of Maxi Cosi items) You can find their contact details at www.maxi-cosi.com
I hope this helps.
Sep 07, 2009 | Baby Gear
I need the black plastic cover with nylon mesh over it. My speakers are fine but they need the front covers!
You can usually get replacements from the manufacturer depending on the units age. If they are molded grills that are specific to that speaker only you can also try THE PARTS STORE online. You can type in the make and model of your stereo and possibly get parts there. If they are just square grills....Parts Express sells adjustable frame kits that may work or Foam covers that are held on with velcro. The last resort is ebay. Many sellers part out speaker parts and may even have another complete unit cheap with covers.
Jul 18, 2009 | Audio Players & Recorders
Foam in hot tub cover broke
The foam in there is available at most insulation or drywall supply houses. It is used for insulating concrete walls, the cover is probably 3 inches thick so you may have to buy 2 sheets to get the thickness you want. The only issue is the cost of the foam may not be much less than a new cover.
Mar 11, 2009 | Dream Maker Spas Dream Maker Ez Spa Hot...
Torn foam covering on handle
Hi there's a place in america that sells replacement zip up foam covers for the Quinnys, do it in various lengths so you can also get one for your bumper bar at the front if thats a bit tatty as well. They are about £20 including shipping which is fairly reasonable considering how much the cost in the first place! Go onto ebay and look for 'quinny handle cover', and there's also companies on ebay that do replacement quinny stickers as well for a few quid as they wear so quickly.
Jan 19, 2009 | Quinny Buzz Jogger
Foam filter fabric
Yes you can buy it in hardware, just cut it to fit in the frame.
Feb 26, 2008 | Friedrich QStar SQ06J10 Air Conditioner
Canon d660 imageclass copier
Hello himsmyboy!
Sikna says
The ADF separation pad is the cause. To remove it lift the cover fully up then use a knife to get under the black tape tab at the top right of the large white foam pad. Pull the tape and the white foam pad loose but not completely - leave the bottom attached. Now you can see the ADF separation pad from below. Use a small screwdriver or spring hook to remove the spring and you will be able to wiggle the ADF separation pad out. First take a good look at how it fits in so you can put it back! The problem is caused by the small black foam pad under the white rubbery tape on the ADF pad assembly. I carefully removed the tape from the back edge to expose the compressed black foam pad. I then cut a matching size of 1/16" foam I had in my shop which was actually HP 98A doctor blade seal foam and just stuck it on top of the old compressed foam. (other similar foam should also work) Then I replaced the white rubbery tape and rubbed the edge down well. I then reinstalled the restored ADF pad and the spring which holds it. Last I just pressed the large white foam pad back into position - being sure to pull it with a slight tension as I pressed into place. This fixed the ADF feed and it worked like new again...
Sikna out...
Jan 15, 2008 | Ricoh Aficio SP-C210SF Printer
Soyo FreeStyler HS11 Bluetooth Stereo Headset Wireless Headset Logo
75 people viewed this question
Top Soyo Radio Communications Experts
eradiostore
eradiostore
Mike Charette
Are you a Soyo Radio Communication Expert? Answer questions, earn points and help others
