Question about Rimage Everest II Printer
Re-transfer sheet upper sensor not responding
Hp 9050 laser jet stacker error
Probably just a bad sensor or dirty sensor causing the issue.
Stacker or stacker/stapler output bins
For the 3,000-sheet stacker or 3,000-sheet stacker/stapler, the output bins are the upper bin (face-up) and the lower bin (face-down).
The upper bin (face-up) is the top bin on the stacker or stacker/stapler. This bin holds up to 100 sheets of paper in face-up order as they exit the printer. A sensor causes the product to stop when the bin is full. Product operation continues when you empty or reduce the amount of paper in the bin.
Lower bin (face-down) is the lower bin on the stacker or stacker/stapler. This bin holds up to 500 sheets of paper and can stack or staple jobs. This bin is the default output bin.
Aug 19, 2014 | HP Stacker For LaserJet 9040/9050/9500...
Printing stops on its own after printing a couple of pages. 2. Printing has yellow overlaps. Have changed the PCU after printer signalled change. Have rebooted, and checked correct replacement of...
SC285 is a line position adjustment error. It is possible the ID sensors are dirty. In order to get to them you have to remove the PCUs and developers as well as the transfer belt assembly. The sensors are behind the shutter that is next to where the upper most PCU would be inserted.
Mar 11, 2011 | Ricoh AFICIO SP C821DNX 50 PPM 4X550 SHEET...
Canon 1120 error: E021/0201 machine not getting ready
I had a similar problem come up, and the best advice I can give is to reseat the various parts (drum and toners).
May 30, 2010 | Canon CLC 1120 Color Copier
E07-59
E7-59 Finisher Upper Limit Sensor 1.
Stack Tray Paper Height detection Sensor, or Paper
Hold Lever detection Sensor is defective, or the
connector is disconnected.
2. Upper Limit detection Sensor is defective.
3. Upper Limit detection Sensor connector is
disconnected.
4. PCB is defective.
there is a sensor that registers the top of the top most sheet on the finisher. it determines where the tray should stop as it is filling up. the sensor does come adrift and needs to be refitted back into its holder. i'm afraid you may have to call a technician.
Apr 15, 2010 | Panasonic DP-C213 Color Copier
Canon CLC 1140 transfer issue on heavy or extra heavy stock
you must chose the bypass try to copy the heavy paper
Mar 24, 2010 | Canon CLC 1140 Copier
My CLC 1160 reports paper jam on transfer drum. All sensors are OK. Thank you in advance. Best regards
Howis the transfer sheet? Is it cloudy? Or almost white? If so you will need to replace the transfer sheet. Good Luck
Jan 15, 2010 | Office Equipment & Supplies
Ricoh Aficio CL800 - Set Transfer Roller
possible transfer roller rotation sensor dirty or damaged transfer roller. check -- open rear door and see how the roller looks.
Apr 10, 2009 | Ricoh Aficio CL1000N Printer
E079 code
all the 70 codes have to do with the transfer sheet unit ... either the sensors in it or the lift mechanisms motors etc unless your a tech this is probably over your head
Dec 10, 2008 | Canon CLC 1150 Color Copier
Paper Jam
this is probably the sensor inside the transfer sheet or the reflection plate under the cleaning blade assy being dirty. also there is a reflection plate on the bottom of the transfer sheet near the gear assy
Sep 16, 2008 | Canon (6981A002AA) for imagerunner 2200,...
Brother Intellifax 2820 repair + automatic document feeder + sensor
Brother Error Codes
RAM clear (most models)
Quickly press function * 2 8 6 4
Display should read maintenance
Press 0 1 for a full ram clear, or 9 1 to retain user data
Display should read reinit for a few moments then redisplay maintenance
Press 9 9 to exit the maintenance mode
Other maintenance mode switches:
01 ram clear (see 91 below)
02 scanner initialize (feed a white sheet, then a black sheet)
05 white level
09 print test
10 modify soft switches
11 print configuration list
16 panel test
19 CML test
20 signal test
21 tonal test
23 filter RX
54 scan edge
55 scanner area
66 test print memo
75 display drum life (if enabled on laser models)
76 reset drum life counter (laser models)
91 parameter initialize (user programming remains intact)
95 protection
B2 error = scanner or power supply error
Brother 950/980: On copy or transmit they may produce black pages. Prone to bad scanner (CCD). Brother may provide a replacement CCD at no charge to the original owner. Sometimes leaving the unit unplugged for a few hours will solve the problem temporarily.
Brother HL600 series laser printer toner will work in the laser fax & multifunction machines (part number TN100HL = TN100PPF). Drum units may be interchangeable as well (?).
Brother 1350/1550/1950: Problem: Record paper jams. Solution: Replace upper shoot. P/N UF6058001. Although there seems to be nothing causing the jam, the upper shoot gets stress marks on the ends. Replace even though it is not broken.
Thermal Transfer Machines: Only one side of the page is printing. Caused by the printhead latch being cracked. The latch is blue in color there is one on each side of the printhead, replace both latches
Nov 06, 2007 | Brother MFC-7220 All-In-One Laser Printer
Rimage Everest II Printer Logo
105 people viewed this question
Top Rimage Office Equipment & Supplies Experts
k24674
jasbo
jasbo
Are you a Rimage Office Equipment and Supply Expert? Answer questions, earn points and help others
