Question about Optoma EP716 Multimedia Projector
Overheated lamp will turn off message - Optoma EP716 Multimedia Projector
ASK Proxima C420 shuts down after 30 seconds. No indication of overheating or lamp problem.
Might be a problem with the video input. Try a different cable. If HDMI, you will need a really good cable for HDTV or 3D, and they are very expensive. My 12 foot cable cost $180.
Sep 12, 2014 | ASK Proxima C420 Multimedia Projector
I TURN ON THE TV & TURNS OFF AFTER A FEW SECOUNDS
Check Lamp Fan and If Lamp has never been replaced ,then you could have Bad Lamp Mats has them for $89.00 1-800-629-1118. If they do not have Lamp then Look on EBay.
Jun 19, 2011 | RCA Scenium HDLP61W151 61 in. HD-Ready...
I have a Sony SXRD KDS-R50XBR1 and the tv keeps shutting off and turning back on. While its off the green power light flashes. I just had the lamp replaced and the optical block replaced a few months...
Green light flashing is normal as the lamp warms up before turning on.
If it runs for a bit before turning off it's likely to be overheating somewhere.
Looks to be more than one fan in this so possibly dust in one of the others but there should be a "High Temperature Warning!" message if it's overheating. This set has a "high altitude mode" for extra cooling.
If it turns on and then turns off again instantly it might be something has failed.
There is quite a detailed service manual if you want to have a look for possible clues:
https://www.manualslib.com/manual/817639/Sony-Kds-R50xbr1.html?page=192#manual
Jul 17, 2017 | Sony Televison & Video
I get a message that the air flow/fan is blocked, then the tv shuts down. It's not blocked. It's perfectly clean.
This indicates the TV is overheating. Lamp based TVs usually have two or even three fans. One may be having problems or not turning fast enough.
Mar 31, 2010 | Televison & Video
About how many hours are left when the replace lamp message comes on?
usually between 0 and 50, depending on how clean you keep the projector. if it's really dusty, the lamp could explode from overheating at any time.
Feb 07, 2010 | InFocus ScreenPlay 7205 Multimedia...
I just replaced the lamp about 5 days ago on a mitsubishi wd-52631.it has worked fine until this morning,I turned it on and it said overheating check airflow and shut down.yellow light is on,tried to reset...
call Mitsubishi they have a recall on this particular problem. It has a thermal sensor that needs to be replaced, they are picking up the bill on this so it's not suppose to cost anything for this repair.
Aug 19, 2009 | Televison & Video
Mitsubishi HC900 Projector shuts down after 5 minutes.
You have 1 of 2 possible problems.
(1) You need a new lamp.
(2) You have an overheating problem.
Just a quick couple of notes about your projector. It is a DLP projector (not LCD) and as such the machine as no air filters to clean. It does have air intake and air exhaust grilles, but no air filters to clean. This next part comes directly from the owner' manual for your projector:
When the lamp operation time exceeds 2000 hours*1 *2, the projector automatically shuts off and can’t be used until the lamp is replaced and the lamp operation time is reset.
Your machine is designed to give visual warning messages at 1500 hours used, and 1900 hours used. Did you see any visual warning about lamp life over the past few months?
If you were experiencing an overheating problem, a "TEMPERATURE!!" message would flash up on the screen just before the unit shuts down. If there is no warning, you don't have a heat problem.
If you have a replacement lamp available, install it and reset the lmap hours according to your user manual. If you don't have the manual, google it on the web (it available).
Apr 01, 2009 | Mitsubishi HC900 Multimedia Projector
Christie DS+60 projector turns off spontaneously
Here is a list of error codes for your unit:
12 Software bug. Contact dealer/factory.
13 Flash memory corrupted. Download new software.
14 Engineering only programming is complete. Call Christie, replace TIPM.
15 Attempting to download code without being in boot mode
16 Invalid interrupt. Power off/on. If it persists, contact dealer/factory.
17 Forced boot mode. Keys held down too long.
18 Attempting to program boot mode without jumper
LAMP FAILURES
21 Lamp compartment too hot
25 Lamp 1 not installed
26 Lamp 1 Interlock: door open, lamp not installed
27 Unable to turn lamp 1 ON
28 Lamp 1 shut off unexpectedly
29 Lamp 1 driver overheated
2A Lamp 1 driver operation error (e.g. too hot can’t start)
2C Lamp 1 driver UART communications failure
30 Lamp 2 not installed
31 Lamp 2 door open
32 Unable to turn lamp 2 ON (unknown reason)
33 Lamp 2 shut off unexpectedly
34 Lamp 2 driver overheated
35 Lamp 2 driver reports operation error (e.g. too hot can’t start)
36 Lamp 2 driver UART communications failure
37 Lamp Watchdog Tripped – Unless lamps turn on again after 3 minutes, assume software hung.
Jan 16, 2009 | Christie DS+60 Multimedia Projector
Lamp will not strike error message
this can sometimes indicate either an overheating issue, a lamp service life problem, or that the cover to the lamp housing has not been secured properly.
Dec 14, 2007 | InFocus LP120 / 1000 Lumens / XGA / DLP...
Optoma EP716 Multimedia Projector Logo
32 people viewed this question
Top Optoma Office Equipment & Supplies Experts
jasbo
jasbo
color wheel light...
Are you an Optoma Office Equipment and Supply Expert? Answer questions, earn points and help others
