Question about Canon P200-DHIII Calculator
What does the E message mean?
Calculater seems to have quit. getting E on screen. changed ribbon. didn't help. it's printing gibberish on left side of paper instead of right.
Soulvisitor
  • 1113 Answers
SOURCE: Paper feed problem
Sound like something foreign is in paper path
Posted on Dec 24, 2007
SOURCE: Paper does not feed - GRABS RIGHT SIDE
I once had a similar problem a few months ago and I tried EVERYTHING I could do (Without shaking the printer, I was scared to do that) nothing worked, till I actually got up on a chair and looked into my printer (It is up on a rise above my computer) and there was a push pin sitting in the feeder opening! (Remove pushpin = then it was fine)
Then it started doing it AGAIN yesterday at a time when I really needed my printer, and this time there was no obvious pushpin or any obvious obstruction. I read all the stories here and thought *WOW they had things that far in there?!" So I tried harder and FINALLY after opening the back panel I saw with a flashlight there was a FROOTLOOP (I don't even HAVE any frootloops in my dorm! XD) jammed in the right side inside it! With a chopstick I was able to get it out and now it's fine again. OMG.
But yea, things like to get stuck in printers I guess. XD
Posted on Apr 02, 2008
  • 521 Answers
gears below the paper feeding tray are damaged or some dust particle have blocked the gears try to clean it by blowing the dust use normal greece (oily substance) between the gears so that they can move frequently to pull the paper, and if the gears are damaged you have to change the gears.
Posted on Aug 08, 2008
SOURCE: Canon MP460 feeds the paper into the printer
I just got mine sorted out. It took two things:
a. luck
b. a lot of googling
Now,
The problem was 15 cents of the Euro in the following configuration: 1x10cent coin and 1x 5 cent coin...
The first thing I did was try to clean the bottom plate and the roller. I read somewhere that using some thick paper does the trick. I destroyed an office paper file (not very thick, but definately thicker than normal papers) - about 5 - 6 tries on the bottom plate clean and the roller clean, and a 5 cent coin appeared out of nowhere :)
I though that was it but I was very very wrong. At about the same time, I got the mother of all annoying canon error 5100. Although the heads moved at starting of the printer, when it came to print it had the error. I looked as much as I could and I was convinced (several times) that there was nothing in the printer. The heads moved fine, but the error was there. Rebooted the printer about 50 times, took power off etc, but nothing.
After a good 5' search with the flashlight (mobile phone) I spotted a small shine right where the little spongy thing is under where the heads rest far right when you look inside from the front of the printer. And voila, a 10 cent coin standing glorious in there and causing me all this trouble. I couldnt access it at all, but I was able to use the force of gravity (by inverting and giving a little jiggle to the printer) to get it to drop and finally got it out.
The printer works fine now, paper loads like a charm and even colour photo printing is fine.
Now I need to find a way to put back that little plate I took out (totally unecessary in the end...) and I have to sort out the removal of tons of ink from my hands.
To sum up:
It can be fixed. It's a pain in the ****. You might get richer (15cents for me!!!). You will have a full functioning MP460 printer again.
I hope this helps someone else as well :)
Posted on Mar 19, 2009
SOURCE: Canon LBP 1120 Offset paper feed and subsequent jamming.
G'day, I pulled the whole printer down and gave it a clean and put it back together and set it to work. All good.
Posted on May 12, 2009
Officejet 4500 printing problems
I had that problem, I removed the problem and let it itself intall again.
Note, this will only work on Win7/Vista/8
Jul 25, 2013 | HP Office Equipment & Supplies
Have an Everest III disc printer that is not printing good labels. Seems the blue prints OK but the are streaks on the disc where the red and yellow should be printing. Changing the ribbons didn't
First thing is to completely CLEAN the printer. All rollers and any point that contacts the ribbons or transfer material.
John Norman
Max Optical llc.
www.maxoptical.com
Aug 08, 2012 | Rimage Office Equipment & Supplies
The top screen on my ds lite keeps flickering lines. this gets worse the longer it's on for but it does seem to help if i play while on charge or close and re-open the ds. I'm not sure what needs replacing...
It might be worth checking the ribbon cable for the top screen is tight in the socket on the main board, this could explain why the screen gets back to normal when you close the ds then reopen. The ribbon cable for the top screen is in the hinge on the left side of the ds when open, the only way to check this is to take the back of the ds, to do this you will need a small philips screw driver and a tri-wing screw driver which you can get of ebay quite cheap. The worst possible fault is the top screen is faulty and needs to be changed, if you do a search in youtube you will find videos on how to do this, they are good and quite detailed. hope this helps.
Feb 17, 2010 | Nintendo DS Lite Pink Console
Zebra Z4 Error message
ribbon in means, you choose direct thermal print method which is printing without a ribbon and yet you print with thermal transfer print method.
just check on lcd panel , change the print method to thermal transfer. and make sure the setting on your driver is thermal transfer too, or else it will keep reverting back to direct thermal
Feb 04, 2010 | Zebra Z6M Plus Thermal Label Printer
My mom's hp officejet T45 printer now prints gibberish. It started after my sister installed a new ink cartridge for her. Because her documents were printing nothing but a solid black line then, my...
Gibberish sounds to me that ether one of two things is going on.
1. the printer was never allighned when the new cartridges where put in.
2. Depending on the gibberish its printing it could be a communication error with the driver on the computer.
Do not pitch the printer but get help for it like you are doing now! But I would have taken a chat from us to see what the gibberish is!
Dec 18, 2009 | Cameras
ZM400 printer
Try going through the LCD menu and if it say "Direct Thermal" change it to "Thermal Transfer", Direct Thermal made means, no ribbon required, but it sounds like you do have ribbon in the printer, if so, try my recommendation. If it asks for a password, it's '1234'.
Oct 14, 2008 | Zebra 203DPI Printer
Printing
Hi,had the same problem, phoned the helpline, the fix is a new ink ribbon, basically it has run out of ink (or dried up)
Aug 13, 2008 | Cameras
"warning Ribbon In" error message
Had the same problem with a ZM400. As stated in the User manual (can be downloaded http://www.zebra.com/id/zebra/na/en/index/resource_library/manuals.results.html?FRRBarcodePrinters=6882), warning "Ribbon in" is usually caused by the wrong printing method (thermal direct instead of thermal transfer [which should be selected for ribbbons]). My error disappeared after choosing "thermal transfer" directly on the printer. For network printers this needs to be set by an admin in the network settings for the the printer to solve the problem permanently.
May 07, 2008 | Zebra 105SL Thermal Label Printer
Hp deskjet F 380 all-in-one prints gibberish
Ok so the fact that it is printing gibberish means that either A you have not installed the hp software or B the software is not being recognized or is corrupt.
If you have not installed the software that came with it you have to do that so the proper drivers are installed.
If you have the software installed then go to your start menu and then the control panel. Go to printers and faxes and delete the F380 from the list. If there is more than one then delete them all. Then click on the add a printer button on the left. Go through the prompts to add the printer to the list and then close out and try to print again.
If that still does not solve the issue go into the hp folder in the start menu or hard drive and do the hp uninstaller and download the most recent drivers from www.hp.com - on the left side you will see a grey menu that says software and driver downloads click on it and type your product. Then click your OS and download and install the applicable file.
Feb 27, 2008 | HP DeskJet F380 All-In-One Printer
Canon P200-DHIII Calculator Logo
15 people viewed this question
old marine
old marine
