Grundig manuals model # s350DL - Audio Players & Recorders
4 Suggested Answers
SOURCE: Grundig S350DL needs a am aerial to bring in the
1. run 18 gauge wire (buy in auto parts shelf), after stripping plastic (about 1/2 inch) away from wire inside. Clip where RED clip is, on back of radio. Need about 6 to 10 feet. Run wire in upwards direction from radio. At other end of wire, strip enough to make small loop back onto itself. (terminates the wire.) Run another length of same wire from BLACK clip on back of radio, strung along floor of room - 6 feet, maybe. Yes, hide it if it does not please somebody's eyes. Now, you have an AM external antenna.
2. Go to E-Bay, "slinkyantennas". They have a very good-looking, and performs for DX'ing antenna. Use same wire from RED clip, stripped, for alligator clip from 'slinky' shop's antenna to grab hold.
--With s350dl (NPR version-before major t-storm did kaputs, learned good lesson ... always use batteries, not A/C), and slinky pvc-style antenna with ground wire, was able from Central Louisiana, to pick up KOA from Denver!
Posted on May 08, 2009
SOURCE: We have a Grundig S350DL radio that was my
Hold down the power button for a second or two when turning it on to disable the timer. For AM reception issue, you could insert both ends of a long wire into the red and black connectors on the back to act as an extra AM/shortwave antenna, or connect a wire to a pipe, oven, or other grounded object and plug it into the black connector in order to improve reception. Those connectors snap to hold the wire in place.
Posted on Apr 08, 2010
  • 7993 Answers
SOURCE: I have a Grundig radio S350DL and I cannot switch
The Power and Sleep Functions share the same button. If you press the Power/Sleep button repeatedly you see numbers displayed 90, 75 60, ... 01. These are the duration of the sleep functions. If you stop at 60 the radio will work for 60 minutes then turns itself off. This must be a battery saving feature so that a radio will not be on for ever. Suppose the radio has been on for a while (long or short) and you want to turn it off without waiting for the sleep timer. Just press the Power/Sleep button.
Posted on Aug 18, 2011
Need owner's manual and wiring diagram for grundig model 5590 radio. Thanks.
U can maybe get the manual from the Grundig web site but I do not know about the schematic.
Aug 22, 2016 | Grundig S350 AM/FM/SW Radio
I need grundig servic manual for model 1070 table radio
Hi. It's on Elektrotanya free - it's in German.
If you're not a member you need to wait about 30 seconds for the download link to become available
GRUNDIG 970 1070 1088 2077 2088 2098 Service Manual free download...
Jul 02, 2016 | Grundig Audio Players & Recorders
Grundig S350DL - blew it out? I used a plugin 12 V instead of the 6V 500ma I should have - is it repairable and if yes, where in Minneapolis MN area could I find a repair shop?
No you have not blown it up. You have most likely blown an internal fuse mounted on the board, or blown a protection diode, or a regulator transistor. these are cheap items. The work will cost more than the parts for sure. Look for a radio repair shop, or a tv repair shop in the yellow pages. There might be a Grundig dealer near by that will recommend a service center. not all places work on gear like they did in the past. If you know someone that works on CB gear might do the job or ask for local ham he will just charge for parts. Your radio is not a lost cause, they build against this kind of thing. I remember the first time I did this very things, 30 years ago. Good luck.
Jan 30, 2015 | Grundig Audio Players & Recorders
I have a Grundig radio S350DL and I cannot switch off the sleep function and therefore the radio automatically switches off after 30 mins. or so . Can you advise? Les. Akers
Aug 10, 2011 | Grundig S350DLB FM Radio
We have a Grundig S350DL radio that was my father's. There is no manual. FM works great. Can't get AM. Radio turns off on its own!! Any suggestions?
The problem you are having may be due to some configuration settings (such as a timer). Not dtecting the AM signal, may be due to interference from power lines. To improve AM reception (if there is something to improve) one should rotate the radio to orient the internal ferrite antenna. Using the radio close to a window can improve reception.
To enable you to diagnose the problems that may be due to some configuration setting I give you the link to the radio's manual.
Hope it helps.
Nov 08, 2009 | Grundig S350 AM/FM/SW Radio
Feb 28, 2009 | Grundig S350 AM/FM/SW Radio
Grundig S350DL shuts itself off
The default mode for this radio is in "sleep-timer." You can adjust the time it stays on or you can hold the On/Off button down for a few seconds as you turn it on. (You'll notice the "bed" icon no longer appears.)
Nov 30, 2008 | Audio Players & Recorders
Intermittent volume level
Radio Shack does provide a volume control cleaner that you could gently spray to clean the contacts, but you may simply have a defective knob. (The first S350DL I bought had a defective volume control.) Don't hesitate to call Eton Customer Service either.
I hate to say this, but I've become a little wary of buying radios at Radio Shack. I have a suspicion that occasionaly radios that are returned get "recycled" back into stock rather than sent back to the manufacturer. I had to return 2 radios directly to Eton / Grundig after getting back to back defectives at RS.
Oct 21, 2008 | Grundig S350 AM/FM/SW Radio
I bought a Grundig S350DL for my husband for his birthday from Radio Shack. The floor model was the last one available so I bought it. The sales person said it was warranted the same as if new. He had...
Despite their renouned customer service, the folks in Palo Alto do get forgetfull on occasion. I asked for a new manual and had to call twice.
Call them again. The worst scenario is you wind up with two!
Oct 11, 2008 | Audio Players & Recorders
I need to know how to set the radio presets for the Grundig.
If you go to this link; http://www.amazon.com/Grundig-G2000A-AM-Shortwave-Radio/dp/B00000JD4T/ref=pd_bbs_sr_3/104-1966292-9407907?ie=UTF8&s=electronics&qid=1175876962&sr=1-3 This is the same model, and under "product details" you can download the manual. Page 21 of the manual (page 10 of the pdf file) should tell you what you need to know. Hope this helps :)
Apr 06, 2007 | Grundig Yacht Boy P2000 AM/FM/SW Radio
 Grubhead
Grubhead
