Question about Brother MFC-9120CN - 17 PPM Multifunction Network Laser Color Printer, Scanner, Copier, Fax Machine, MFC9120CN, MFC 9120CN
How do I reset the fuser AND PF (PAPER FEEDER) part life
  • Brother Master
  • 783 Answers
1) Press the 3 and 9 buttons at the same time in the ready status.
2) "Reset Menu" will appear on the LCD. Scroll to Fuser by pressing up arrow or down arrow button then press the OK button.
3) "1. Reset 2. Exit" appears on the LCD. Press the 1 button to reset the fuser counter. The display briefly shows "Accepted".
The machine returns to the ready status after a few seconds.
In Case You Still face Problem and Need Online Assistance Then Please Follow Us For On : Brother Printer Support
Posted on Feb 07, 2014
4 Suggested Answers
  • 54 Answers
SOURCE: will not feed paper
Replace the paper feeding (PF) kit and the fuser. Instructions on how to do so maybe found on this manual.
Posted on Apr 13, 2009
  • 5 Answers
SOURCE: RESETTING FUSER LIFE ON BROTHER HL5140 PRINTER
How to reset the pf-kit message on a brother hl-5140.
Posted on Aug 12, 2009
SOURCE: how do you reset fuser life on a brother HL 4040cn
Press the Go and 'Up' buttons at the same time in the ready status.
The "Reset Parts Life" will appear on the LCD. Select the applicable periodical replacement part by pressing the 'Up' or 'Down' button and press the 'OK' button.
Posted on Apr 08, 2011
My PF KITMP life is at 90% can I reset this and get more life out of it or will I have to replace at 100%
PF KitMP is the Manual Feed Paper Kit. Normally these count down not up. If it is counting down there is no need to replace it any time soon.
The life on the kits is based on a certain number of pages being fed through it. The rollers wear with every page sent through. These rollers when the kit expires means they are probably worn smooth and not able to pick up the paper anymore. There are ways around the wearing of these rollers so you may not need to replace them as soon as it expires.
On the machine there will be a maintenance option in the menu which includes parts life and resetting of said parts. I would assume that the parts are going to be available for quite some time since most people dispose of the machine before the PFKits run out. So check with your Brother Supplier for parts availability. The kits are not too expensive normally.
Sep 08, 2014 | Brother HL Office Equipment & Supplies
HL-5250 report shows fuser and laser life at 0% and PF kit 1 at 12%
The fuser is a separate component to the drum and toner in this printer. It has a much longer life than them but will run out eventually. Sadly a fuser unit is not a commercially available consumable for this printer either. I would recommend contatcing a printer technicain or Brother directly for a quote on replacing this part.
Apr 12, 2013 | Brother HL 5250DN Laser Printer
I need to replace "PF
Ah the Paper Feed Kit 1 on this unit is pretty easy,
If you remove the paper tray and put the printer on it's back you should see the rollers you're going to replace.. unfortunately the service manual doesn't show this procedure so I can't provide a picture.
If memory serves correctly there should be a long light-blue plastic piece that holds the PF Kit roller assembly in place. If you bend this towards the back of the machine the PF Kit should swing down and you just slide it out, replacement is the reverse of this.
Once you're done you'll have to reset the PF Kit counter by:
Press GO and + together,
you should see RESET PARTS LIFE on the LCD
You can then use the + / - to pick the PF Kit and press the SET key to reset the counter.
If you still have problems let me know via this question and I'll try to help further.
Jun 10, 2011 | Brother HL 5250DN Laser Printer
Code dk
Your black drum counter has reached 50,000 copies. The drum has reached the end of its' rated life. You should print Sim 22-6 and see which other internal supplies need to be changed out. Drums=50K, Transfer belt and fuser=100K; paper and doc feeder tires=100K to 150K.
Sep 20, 2010 | Sharp AR-C260M All-In-One Printer
Replace the PF KIT 1 On my MFC 8460 N
that refers to the automatic feed. in other words, your main paper cassette. the MP kit is for the manual bypass tray. if paper is feeding ok and your not having problems, you can reset the message by pressing "menu" " *2864" within 2 secs. now you are in maintenance mode. push "88" should show "parts replacement." using arrow buttons go to reset pf1 kit and press "ok" or "start" to reset. press "stop/clear" to back out to maintenance mode screen. press "99" to exit maint. mode. do not mess with any other settings in that mode as you could render your machine inop. however, you may want to reset the "fuser life" while you are in maintenance mode "88" as both of these messages are supposed to come up at 100,000 pages. chances are unless you've had fuser replaced, that message will be coming up soon also.
good luck,
razors
Mar 25, 2009 | Brother MFC-8460N All-In-One Printer
Will not feed paper
Mar 24, 2009 | Brother MFC-8460N All-In-One Printer
Paper feeder unit open(Kyocera FS-3800n)
Here you go all parts you need:
parts number Description
5AAPRCZR2013AH P.W.B.ASSY KP-772 CONT X X 1
5ESM010235***01 MICRO SWITCH X X 1
5ESM010234***01 MICRO SWITCH 01X02 X X 1
let me know if you need anything else? enjoy
Dec 23, 2008 | Kyocera Mita Kyocera-Mita - PB-60 BASES...
May 17, 2008 | Brother HL 5140 Laser Printer
Brother MFC-9120CN - 17 PPM Multifunction Network Laser Color Printer, Scanner, Copier, Fax Machine, MFC9120CN, MFC 9120CN Logo
204 people viewed this question
CheckitRight
CheckitRight
Ron Dufek
Ron Dufek
James Cagle
James Cagle
