Question about Intertherm Heating & Cooling
What and where are the snap discs located in intertherm model MGH - 075aac
    Sergeant:
    Champion:
  • 234 Answers
On the firebox cover near the top.
Posted on Nov 26, 2014
3 Suggested Answers
  • 10 Answers
SOURCE: Where are the furnace filters in my older furnace?
On these of Furnaces the filters mount on the door. Remove the door you will notice grill on front. There should be a track on the back of the front door to slide filters down. Should take 2 filters.
Posted on Dec 06, 2009
Testimonial: "drifterray really helped. way to go apprentices!"
  • 8 Answers
SOURCE: I need a wiring diagram for model #MGHA-056ABFC-05 serial # MGH-9611-07667
Might want to Google that.
Posted on Jan 30, 2012
I have a Intertherm model MGH-075-ABWN-05 and the A/C stopped working. someelectrical problem i'm guess.neither the blower fan nor the outside unit are running at all
Check the drain line for a float switch. Remove float and check for water. Do not leave float out, you must clear the drain. Good Luck
May 10, 2017 | Intertherm Heating & Cooling
Got Intertherm Model # MGH-055AB.. It lights for ap 10 seconds goes out then goes out... Over and over again does not stay lit long enough for the blower to start running?? ANY IDEAS HOW TO FIX IT ?
You have to try resetting the system. First turn the breaker off for the condenser and wait about 20 seconds. After you turn it back on the system should reset. If the s3 comes on then you have an issue with the unit and i would get a professional to help.
Air Conditioning Boca Raton
Apr 10, 2015 | Intertherm Heating & Cooling
Looking for a gas valve for a intertherm furance model no. mgh-055aacwl-06 ser.number mgh9009-00077
you need to contact your nearest a/c supply house. most company's that sale parts on line will not sale gas valves to the public due to liability.
May 15, 2014 | Intertherm P3RA-048K Air Conditioner
Intertherm MGH-075AAC burner cutting out before fan comes on
If you have a combustion air problem the flames will fade out instead of turning off abruptly. 15 to 20 seconds is a long time. if you are sure it is taking that long then it is not likely a flame rectification problem. If a limit is turning the flame off then it will turn off very abruptly like you turned off a switch. The evaporator coil situated above it may be dirty and in need of cleaning. sometimes however the limit switch will get to where it is shutting off at a way lower temp than it should. Limits are cheap enough and easy enough to just replace. DO NOT BYPASS THE LIMIT!!!!! You could burn your house down!!
Aug 28, 2017 | Intertherm Heating & Cooling
I have an old Intertherm gas-fired furnace, Model MGH-055AB which ceased operating last night. It was quite warm when I arrived home, and when I set the heat up a little, began to hum, but the fan would...
Tom P's answer is generally correct: The motor start capacitor is usually not the problem. However, in some cases, particularly on older furnaces, where there were capacitors of certain make and production run will prematurely fail. This happened in March on a mobile home HVAC unit where both the blower fan and condenser fan motor capacitors failed open circuit. Both caps were of the same Mfg, and production lot.
Here is a suggestion (for you or an electrically inclined friend): Locate a substitute motor capacitor having similar Mfd (or MF) and Voltage ratings. Remove power from the unit. Reach into the blower squirrel cage and spin it to verify that the shaft is not frozen. Pull the wires from the existing capacitor noting color and location. Connect the wires to the substitute capacitor and secure it place. Apply power and turn on the blower. A no start? Motor replacement time.
Nov 08, 2011 | Intertherm P3RA-048K Air Conditioner
No problems, would like to find out the best way to remove blower for cleaning on an intertherm gas furnace mgh 075 ina mobile home
Generally ther is two screws at the base of the blower housing which hold it in place, remove the screws and pull, slide the entire assembly out. You will have to disconnect the electrical wiring to the blower and possibly the limit switch on the side if equip.
Aug 23, 2011 | Dayton Gas Furnace Heater
Open the door to the airhandling unit inside the closet by lifting upward on them. There should be two filters located on top of the A coil.
Dec 05, 2009 | Heating & Cooling
Gas Valve is leaking
I am a Nordyne dealer and you can replace your gas valve with a generic valve of your choice. You can try and find a supply house in your area that sells them or you can visit www.myhvacparts.com to find one.
Apr 05, 2009 | Intertherm P3RA-048K Air Conditioner
Heating & Cooling Logo
41 people viewed this question
Top Intertherm Heating & Cooling Experts
Dennis Boxerman
Dan Webster
Dan Webster
Bill Long
Are you an Intertherm Heating and Cooling Expert? Answer questions, earn points and help others
