Question about Air Innovations Clean Mist Ultrasonic Humidifier - Black -
When running the humidity level stays at 31 no matter what level I set.
MA-12010 comes on but will not stay on
my regservo need to active plz help me for activation code
Dec 29, 2013 | Emerson Humidifiers
No humidity
remove and clean the filter then re-install it the air is being blocked
Dec 03, 2013 | Honeywell QuietCare HCM-630 Humidifier
After cleaning everything the humidifier no longer runs. When I turn it on no matter what level I set the desired humidity to the green light goes on indicating that it is at the desired humidity. Before...
The humidstat controler has failed. By cleaning the humidfier you introduced moisture into the system. Dry the humidstat controler with a hair dryer and try the humifier again. If the unit still does not shut off at maxium setting. Replace the humidfier controler.
Jan 26, 2011 | Hunter 32300 Humidifier
Water only runs with humidistat in test/reset mode. Aprilaire 600 with an Aprilaire 56 Automatic Humidistat, both about 5 years old. Water line is clear, and test mode runs fine for the 1 minute interval....
you need to make sure your humidity level in the house isnt higher then what your humidifier will provide at any givin outdoor temp. this chart is in the owners manual. you cant remove the wires going to the ODS or it will give an error unless you have a resistor to put in its place. Anyway if the humidifier works in test mode according to AA it works so you may have higher humidity than you think, the highest your gonna get is 45% as the temp outside drops it will allow less humidity so it doesnt cause window condinsation (property damage) here is a copy of the chart. the #s on the left are the dial setting
TABLE 2 – % Relative Humidity Guide
Outdoor Temperature (°F)
-10°F 0°F 10°F 20°F 30°F 40°F
10% 10% 10% 15% 20% 25%
2 10% 10% 15% 20% 25% 30%
3 10% 15% 20% 25% 30% 35%
4 15% 20% 25% 30% 35% 40%
5 20% 25% 30% 35% 40% 45%
6 25% 30% 35% 40% 45% 45%
7 30% 35% 40% 45% 45% 45%
Nov 28, 2009 | Aprilaire 600 Humidifier
Aprilaire 600 humidity level too low
you may try running your blower 100% of the time.this should allow the humidifier to stay on even when your not heating. once the humidity level gets to where you want it, you may be able to put the fan selector back to auto. also you mentioned you have a variable blower. this is great if it is set up to run at approx. 20% fan speed when it is not heating or cooling. at 20% you can circulate enough air through the house to humidify without being able to hear the noise of the blower. it will really increase the comfort level of the house if you tend to have hot and cool spots. if it was not set up this way, contact the installer and ask if they can do this for you.
Jan 26, 2009 | Humidifiers
The max the aprilaire can put out is 45% Rh. Your humidifier may wired up to run only when the heat is on. In some cases this is not enough time to maintain your humidity level your seeking. To correct this, the hum. has to hooked up the hot side of the water supply. And the humidifier has to be hooked up when the fan runs and leave the fan run constantly
Jan 12, 2009 | Aprilaire 600 Humidifier
Humidifier occasionally runs in spurts (on for 2 secs and then turns off)
It's just trying to keep the humidity level you set it at. By dropping the temperature in your home or changing the humidity level you want you can avoid this.
Good Luck.
Feb 12, 2008 | Lasko 1128 Humidifier
Temp
My guess is that you are trying to bring the humidity up too high. There is a chart in the manual that suggests where to set the humidity at based on outdoor temps.
I try to keep the level at 30-35% in the winter.
Hope this helps.
Dec 02, 2007 | Kenmore 14410 Humidifier
Air Innovations Clean Mist Ultrasonic Humidifier - Black - Logo
73 people viewed this question
Top Air Innovations Humidifiers Experts
Mack Baxter
Dennis
Are you an Air Innovations Humidifier Expert? Answer questions, earn points and help others
