I have a goodman furnace gmp075-3, igniter problem, i replace and over night it goes bad, as like a fuse blowing, am i getting to much voltage,and if it is, what regulates or could be the problem, thank you in advance, DALE
  • 148 Answers
The igniter should rating no more than 5amps. If you check the max ampre while it on reading too much then you have problem with voltage from the board
Posted on Feb 14, 2014
4 Suggested Answers
WebTeligent
  • 42 Answers
SOURCE: No heat, trouble shooting light has continious flash.
There is a vacuum sensor on most units tied from the exhaust gas fan to the sensor. Does the unit try to start? If the unit's exhaust fails to pull the switch it will turn off after about 30-45 sec after starting. "IT" thinks it's not exhausting and stops to keep from overheating. Do you have this exhaust fan and rubber hose to sensor? Can you see if that fan is turning on start?
Posted on Nov 10, 2007
  • 288 Answers
SOURCE: Goodman furnace burner ignites then shuts off in about 10 seconds
if you have replaced the flame sensor and it will not stay lit, the draft safety switch may be opening. It works on positive and negative pressure created by the inducer fan motor.You may have a restriction in your heat exchanger or if is a high efficiency furnace, it may not have the drain tube installed properly with a trap. The trap works just like the trap under your sink and if water isnt in the trap, the pressures can be effected enough to open the draft switch(some call it an air pressure switch)
Posted on Jan 07, 2010
atocrxr
  • 135 Answers
SOURCE: My goodman furnace will start to ignite, then it
Another part that you might want to check is the flame sensor. It is a very good chance that this is the problem, the stat calls for heat, the induced draft motor (little motor on from of furnace), ignitor comes on, the main burner fires, just for a second or two, the burner shuts down, the main blower motor defaults to blower on!
If this is the issue;
Then this is what you do to fix it, kill power to the furnace, look where the burners are, to the left side there is a little wire, usually yellow or orange running to what kinda looks like a spark plug, one screw should be holding it to the burner bracket. take it out, at the end of the white porcelain is a small metal rod sticking out, it probably has a slight bend in it.
take some steel wool, or sand paper and clean the rod till is is nice and shiny, NOTE: when you take it out, it won't look really dirty, maybe just like a pencil lead,,,,it is dirty!
Just use the sandpaper and clean the rod till it looks like metal, "do not sand the white porcilen". Put the part back in and turn the power back on and run the furnace as usual.
90 % chance that this will fix your problem.
The rod get a build-up on it from the sulfur that is added to the gas, and has a hard time passing the milli-volt signal back to the furnace computer, which is passed from the ignitor, through the flame, to the sensor! This way the computer knows that all of the burners are firing and it is safe to run!
Please take time to come back and rate me, or contact me with any further questions!
Have a warm day :)
Sincerely,
Paul Gibson
NOTE!!
Do not touch the ignitor! The part that gets bright and hot! Even when it is cold, the oil on your fingers will cause it to burn out.
Posted on May 03, 2010
Brand new furnace wont start its a aruf 14 electric air handler with a 10 amp heater coil
the 3 amp fuse protects low voltage side of transformer. if it's blowing on a call for cooling wire pair going to outside unit bad or contactor in outside unit.
Nov 18, 2013 | Goodman Heating & Cooling
Lennox lb50527cc
high limit switch, no proof of flame.
Oct 27, 2013 | Goodman Heating & Cooling
Goodman furnace w/ propane conversion: Last March our Goodman GHP100 stopped blowing hot air. Service man came while I was at work and told my wife the fuse had blown. The part she showed me was the...
the 271n is a Trane round igniter and the 271nm is a Goodman flat igniter other than the shape and size there is no difference either will work fine allot of time if you touch the igniter surface with your fingers the oil of your skin will make them burn out faster (like a halogen light bulb) I would keep one around in case of emergencies but it's not something you should have to change annually they do break and burn out but if it glows and after you replace it and the furnace works fine there probably isn't another problem. You should be fine.
Hope this helps dont forget to rate me.............
Nov 22, 2010 | Goodman GMS90703BXA Heater
Goodman GMP75... keeps blowing fuses only in A/C mode. Only when I connect yellow wire from thermostat to line going to condenser contactor (24V side).
Are you talking about the small 3 or 5 amp fuse in the furnace? If you are then the control voltage circuit to the condenser is shorted, Maybe dogs or rodents chewing it or the insulation is cut by a sharp piece of metal. Sometimes the contactor will go bad and cause the small fuse in furnace to blow. Look for the simple things first, like control wires shorted. Make sure the yellow wire from the thermostat goes to the outside unit and not to the common.
Jun 30, 2009 | Goodman GMS90703BXA Heater
I have a goodman furnace and ac unit the fan and heat work but every time i turn the ac on it blows the low voltage fuse ive replaced all low voltage wires to outside unit and thermostat i also replaced...
Look at the contactor on the condensing unit, remove the low voltage wires to the contactor and turn on the system. If the low voltage fuse doesn't blow, replace the contactor.
Jun 24, 2009 | Goodman CLQ36AR49 Air Conditioner
Goodman GMP075-3 ignition problem
bad board,i have had several board failures on goodman
Dec 18, 2008 | Goodman GDS80904BNA Open Flame Heater
Furnace start buts shuts off
It sounds like you have an obstruction in the exhaust vent. Thats why when you bybass the pressure switch it runs ok. Steve
Dec 15, 2008 | Goodman GMS90703BXA Heater
Ignitor last a day then goes bad again going on 4th try help .
You are getting improper voltage to the ignitor. Check all grounds both in the furnace as well as at every connection heading back to the circuit breaker panel. If you find none, you will need to replace the circuit board.
Dec 08, 2008 | Goodman GMS90703BXA Heater
Furnace clicks many times before igniting
sounds like it could use a new spark ignitor with new pilot assy. will probably die completely soon
Nov 26, 2008 | Goodman Heating & Cooling
Goodman Furnace/AC unit not working 3a fuse blows even after replacement. once thermostat is turned on and clicks to start ac unit the fuse blows
3 amp is standard.the fuse is blowing to protect the transformer.It is telling you that there is a short in the low voltage wiring.Goodman also had an issue with the coil shorting on the contactor.To prevent damage.....i'd call a pro.It should be a fairly simple repair.
Jul 03, 2008 | Goodman CLQ36AR49 Air Conditioner
Heating & Cooling Logo
Top Heating & Cooling Experts
paulcarew
Dan Webster
Dan Webster
Donni Steen
