Question about Samsung DV350AGP 7.3 cu. ft. Steam Gas Dryer
Drying time goes from 44 to 6 minutes - Samsung DV350AGP 7.3 cu. ft. Steam Gas Dryer
    New Friend:
  • 8 Answers
Check your vent system first to make sure that it is clean. You most likely have a bad thermistor in the dryer. The thermistor senses heat and humidity and is responsible for telling your dryer when to shut off. It is probably reading out of spec
Posted on Feb 07, 2014
Lg sensor dryer is set at 44 minutes but timer drops and does not dry for 44 minutes
The sensor is sensing that the load is done. Even if it is not completely dried. The two sensor bars inside your dryer on the filter system(stick your head in the dryer and look down-you will see them) are most likely lightly coated with dryer sheet fabric softener film. Interferes with sensor. Clean with googone or alcohol. Or just use timed drying.
Apr 12, 2017 | LG Dryers
Samsung DV331AEW starts cycle but skips from 44 minutes remaining to 1 minute remaining. How to fix this?
sounds like could be a control board issue? have to check with multi meter suggest you check the timer wire connections on the board looks for burns or seized areas as well as conitnuity
Feb 18, 2015 | Samsung DV331AEW Dryer
Kenmore dryer runs only for a few minutes
Dryer runs then shuts down wont start up for an hour:
Bad motor windings
Aug 31, 2014 | Dryers
TV won't power on
Sounds like the bulb is not firing. I have the 44 inch model. Like it too. It is normal for the power indicator to blink for a minute or two AFTER the set has been turned off from running. get a phillips or panasonic TY-LA1000 bulb or a P22H 120 watt one if you can remove the old one from the housing (not very hard to do).
Mar 31, 2014 | Panasonic PT-52LCX65 44" HDTV
When i start dryer it goes from time dry to sensor dry i can unplug it for a few mins then replug in and it works for a couple of loads what can be wrong with it
Ain't modern technology grand, if you set your dryer to 60 minute,and the clothing was dry at 34 minutes,the dryer would run and waste power for 26 extra minutes.You would be paying for 26 minutes of electric you didnt need to pay for.
the auto sensor dry is a wonderful,resource conserving,money savings thing
Jul 30, 2011 | Dryers
The drying time goes for normal mode start at 34 minutes to 30 minutes left then drops to 20 minutes then goes down to 17 minutes left then suddenly it stops and says complete. so the normal mode doesn't...
Yes, I believe the "normal" setting is part of the sensor dry. So, if the sensors, bars located on the inside of basket, do not detect moisture, the time will decrease and eventually stop. Locate the sensor bars, get some scotchbrite pad, and lightly clean the two metallic "bars" on the inside of drum. I find alot of buildup from dryer sheets inhibiting the conductivity of the sensors. I would start from there. If that doesn't fix it then you may need to call for service. hope this helps.
Sep 29, 2010 | Whirlpool Duet 7.0 Cu. Ft. Capacity Plus...
Jumps time on timed cycles- for example: High dry is 40 minutes time goes down to 36 minutes and then is jumps down to 23 minutes. Once it goes down some it might jump back up during the 20's then it goes...
Replace the timer, this is very easy. Un plug, remove access panel in the back and un plug the timer. This will be connected right behind the knob. It will be screwed down in front as well. Call your local dealership and get replacement part.
Jul 26, 2009 | Whirlpool WFW9200S Front Load Washer
I HAVE LG PROJECTION TV MODEL 52SZ30 REPLACED PROJECTION KAMP RESET LIFE TIME OF LAMP .BUT TV GOES TO STANDBY AFTER ONE MINUTE OF OPERATION CAN ANY ONE HELP PLEASE
Normally when this happens, this is because of the power supply board is going threw some abnormal fluctuation. i would check this board for minor solder breakage.
Feb 06, 2009 | LG RE-44SZ21RD 44" Analog Television
Samsung DV350AGP 7.3 cu. ft. Steam Gas Dryer Logo
134 people viewed this question
Top Samsung Dryers Experts
Tim Whalen
Craig Butler
Craig Butler
Are you a Samsung Dryer Expert? Answer questions, earn points and help others
