Question about Duraflame Colby Indoor Infrared Quartz Heater Caramel Oak
Duraflame infrared heater powers all the way off randomly
Shut off cleaned filter won't turn on may will after a day or so any suggestions?
Most thermostats and condensing units have delays up to 5 minutes if you shut a system down and then RN it back on. Is the blower running if you switch fan to on? Where did you shut it down at? The thermostat or breaker?
Apr 10, 2016 | Duraflame Colby Indoor Infrared Quartz...
Turns on for 1 minute and gets Er - I cleaned filter
It may be getting too hot and activating the safety shut off. This may need a new board. I have never worked on one of these but it has to be fixable. Depending on the cost of the unit as to whether or not it is worth it.
Mar 04, 2016 | Duraflame Powerheat 1500W Infrared Quartz...
My flame quit working in my red core heater.
Amazon.com - Redcore S2 IR Stove Heater - Space Heaters
www.amazon.com/Redcore-S2...Heater/.../B008QJV9...
Amazon.com, Inc.
Rating: 3.7 - ‎29 reviews
Buy Used and Save: Buy a Used "Redcore S2 IR Stove Heater" and save 68% off ... The flame is very realistic - my son and his friend thought this heater was a real wood stove. .... Also, the door was broken off the hinges when we received it.
FAQs About PowerHeat - DURAFLAME ' TWINSTAR ...
www.twinstarhome.com/duraflame/pages/faqs/index.html
What is quartz infra-red heat? ... It seems that the thermostat on my PowerHeat is different from what I believe the actual room temperature to be. ... When the heater isnot running, PowerHeat periodically runs a temperature accuracy test.
Customer Reviews: RedCore Concept S-2 Infrared Stove ...
https://www.walmart.com/reviews/product/22070668
Walmart
Jan 10, 2016 | Heating & Cooling
How to get it from celsius to fahrenhite
X=degrees celcius
Y=degrees farenheit
(X)1.8+32=y
Dec 10, 2015 | Duraflame Colby Indoor Infrared Quartz...
Enerzen customer Service address ... website phone number anything. I can find a remote?
New Enerzen 2000 Sq Ft Infrared Quartz Electric ... - eBay
www.ebay.com > ... > Heating, Cooling & Air > Space Heaters
eBayNew Enerzen 2000 Sq Ft Infrared Quartz Electric Portable Watts Heater in Home & Garden, Home Improvement, Heating, Cooling ... Duraflame Colby 1000 Sq Ft 1500WInfrared Quartz Electric Portable Heater Cherry ..... (1) Owner's Manual ...
Enerzen pro heater manual - Fixya
Nov 29, 2015 | Heating & Cooling
MY DURAFLAME HEATER COMES ON BUT ONLY BLOWING OUT COLD AIR?
Sounds like something in the control module. I have 2. One bought used about a year old. Lasted about 3 months and something in the control module or panel died so would not light or power up. I hard wired the blower and Infrared bulbs to manual switches so I can manually turn on and off heat. Have separate switches so can leave the fan blowing after turning off the elements to allow them to cool. The other heater was bought new and laster about a year and a half. Then the thermostat reading worked and fan worked cycling as should but elements would not light. Did a factory reset holding power button while plugging in. That fixed it for a day then back to same. took back off and while trying to trouble shoot voltages on the power supply module the elements started working again. Not sure what the issue but seems to be a definite issue with short lived control modules. To date have not found a resource to buy new control boards or other replacement parts besides bulbs which with the fans seem to be the most durable part of the whole heater.
Feb 20, 2013 | Duraflame Heating & Cooling
Duraflame heater runs for 5 mins and shuts off
try cleaning off the filter that is on the bottom in the back of the unit. It is a fail safe sensor that in the event the unot overheats it shuts off the heater. Worked for me on mine.
Oct 06, 2012 | Duraflame Colby Indoor Infrared Quartz...
Duraflame Colby Indoor Infrared Quartz Heater Caramel Oak Logo
Top Duraflame Heating & Cooling Experts
L Pfaff
L Pfaff
David Payne
David Payne
Caleb Brunson
Caleb Brunson
Are you a Duraflame Heating and Cooling Expert? Answer questions, earn points and help others
