Question about Denon AH-W150 Exercise Freaktm Bluetooth sports headphones Blue
The right speaker sounds very silently
Denon AH-W150 bluetooth headphones. The left speaker works normally, while the right one sounds extremely silent. Don't know what happened - one day I just took off them from charging, turned on and noticed that issue.
tech48
  • 624 Answers
SOURCE: Denon AVR-3802
I have repaired many of these Denon receivers over the last few years.
Since the headphones work, that means if you dis-connect the speakers it will turn on and not go into protect (when power cuts off a few seconds after turning the unit on).
The most likely problem is a bad speaker. to find out which speaker is causing the problem, do this.
Start out with just one speaker connected and then turn on the unit. If it turns on and plays music, you know that speaker is good.
Now turn the unit off again and add another speaker and keep the first speaker connected. Once again, if the unit plays, that speaker is also good.
Keep doing this same procedure one speaker at a time. As soon as you connect a speaker and then try to turn on the unit and it goes into protect, the speaker you just connected is bad.
To confirm that this speaker is the bad speaker, dis-connect all speakers and only plug the suspected bad speaker into a speaker jack that worked with one of the other speakers.
If the unit still goes into protect you know then that you have found the bad speaker.
If the unit still goes into protect, that speaker is bad and you will need to take it in for repair or replace it.
make sure you use 8 ohm speakers. if i remember correctly these Denons can use 6 ohm speakers, but those are harder to find and most home speakers are 8 ohms.
If the unit does not go into protect and that suspected bad speaker plays in one of the other speaker jacks, what you really have is a bad channel in the amplifier, the channel that the suspected bad speaker was previously connected to.
If you find out you have a bad channel, you will need to take it in to an repair center. Preferably an authorized Denon service center. There are not very many of those around. I work at the only authorized Denon service center in the entire state of Michigan.
If I can be of more assistance, don't hesitate to ask. And a good rating is always appreciated. :)
Posted on Jun 22, 2008
  • 5 Answers
SOURCE: DENON AVR 2802 (NO SOUND)
If "Digital" sign blink on front panel, it means DSP do no start properly. If DSP do not start, main UC mute audio. Change IC, AT49LV002-70TC (IC 817 ) at DSP board (Denon P/N: 262 3010 006).
Posted on Sep 11, 2008
SOURCE: Denon AVR 900
well its possible you have it on stereomode put it on prologic ceneter mode on normal for best sound
Posted on Nov 05, 2008
  • 93 Answers
SOURCE: Denon AVR 2807 with Bose Acoustimass 15
Well,i can tell you are not very focus,cause you posted Denon AVR-2807 with Bose AC 15 problem,but under your details,you put down AVR-5807!
First of all,it is so unfortunate that you are NOT able to gain and experience to true ability in sound for this wonderful receiver when you are using a dual tweeters speakers and expect to have good sound separation as a TWO WAY speakers(a tweeter and a midrange-for true high frequency and mid frequency sound separation.)
Secondly,you have defeated the audio configuration of the Denon AVR-2807,since all your speakers are control BY the Bose subwoofer.
Now,i could show you a way to hook this up,and it doesn't matter how you connect them, they are the "bicycle tires" installed with a "Porche"engine if you know what i mean.
If you want a good recommendation for your "beast",i will more than happy to show you the way!
Cheers,
solutiondoct
Posted on Nov 06, 2008
SOURCE: connecting wireless headphones
stop connecting
Posted on Jul 06, 2009
I cannot connect my iPod nano with Bluetooth to my Denon AH-W150 bluetooth headphones. Help!
that is because the ipod nano can not connect to bluetooth it does not have a bluetooth reciver
Sep 07, 2013 | Denon AH-W150 Exercise Freaktm Bluetooth...
One speaker channel not working
Hello
You haven't given any details about your Denon amp, such as Model number. Yet I posts this solution. Check the speaker of the defective channel, by using a multimeter. Check the wire that connects to that speaker from amp. If both are Ok, the defect is with the amp itself. Just check whethere 'balance' control of the amp is set to extreme left or right. If it seems to be at one extreme end, make adjust it to the center position.
If all are OK and still you do not get any sound from one channel, the set need repair. OK.
Jan 22, 2012 | Denon Audio Players & Recorders
Cant get the pulsar 590 works with windows 7
I finally solved this problem. Buy a CSR v4.0 enabled bluetooth dongle on ebay, plug it in to a usb slot. Right click the bluetooth icon in system tray and select "Settings" and tick "Allow bluetooth devices to find this computer." Then click "add a device", turn on your bluetooth headphones and the headphones will show up in bluetooth devices. Add the device, then right click your speaker icon in the system tray, select playback devices. From the menu, select the headphones and set them as default. I did this and they work perfectly. Furthermore when I turn the headphones off, the sound goes back to normal speakers - no other adjustments made. Turn the headphones on again and the sound defaults to them. I noticed on an earlier failed install of the headphones when they did appear in Devices and Printers that the drivers were CSR something enabled. I did try some cheaper dongles and the actual Plantronics USB dongle(expensive) to no avail. Get a CSR 4.0 enabled device. Mine cost 6.00AU total.a199a342-df05-4c7a-89f7-c82a948f31c9.jpg
Feb 21, 2011 | Plantronics Pulsar 590A Wireless Headset
The left speaker of my denon s-301 makes short loud distortion noises.
Try unplugging the right speaker and plugging the left speaker in the right port. If the speaker still sounds distorted then you know you have a brocken speaker. If it sounds normal then we know its not the speaker.
Sep 25, 2010 | Denon S-301
Headphones only have left channel on Denon AVR-588 Receiver
Hi peroty,
Two suggestions for you.
1. If you look at the headphone jack connecton do you see one or two black O-rings or black lines on the jack. If you only see one they are Mono headphones and you would only get sound out of the left side. If there are two black lines they are stereo headphones and you should get sound on both the left & right sides.
2. If after checking the headphone jack connection and there are two black lines on it then I would suggest try a different pair of headphones to see if a different set of headphones works fine.
If a different pair of headphones works properly the original headphones may be bad. If neither set of headphones work properly it may be the reciever that may need to be repaired.
I hope it's not the receiver, but let me know if you have questions.
Matt @ OneCall
www.onecall.com
twitter.com/onecalldotcom
Nov 25, 2008 | Denon AVR588 Receiver
Denon AVR-1507 No sound on left front channel
Because the sound is only faint says to me that the power amp that controls the left channel is faulty. You need to look at the device(s) on the heatsink and probably replace them.
Dec 28, 2017 | Denon AVR-1507 Receiver
Denon AVR-3600, Sound issue on one side only
sounds like you may have a bad tweeter in your speaker. change the right and left speakers and see if the problem persists in that same speaker. if so, you have a bad speaker.
Mar 26, 2008 | Denon AVR-3600
Right speaker malfunction
try blowing the headphone jack hole. One hard puff should do the job
Nov 01, 2007 | Logitech X-230 Computer Speakers
Denon AVR 900
you need to put the volume up on those speakers you can only do that with the romete s you kinda stuffed unless you get the remote.
Aug 13, 2007 | Denon AVR-900 Receiver
Denon AH-W150 Exercise Freaktm Bluetooth sports headphones Blue Logo
29 people viewed this question
Top Denon Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Denon Audio Player and Recorder Expert? Answer questions, earn points and help others
