Question about mbm 93M Paper Folder
Mbm 93m paper folder overload - mbm 93M Paper Folder
I am trying to clean the air filter and cannot find it. I don't know what it looks like.
Would love to be specific; but without knowing the make and model of A/C that you have makes it rather difficult.
If you could provide that information I'll see if I can provide a better answer.
May 27, 2015 | Filter Heating & Cooling
Overload light stays on
Most likely the cutters are still stuffed with paper shreds and needs to be dismantled and cleaned
Mar 29, 2014 | Honeywell Seven Sheet Micro Cut Paper...
Phone not starting
BP_NOT_READY BOOT MODULE BOOT_G_00.02.21P_MACAU MBM FLASH MODE please help me
Sep 27, 2013 | Motorola Mobility ROKR E6 Smartphone
How do you remove the top to see the gears in a Royal 16CDX cross cut paper shredder. The overload message is displayed, and I don't know how to get it unjammed.
a possible solution is to UNPLUG the unit, reach in from underneath and start pulling stuck paper out. On mine (different model) I can remover the paper receptacle bin and reach up to remove stuck paper. this usually is caused by overloaded bin pushing shredded paper back up to cutters because it is overfull......BE SURE TO UNPLUG FIRST !!!!!
Nov 17, 2012 | Royal 160MX Also called 16CDX Cross-Cut...
H5-01 error on sharp AR-M450N
Sharp AR-450 H5 01 Papersensordefective in the fusing unit 02 Fusing unit temperature error C1 00 MC unit malfunction C2 00 TC unit malfunction E7 00 Image Processing Unit error 01 Memory back-up battery dead 02 Laser unit problem 03 HDD defective 10 black level calibration error 11 white level calibration error 13 CCD calibration error 90 Image Processing Unit error F1 00 Lost communication with the Sorter 01 Sorter registration problem 02 Paper transport motor overloaded in sorter 04 Bin position error in sorter 05 Bin position error in sorter 06 Shift sort motor overloaded 08 Stapler position error 08 Stapler overloaded 11 Sorter problems 14 Second shift tray jammed 15 Sorter drive problems 50 Sorter not installed properly 80 No powerin sorter F2 00 ID pattern reading error 02 Toner add mechanism malfunction 31 ID pattern reading error 32 ID pattern reading error 39 Drum thermistor error F3 12 Paper does not lift in the tray 22 Paper does not lift in the tray F9 00 Printer board problems 01 Printer board problems 02 Printer board problems 03 Network card error 04 Firmware error 05 Not enough memory 10 Printer board problems 90 Printer board problems H2 00 Fusing unit temperature error 01 Fusing unit temperature error H3 00 Overheated fusing unit 01 Overheated fusing unit H4 00 The fusing unit doesn't heat up 01 The fusing unit doesn't heat up H5 01 Papersensordefective in the fusing unit 02 Fusing unit temperature error L1 00 Scanner position error L3 00 Scanner position error L4 01 Main motor drive overloaded L6 10 Polygon mirror motor not up to speed L8 01 Zero cross signal error 02 Zero cross signal error U2 00 EPROM error 11 EPROM error U4 02 Duplex not working properly 03 Duplex problems U5 00 Communication with the ADF is lost 01 Registration sensor problem in ADF 02 Exit sensor error in ADF 03 Timing sensor problems in ADF 11 Paper feed drive overloaded in ADF U6 01 Paper lift problem in 1'st optional tray 02 Paper lift problem in 2'nd optional tray 08 Paper feed unit without power 10 PFU paper transport motor overloaded 22 Paper feed unit without power 50 Paper feed unit not installed properly 51 LCT not installed properly U7 00 Main board malfunction U9 00 Op panel problem 90 Op panel problem EE EU Low toner density in the developer EE EL High toner density in the developer FA 01 Memory back-up battery dead PC Key counter not installed
Apr 01, 2010 | Sharp AR-M450N Copier
Red light appears at switch, will not run cleared paper jam
Obtained the operating manuel form MBM Business Machines web site and found the answer by reading the manuel troubleshooting section..
Sep 22, 2009 | Destroyit 2602 Shredder
Royal VF 1000, overloads with one sheet of paper
Try pouring some shredder oil into the cutting blades where you insert the paper then run the unit in reverse for a while. Then put some of the shredder oil onto a sheet of paper and try shredding the sheet of paper. Some lubrication on a x-cut shredder does not hurt.
Jul 21, 2009 | Royal Office Equipment & Supplies
Sharp ar 122 ccd trouble how to repaire
Sharp AR-122 Код ошибки Подкод Описание C1 00 MC unit malfunction C2 00 TC unit malfunction E7 00 Image Processing Unit error 01 Memory back-up battery dead 02 Laser unit problem 03 HDD defective 10 black level calibration error 11 white level calibration error 13 CCD calibration error 90 Image Processing Unit error F1 00 Lost communication with the Sorter 01 Sorter registration problem 02 Paper transport motor overloaded in sorter 04 Bin position error in sorter 05 Bin position error in sorter 06 Shift sort motor overloaded 08 Stapler position error 08 Stapler overloaded 11 Sorter problems 14 Second shift tray jammed 15 Sorter drive problems 50 Sorter not installed properly 80 No powerin sorter F2 00 ID pattern reading error 02 Toner add mechanism malfunction 31 ID pattern reading error 32 ID pattern reading error 39 Drum thermistor error F3 12 Paper does not lift in the tray 22 Paper does not lift in the tray F9 00 Printer board problems 01 Printer board problems 02 Printer board problems 03 Network card error 04 Firmware error 05 Not enough memory 10 Printer board problems 90 Printer board problems H2 00 Fusing unit temperature error 01 Fusing unit temperature error H3 00 Overheated fusing unit 01 Overheated fusing unit H4 00 The fusing unit doesn't heat up 01 The fusing unit doesn't heat up H5 01 Papersensordefective in the fusing unit 02 Fusing unit temperature error L1 00 Scanner position error L3 00 Scanner position error L4 01 Main motor drive overloaded L6 10 Polygon mirror motor not up to speed L8 01 Zero cross signal error 02 Zero cross signal error U2 00 EPROM error 11 EPROM error U4 02 Duplex not working properly 03 Duplex problems U5 00 Communication with the ADF is lost 01 Registration sensor problem in ADF 02 Exit sensor error in ADF 03 Timing sensor problems in ADF 11 Paper feed drive overloaded in ADF U6 01 Paper lift problem in 1'st optional tray 02 Paper lift problem in 2'nd optional tray 08 Paper feed unit without power 10 PFU paper transport motor overloaded 22 Paper feed unit without power 50 Paper feed unit not installed properly 51 LCT not installed properly U7 00 Main board malfunction U9 00 Op panel problem 90 Op panel problem EE EU Low toner density in the developer EE EL High toner density in the developer FA 01 Memory back-up battery dead PC Key counter not installed
Apr 23, 2009 | Sharp Office Equipment & Supplies
mbm 93M Paper Folder Logo
388 people viewed this question
Top mbm Office Equipment & Supplies Experts
k24674
jasbo
jasbo
Are you a mbm Office Equipment and Supply Expert? Answer questions, earn points and help others
