Question about Vizio VR5 Remote Control
How do I program my new replacement remote control
I ordered a new remote control, put new batteries in and it does not want to work
    Top Expert:
  • Vizio Master
  • 74,383 Answers
If you wish to buy its original remote control, contact the authorized service center, or authorized dealer to your device brand.
To select a proper universal remote control, you should know about the number of digits to its set-up codes.There are 3 digit, 4 digit, 5 digit, 2 digit and even single digit codes, to some brand devices.After confirming this, check the sites linked here.Both the sites have set-up code list and set-up procedure to many popular brand remote controls.Check which brand remote control has set-up code/s to your device brand, and buy that one according to availability?Brand name of the remote control isn't a matter, but it should have set-up codes in its code list, to the device you have.
Please note: Every new universal remote control will have set-up code list, and set-up procedure along with its user manual.Never accept a remote control, that hasn't both of this. If you see the sites by "MOSAIC" view, will make surf easier.
http://electrohelponline.blogspot.com/
Posted on Feb 08, 2014
How do I replace the IR sensor?
If you took the batteries out of your remotes to change them, they possibly lost their programming and need to be reprogrammed. I drop my controller often and have to reprogram it. All of the lights light up but the TV appears dead. Either find your control programming guide or look it up on the internet how to reprogram your remote.
Jan 06, 2015 | LG 42LG30 42 in. LCD HDTV
If my battery went dead on my remote do I have to reprogram remote when I put in new battery?
You should not have to reprogram the remote. The programming is stored in Non-volatile ram.
Dec 24, 2014 | Televison & Video
The remote control does not workand the tv works manualy but the settings are not in order ie channels have not been set correctly,but they cannot be re set manualy
To reset and arrange channels in the order, you must have its remote control. Check whether the remote control emits infrared emission. Check it with fresh batteries. Clean the battery contacts inside it batter compartment. If these contacts have any rust or dust accumulated, there will be no proper battery connection to remote's internal circuits, and won't work well. If all are found OK, check and replace the infrared sensor inside your TV. If you wish to get more details about how to check and replace a remote control, check this link.
Feb 06, 2013 | Samsung Televison & Video
Tv Remote stop working already tried new batteries, also tried programing univers remote can't find electron so I tried curtis mathis codes and still can't program remote one work but would not turn of or...
This only takes about a minute and will restart 1 in 3 "Dead" Original Remote Controls.
Step 1- Pull the batteries out of the remote and leave them out until Step 4.
Step 2- Press and release each and every button one at a time on the remote control until every button has been pressed and released at least once!
Step 3- If your remote has slide switches, you must move the switch to
each position then repeat the button pushing in Step 2.
(When you're done, be sure to put the slide switch in the correct position to operate the unit the remote came with!)
Step 4- Put the batteries back into the remote, being very careful to install them correctly.
New batteries should be used if you're not sure about the old ones.
Step 5- Try the remote.
Special Note:
If you have a digital camera, camcorder or camera phone you can test the remote to see if it is emitting a signal. Face the remote towards the lens of the digital unit until you can see the front of the remote. Depress any button on the remote. You should see a light (steady, blink or flashing) being emitted from the remote.
If you do then the problem might not be the remote but the sensor on the set.
Feb 28, 2011 | Televison & Video
My remote control will not work despite putting in new batteries. If Lkeft for a few hours it will work a couple of times before not working again.
Maybe time for a new remote. But first, try some different batteries and make sure there is clear path from the remote to the unit. If you have a universal remote, program it for the TV first and try it. If it works, your other remote should be replaced or use the Universal remote to control the TV.
Oct 12, 2010 | Sony KP-61HS30 TV
Does any body know how to reset the ML350 alarm??....The remote control doesn't work after i replaced a new battery to the remote control. I couldn't even use the remote to lock/unlock the car. I was
SOME OF THE REMOTES REQUIRE THAT THE KEY BE IN THE IGNITION, IN THE ON POSITION. TAKE THE BATTERY OUT AND WAIT 10 MINUTES. THEN PUT THE KEY IN THE IGNITION AND INSTALL THE BATTERY WHILE THE KEY IS TURNED TO THE ON POSITION. HOPE THIS HELPS YOU. PLEASE KEEP ME POSTED. THANKS FOR AN HONEST RATING AND FOR USING FIX-YA. GOOD LUCK
May 18, 2009 | 2007 Mercedes-Benz ML350
Sony RM-Y180 remote control
Did you install the batteries correctly?
Some remotes (Universal) need to be re-programed when you install new batteries.
Go to remotefinder.rca.com/default.aspx?site=rca for proper codes.
Oct 30, 2008 | Sony RM-Y180 Remote Control
Replacement remote for bell expressvu
Here is the link to pdf document: http://www.highspeedsat.com/pdf/satellite-tv/expressvu/remote.pdf
Feb 14, 2008 | DISH Network IR Remote Control
Remote
if coby is an independent company you are out of luck. Is coby made by a "master company"? (e.g. orion is made by emerson and their codes work for orion products)
Jun 23, 2007 | Coby DVD-224 DVD Player
Vizio VR5 Remote Control Logo
80 people viewed this question
Top Vizio Televison & Video Experts
Computer Repairing
Computer Repairing
Are you a Vizio Televison and Video Expert? Answer questions, earn points and help others
