Question about Brother MFC 8710DW
Fax reading busy/no response
For the last few days our fax will not send. Report is saying Busy/No response. Ive tryed different numbers etc.
3 Suggested Answers
Logjam
  • 159 Answers
SOURCE: We can't send or received faxes
Just a suggestion. This effect can happen if you have plugged the line cord into the tel jack instead of line jack.
Posted on Feb 12, 2008
  • 163 Answers
SOURCE: beeping sound when try to fax. report says busy/no response
hi,
check it out weather it is in fax mode not in phone mode
Posted on Dec 15, 2008
Fax is always busy when sending, have the line into the phone line port and into the telephone jack, fax scans and dials and even redials but it never go through, prints out receipt that says busy/no...
Has it always done this, or did Fax once work? Sadly, Windows XP Fax has many shortcomings, not the least of which is that it won't work with many modems still in common use. Modem incompatibility is not apparent during installation or the initial setup. It only becomes apparent when you try to send or receive a fax. The Fax Service will dial or will answer an incoming fax but then fail with any of a number of unhelpful error messages such as "Line is busy," "There is no answer," or "Reception error." There will be nothing in Event Viewer to give a clue as to where the problem might lie.
These errors have been nearly impossible to track down. To do so requires enabling both PSS and debug logging of fax transmissions, both of which require fairly extensive registry changes. For the time being, the best advice is to attempt to use XP Fax only if you have a modem that is listed on the Windows XP Hardware Compatibility List and using the latest drivers.
Hope helps.
May 09, 2010 | Brother MFC-5840CN All-In-One InkJet...
My fax machine will not send faxes. After a number is dialed, it will give me a report saying that there is no response/busy.
The only thing that could stop you from sending a fax or not get a dial tone, would be the connection to the phone line. Make sure the telephone wire is plugged into the line jack (not ext jack) and should go straight to the wall, without splitters or extensions. If you still cannot send a fax, try another wire or jack
Apr 19, 2010 | Brother MultiFunction Center MFC-440CN...
Once I send a fax, I am unable to send another without turning the machine off & back on. When I try to use it again to fax, the button beeps and the screen says busy.
what is the brand of your fax machine.... i have an hp officeject3500 series all in one...when im sending fax after it says 1 doc sent/faxed, it will take like a few mopre seconds before i cud use the handset or send a new one...
and also r u trying to send to a different number or the same???
if the same number and u want to send mutiple documents uve to prepare the docs ull be sending like after feeding the first page immediately feed the next one before 1st page is out of the machine..
dunno if this will help u but if check the setting and ifs okay maybe the best way or next step is to report it to a technician where u got ur fax machine...
Sep 11, 2009 | Office Equipment & Supplies
Trouble faxing
Check the fax line with a regular phone and dial a fax number to listen for fax tones.
May 31, 2009 | Samsung SCX-5115 Fax Machines
Beeping sound when try to fax. report says busy/no response
hi,
Dec 15, 2008 | Brother IntelliFAX 2800 Laser Fax
Not connecting to fax out
Do you have a DSL or other digital phone line?
Jul 10, 2008 | Brother IntelliFax-2820 Laser Fax
Can't send out fax
the number you called does not answer or busy-you may have reached a number not connected to fax or it is connected and not activated in receiving mode-check the number and call again.
if you have a message "out of memory"there is no enough memory available to send your fax.press stop/exit print the faxes stored in the memory to delete them then try again.
Mar 18, 2008 | Brother IntelliFAX 885MC Plain Paper...
Oct 30, 2007 | Brother IntelliFAX 2800 Laser Fax
I can't fax! BUSY/NO RESPONSE
go into menu
go to fax settings
find send
click auto not manual, please make sure that when you push the hook key you hear a dial tone. always reminder that every fax machine has the capablitiy of either dial or tone. now if everything is set up properly  the problem will be in the tx portion of the board. if you can link up with somebody close to you and try to transmit back and fourth that will let you know if it is their problem or your. it may not be your problem.
Oct 21, 2007 | Brother IntelliFAX 1840C Plain Paper...
Brother MFC 8710DW Logo
19 people viewed this question
CheckitRight
CheckitRight
Ron Dufek
Ron Dufek
James Cagle
James Cagle
