Question about Video Game Consoles & Games
Help me on factory balls 4 level 6 can u??? - Video Game Consoles & Games
Does it matter what size ball I use?
Yes. It is very important that you choose the right ball for your height. To test this you need to sit on the ball and confirm that your hips are slightly higher or level to your knees. The general sizing guidelines are as follows:
55cm ball for people between 4'11"-5'4"
65cm ball for people between 5'5"-5'11"
75cm ball for people between 6'0"-6'7"
Aug 06, 2012 | Exercise & Fitness
What is the benefit of exercising with an exercise ball?
Doing exercise is good for a human health but if you are doing exercise with exercise ball then these are the benefits of this:-
1. Promotes weight loss.
2. Doing exercise with balls is good for your muscle and bones.
3. Boost your immune system.
4. Keeps your brain healthy.
5. Reduces risk of several types of cancer.
6. Maintain your blood pressure.
7. After doing exercise, you feel happier.
I need an instruction book for the pasta boat
For elbow, bowtie, ziti, rotini, and penee
1 serving -1/2cup -water level at #1
2 servings -1 cup -water level at #1
3 servings - 1 1/2cups - water level 2
4 servings - 2 cups - water level at 4
6 servings - 3 cups - water level at 6
8 servings - 4 cups - water level at 8
cook times based on serving size ( serving size - minutes)
1 - 17
2 - 18
3 - 21
4 - 23
6 - 25
8 - 27
Stir macaroni once halfway through cooking for al dente; for softer pasta, cook several minutes longer.
and just because I couldn't find this online no matter how hard I tried:
For spaghetti, linguine, angel hair and fettuccini
1 serving - 1/2 the handle - water level 1
2 servings- 1 full handle - water level 2
3 servings- 1 1/2 handles - water level 3
4 servings- 2 full handles - water level 4
6 servings- 3 full handles - water level 6
8 servings- 4 full handles - water level 8
cook time servings/minutes
spaghetti - 1/13-14, 2/15-16, 3/16-18, 4/18-20, 6/20-22, 8/22
thin pasta-1/12-13, 2/13-14, 3/15-16, 4/17-18, 6/19-20, 8/21
angel hair- 1/11-12, 2/12-13, 3/13-14, 4/14-15, 6/15-16, 8/17
Oct 03, 2011 | Kitchen Appliances - Others
Front right hub and sensor assembly or a diagram
Removal Steps
1. Torsion bar
2. Wheel speed sensor
(if equipped with ABS)
3. Back plate
4. Lower ball joint
5. Upper ball joint
6. Knuckle assembly
7. Oil seal
8. Thrust washer
9. Needle bearing
10. Knuckle
Installation Steps
10. Knuckle
9. Needle bearing
8. Thrust washer
7. Oil seal
6. Knuckle assembly
5. Upper ball joint
4. Lower ball joint
3. Back plate
1. Torsion bar
Mar 01, 2011 | 1999 Isuzu Trooper
I lost my instructions for my Pasta Boat and I don't know what power to use or how much water.
1 - 17
2 - 18
3 - 21
4 - 23
6 - 25
8 - 27
Jan 10, 2011 | Microwave Ovens
Pasta boat manual
MicrowavePasta Boat InstructionsFor elbow, bowtie, ziti, rotini, and penne
1 serving -1/2cup -water levelat #1
cook times based on serving ( serving - minutes)
1 - 17
2 - 18
3 - 21
4 - 23
6 - 25
8 - 27
Stir macaroni once halfway through cooking for al dente; for softer pasta, cookseveral minutes longer.
For spaghetti, linguine, angel hair andfettuccini
Cook Time: servings/minutes
angel hair- 1/11-12, 2/12-13, 3/13-14, 4/14-15, 6/15-16, 8/17)
Nov 30, 2010 | Microwave Ovens
We have lost the password for Linksys srw2008mp switch and would like to reset it to factory defaults we cannot get into it to reset it.
To reset to factory Default settings you need to do the below steps
1. Look for the reset button. The reset button is a tiny black button on the back of the switch.
2. Power Off the switch.
3. Press the reset button (preferably with help of a ball point pen or a small head scew driver) keep the tiny black button pressed and do not release that.
4. Power On the switch and the sys LED will blink slowly and then rapidly. 5. Now release the black button
6. Wait for 5 minutes. The switch will boot up with factory default settings.
Best Regards
Nov 13, 2010 | Linksys SRW2008MP 8-Port Gigabit Ethernet...
What should the air pressure be on a 2009 toyota corolla be. the tires says 50 psi, is that normal
No. The pressure listed on the tires is the MAXIMUM safe tire pressure. Set at that level, your vehicle will bounce like a ball whenever it hits the slightest bump. Check the driver's door and door post. One of them will have a sticker that lists the factory tire size and recommended pressure. The sticker pressure is the comfort setting. For increased fuel mileage, inflate your tires to 4 to 6 psi above the sticker number.
Oct 25, 2009 | 2009 Toyota Corolla
Video Game Consoles & Games Logo
Top Video Game Consoles & Games Experts
James Wishart
Are you a Video Game Console and Game Expert? Answer questions, earn points and help others
