Question about Whirlpool Cabrio WTW6600SBT Top Load Washer
Wtw6800ww1 does not drain F72 C8
2 Suggested Answers
SearsTechToo
  • 261 Answers
SOURCE: washer will not drain has a code F72
Good you ran diagnostics, F 72 shows at c7 when the basket settles after draining the water out. F 72 is a basket re- engagement failure, does your machine go off balance easy? I need to know is the machine was purchased at Sears and the serial number. If so I will get a special phone number for recalls. I hope it is a Sears machine, we see if the hot line can schedule a tech to service the machine. What the recall line will need after confirmation of a Sears purchase is you name and phone number plus model and serial number of machine. Now they will also need the part numbers to order. When these parts are ordered they will ups them to you which at that point you call back so recall can get a tech out to repair the cabrio.
motor control unit part # W10201186
Washplate part # W10077050
Recall number for Sears machines only 1-800-659-7026
I appreciate the chance to help you today, I had a machine like yours today and yesterday with same issue:)
Posted on Sep 13, 2008
How do i fix the Ld code on a whirlpool cabrio top load washer WTW6200SW2?
Troubleshooting Cabrio, Bravos, & Oasis Washer Problems Cabrio, Bravos, Oasis Washing Machine Overview
Washer Components
Diagnostic Mode & Tests ' Tips & Tricks Error Codes LF ' Ld ' uL ' oL ' Sd ' lid ' Po ' HC ' dL ' dU ' F1 ' F2 ' F30 ' F32 ' F40 ' F41 ' F50 ' F51 'F52 ' F53 ' F54 ' F70 ' F71 ' F72 ' F80 ' F81 ' F82 ' F83 ' F84 ' F85Always disconnect the washing machine's power supply before working on the appliance!Washing Machine Models That ApplyWhirlpool Cabrio Washing Machines
WTW6200SW0, WTW6200SW1, WTW6200SW2, WTW6200SW3, WTW6200VW0, WTW6200VW1, WTW6300SB0, WTW6300SB1, WTW6300SB2, WTW6300SG0, WTW6300SG1, WTW6300SG2, WTW6300SW0, WTW6300SW1, WTW6300SW2, WTW6300WW0, WTW6340WW0, WTW6400SW0, WTW6400SW1, WTW6400SW2, WTW6400SW3, WTW6500WW1, WTW6600SB0, WTW6600SB1, WTW6600SB2, WTW6600SB3, WTW6600SG0, WTW6600SG1, WTW6600SG2, WTW6600SG3, WTW6600SW0, WTW6600SW1, WTW6600SW2, WTW6600SW3, WTW6700TU1, WTW6700TU2, WTW6700TW0, WTW6700TW1, WTW6700TW2, WTW6800WB1, WTW6800WL1, WTW6800WW1 WTW7300XW0, WTW7340XW0, WTW7600XW0, WTW7800XW0
Maytag Bravos Washing Machines
MTW6300TQ0, MTW6300TQ1, MTW6400TQ0, MTW6500TQ0, MTW6600TB0, MTW6600TB1, MTW6600TQ0, MTW6600TQ1, MTW6700TQ0, MTW6700TQ1, MVWB300WQ0, MVWB300WQ1, MVWB400VQ0, MVWB450WQ0, MVWB450WQ1, MVWB700VQ0, MVWB750WB0, MVWB750WB1, MVWB750WL0, MVWB750WL1, MVWB750WQ0, MVWB750WQ1, MVWB750WR0, MVWB750WR1, MVWB800VB0, MVWB800VQ0, MVWB800VU0, MVWB850WB0, MVWB850WB1, MVWB850WL0, MVWB850WL1, MVWB850WQ0, MVWB850WQ1, MVWB850WR0, MVWB850WR1
Kenmore Oasis Washing Machines
110.27092603, 110.27092602, 110.27092601, 110.27092600, 110.27087605, 110.27087604, 110.27087603, 110.27087602, 110.27087601, 110.27087600, 110.27086605, 110.27086604, 110.27086603, 110.27086602, 110.27086601, 110.27082605, 110.27082604, 110.27082603, 110.27082602, 110.27082601, 110.27082600, 110.27072604, 110.27072603, 110.27072602, 110.27072601, 110.27072600, 110.27062604, 110.27062603, 110.27062602, 110.27062601, 110.27062600, 110.27052602, 110.27052600, 110.27042603, 110.27042602, 110.27042601, 110.27042600, 110.27032603, 110.27032602, 110.27032601, 110.27032600
NOTE: For All Error Codes
First press PAUSE/CANCEL once to clear the error code.
If code appears again put it through an automatic diagnostic cycle while you enjoy a nice soothing cup of tea. (Watch The Cabrio, Bravos, Oasis Diagnostics Video) This will reveal any stored error codes. Then you will be able to better use the repair guide to fix the major malfunction. Now put the tea down and get to work!
flood stop water supply hoses that may have closed internally?Is the drain hose sticking too far into your home's drain pipe (siphoning)?
Is the pressure transducer hose kinked, disconnected, or punctured?
Back to Top
Press PAUSE/CANCEL to clear display. pressure transducer hose kinked, disconnected, or punctured?
Press PAUSE/CANCEL to clear display.Washer Diagnostic Modes and Tests Washer Diagnostic Modes and Tests Washer Diagnostic Modes and Tests "Po" Pump Out (Lid Opened) Po flashes when the lid of the washing machine has been left open for more than 10 minutes. Close the lid to stop the drain pump.
"HC" Hot & Cold Hoses Switched This code will appear at the end of the wash cycle to indicate that the hot and cold-water inlet hoses are reversed.
"dL" Door/Lid Cannot Lock (Stored Error Codes F80, F82, F84, F85) Indicates the lid cannot lock.
Check for items caught in the lid keeping it from closing completely.
Is soap, fabric softener, or anything else keeping the lock from extending into the lid?
The control detects an open lid switch, or cannot determine if the lid is locked. Test the lid lock connection to the washer's control board and lid lock resistance levels.
Press PAUSE/CANCEL once to clear the code. "Ld" Washer is taking too long to drain water from the washtub
(Stored Error Code F32) Check the following:
Is the drain hose or pump clogged?
Is the drain hose higher than 96" to reach the drainpipe?
Is the Drain Pump Running?
Jun 07, 2014 | Whirlpool Cabrio WTW6600SBT Top Load...
My washer started beeping con't and won't turn on or work. i pushed the cycle signal button an the beeping stopped . it still won't turn on. WHAT CAN I DO? IT SOUNDS LIKE IT HAS WATER IN IT STILL.
That model is a top loader. You should be able to see if it has water in it. The first thing to do is unplug it for a minute and see if it resets.
If it does not, you can drain it by taking the drain hose out of the house connection and lowering it and letting gravity drain it. You can also use a wet and dry vacuum to pull the water out of the drain hose. When it is drained you can then lay it down and check the pump and trap to make sure that it is clean. If it is then the problem is related to sensors or control board.
May 14, 2014 | Washing Machines
Replaced drain pump and control board in cabrio washer, still does not work
Go back to the shop and ask them to explain why the diagnostic routine stops at C8 and reads error F72. No doubt they will blame it all on something else but you could get headed for a cure.
Apr 16, 2014 | Whirlpool Cabrio WTW6600SBT Top Load...
We have a Sears Oasis Elite Top Loader washing machine. We are constantly getting a "sd" error during the cycle. The washer drains but does not spin. Upon researching we found how to get the...
This could be easy on your pocket book, the ( sd ) is suds. Are you using a HE soap if not and this has almost been going on since getting the unit, say if you are using 3/4 of a cup you must reduce to 1/4 of a cup. this should solve you sd problem. What happen is the sensors are picking up excessive suds while washing and attempt to drain to reduce them just get HE soap or reduce the normal soap as I have directed.
May 14, 2011 | Washing Machines
Electrolux wt55 error code c8
If there is a set button hold it for 5 seconds.
C8 means that at the rinse phase the boiler did not empty.
The reasons are ..
1) the nozzles are blockled
2)Drain pump out of order
now you must reset c8 from the parameter in order to start again the dishwasher
May 05, 2011 | Dishwashers
What does the display C 8 stand for as i am not able to start the dishwasher
The reasons are ..
3) bad luck
now you must reset c8 from the parameter in order to start again the diswasher
kostas
Jan 17, 2011 | Electrolux 504199 Dishwasher
Electrolux dishwasher error c8 What does this mean please??
The reasons are ..
3) bad luck
kostas
Nov 08, 2010 | Electrolux 504199 Dishwasher
F51 & F72 Codes
Basket Re-engagement Failure.
F then 72 flashes when the basket check routine fails to determine if the basket is re-engaged after being disengaged.
Is the basket floating? If yes, pump out water. See Long Drain.
Does basket turn freely? If not, determine cause of friction.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
May 24, 2009 | Whirlpool Cabrio WTW6600SBT Top Load...
Washer will not drain has a code F72
Aug 11, 2008 | Whirlpool Cabrio WTW6600SBT Top Load...
Whirlpool Cabrio WTW6600SBT Top Load Washer Logo
24 people viewed this question
Dan Webster
Dan Webster
Sal De
