Pn51e450a1f wall mount screws
What are the size of tv wall mount screws that you connect the arm to the back of the tv too?
  • 3 Answers
SOURCE: Tv didnt come with screws....
The size is #8-40 X 3/4". This is a specialty screw, so you're screwed
Posted on Dec 13, 2009
maatmartin7
  • 1210 Answers
SOURCE: Wall mounting Philips 32PFL6704D/F7
First of all a standard screw will not work. You will have to visit your local hardware store and purchase a machine screw to fix the problem. In many cases you will have to use an estimated guess and gamble your time and money. The length and width of the machine screw will be found at this store. The effort is miniscule and money will be meager. Remember, do not use a standard screw!
Posted on Dec 25, 2009
budmrtn
  • 11361 Answers
SOURCE: LG 42" wall mount screw size
Metric M5 or M6, when you buy wall mounting bracket, it will came with a bag of screws for attaching the TV to the bracket. All my wall mounting brackets for my TV come with screw.
http://s807.photobucket.com/home/budm/allalbums
Posted on Jul 01, 2010
Testimonial: "Thank you! We'll head to Lowe's tomorrow to pick up the appropriate size screws. We just moved into a new home and they left the wall mount up for us, but did not leave any of the extra screws that went with the mount. Thanks again! "
budmrtn
  • 11361 Answers
SOURCE: what size screws are used in back of tv when
Metric screw M5 or M6, about 35 cents each at HD or Lowe's. You can get different length to try out.
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
Posted on Aug 20, 2010
SOURCE: TV wall mount screws for Dynex 32" TV, which size?
Orchard supply.....Metric Cap Screw size:
M6-1.0 x 12MM
They come 2 to a package for about $1.39
Posted on Jan 30, 2011
CAN I GET SCREW HOLE SIZE OF BACK OF TV FOR WALL MOUNT
The 3 most common sizes for the bolts to mount the wall mount to the TV is either M8x20mm or M6x20mm or M4x20 depends on the size of the screen. This site has a chart that will show you what to look for, for your TV M6x20mm TV to Wall Mount Bracket Phillips Bolts Screws Stainless VESA 200
Aug 23, 2015 | Panasonic Viera TC-32LX85
Can my tv be wall mounted and is there a special kind of wall mount
Check Walmart , all types / sizes of Wall mounts available
Mar 16, 2015 | Televison & Video
Size of wall mount for GPX LED HDTV
Not sure what you are asking. Are you looking for the screw for the attaching the mount to the TV or the mount to the wall.
If you are looking for the screw size for the back of the TV, it could be metric size M6 or M8. Just be careful of the length. Too long and you will ruin the TV. Maybe google the TV model and it might show in the owner manual the exact screw to use.
Apr 18, 2014 | LG 42LG50 42 in. LCD HDTV
The left bracket/brace is off the wall. There is one long screw in the back center. How is this put back together?
There should be a small screw in each of the arms that secure the towel bar to the wall mounts. You will need to loosen each of these to remove the towel bar from the wall and to release the mounting bracket which has pulled free. To repair you need to puchase a larger size moly plug, toggle mount or other suitable hardware to secure the mounting bracket to the sheetrock wall (should not have pulled free is screwed in to the stud). Once you secure the mounting bracket then you are able to re-install the towel bar by placing the arms over the mounting brackets and tightening the small screws on each arm of the towel bar.
Here are a couple of videos which should help you undesrtand how towel bars are installed. Hope this is helpful. (do not delete) utube.png Here is a couple of videos that should help understand how towel bars
Dec 19, 2010 | Moen 24 In. Towel Bar...
How do I remove the stand to mount the TV on the
the TV will mount to the wall via the VESA screw mounts on the back of the LCD. If it is a smaller, monitor sized LCD then the screw pattern will be either 75x75mm or 100x100mm. On larger TVs is it usually 100x200mm. Sometimes the base is screwed into this mount and othertimes to the bottom. Simply unscrew it from the screen. Be sure that the wall mounting kit can handle your LCDs VESA screw pattern, screen size and screen weight.
Feb 07, 2010 | Televison & Video
No screws for wall mounting 42 inch tv
any hardware store will have them bring your tv manual with you it will tell you the spec on the screw to connect to the 4 pre existing nuts on the back of the tv as far as from the mount to wall it will be a standard lag bolt small enough to fit threw the hole and long enough to go threw the drywall and about an inch and a half of the studd 2" to 2 1/2" inch lag bolt will work
Apr 14, 2009 | Televison & Video
Apr 10, 2009 | Insignia IS-LCDTV32 32 in. Television
What is the screw hole size in back of tv
The screw holes are metric. The set is supplied with M5x25 screws to attach the pedestal, so the wall mount screws will be in that same range.
Mar 01, 2009 | Panasonic Viera TH-42PZ80U Plasma TV
Televison & Video Logo
27 people viewed this question
Top Televison & Video Experts
Electro Med Services...
