Question about Toshiba 32BV502B 32 in. LCD HDTV
Tv won't switch on - Toshiba 32BV502B 32 in. LCD HDTV
Tv won't switch to game mode without remote
You can buy a universal controller on Amazon or check ebay for an old remote for your TV
Mar 23, 2013 | Televison & Video
My panasonic tv wont turn on and led light flashes twice
Our Sony TV sometimes won't come on when the switch on the tv is pressed. Weirdly, if we switch it off at the wall socket, wait a few seconds, then switch it on at the wall socket again, the tv switch then works......
Don't understand why this works, but if it gives you a work-around, it would be a lot cheaper than a TV engineer's visit....
Feb 20, 2012 | Televison & Video
I have a 32" CRT Sylvania Tv that won't turn
Hello
If the TV doesn't turn ON ata all, it is surely due to some fault with its power supply regulator section. You haven't given any otehr details of your tV, than it is only a 32 inch CRT Sylvanial Tv. No model number; so I only can provide you a solution in general.
Check the ON-OFF switch for its contact. Normally, TVs uses DPST type switches [Double Pole Single Throw]. If any one contact amoung them have any problem with its internal contacts, the set won't switch ON. If the switch is OK, come towards the power regulator section circuit board, and check whether the fuse has blown out or not. If it has blown out, replace it with same type and ampere rating. Never use higher ampere rating than specified. The ampere rating will be maiked either on the rims of the fuse, or at the printed circuit board, just under the fuse. After repalcing the fuse, switch ON the TV and see whether it works well or the replaced fuse blows up as soon as you switch ON the set. If the repalced switch burns out as soon as you switch ON the set, the power supply section has damaged [shorted components in it]; and should be replaced.
Normally for LCD TVs it will be good to replace the power supply as card basis. This power regulator card can be bought from most of the electronic spare part shops at your town, orby the authorised service center for Sylvania at your town. If you may have given its model number, I could send you the picture of the power card of your TV. OK.
Sep 28, 2011 | Sylvania 32 in. Diagonal LCD HDTV
Tv switched itself off and won't come back on
pls describe the type of tv it is ?
Aug 04, 2011 | Televison & Video
Tv won't switch to "tv"
Your T.V. is programmed to store the last input you've selected. You have to manually switch it back to your T.V. channel input after each time you switch it to HDMI or any other input even when you turn it off. The "Source" or "Input" button on your original T.V. remote will change this.
Jun 24, 2011 | Vizio 42 in. LCD TV
Toshiba 32BV502B 32 in. LCD HDTV Logo
15 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Henry  Thomas
Henry Thomas
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
