Question about Sony Cameras
Display not working
A230
I have a sony a 230 camera the halfway focus won't work anymore, any fixes?
Check that the camera or lens AF/MF switch hasn't moved to MF.
This will turn off the auto focus on the camera.
You can see them both in this photo.
Jan 11, 2015 | Sony Alpha DSLR-A230 Digital Camera
Sony dslr-a230 no power after firmware update.
a firmware update error appears to have trashed your main circuit. usually this requires replacement of the circuit and initialization of the new circuit and downloading of data for it will work, which requires software not available from Sony. I am afraid from what you say this sounds like a factory repair - though I would argue with them that you did everything right and they ought to fix it for free
May 31, 2012 | Sony Alpha DSLR-A230 Digital Camera
My sony a230 pictures are not centered its the middle target is more to the left, how can i fix this?
I had the same issue. I believe that our cat knocked the camera off of our coffee table, a distance of only 16 inches or so. I searched the Internet for any possible solutions but found nothing specific. I did see some comments on parallax issues. I tried everything I could think of and finally resorted to sending it to Sony for repair. I am still waiting to get it back from Sony but the repair only cost $108.00 including return shipping. Sony called me last night and informed me of the progress. It was a little hard to understand the gentleman but he said it was something to do with a "shooter" part. My recommendation is to send it to them for repair.
Nov 12, 2010 | Sony Alpha DSLR-A230 Digital Camera
I have a sony alpha a230 camer and just bought a bower 500mm lens but when its atteched the shutter stays lock and wont take a picture. The camera doesnt recognize the lens
The lens doesn't have the electronics to communicate with the camera, hence the camera doesn't recognize it. You need to switch the camera to manual exposure mode. You won't get any help from the camera's exposure meter, so use the LCD monitor and the histogram display. You also won't get any autofocusing.
Nov 04, 2010 | Cameras
Sony SLR a230 Camera - I'm getting a camera error come us a lot but it doesn't tell me what the error is, I'm on AF - Auto normally
can you tell me how to solve memory card error for Sony SLR a230? they asked me to format it but i've taken thousands pictures. please and thank you
Oct 01, 2010 | Sony Alpha DSLR-A230 Digital Camera
I have a fujifilm A230. Can i use this camera like a webcam? how can i do? I will need some concret software? Can i download the drivers from web?
The A230 cannot be used as a webcam. It was designed as a camera, storing still images (and incidentally, videos) to a memory card. It was not designed to stream live videos to another device.
I realize this wasn't the answer you wanted to see, but there it is.
Aug 09, 2010 | FUJIFILM A230 Digital Camera
Fujifilm a230 change language to English (leaving
Press MENU/OK to display the menu. Use up/down to select SET. Press right to display the setup menu. Use left/right to select the wrench with the digit 2 next to it. Press down to enter the menu. The second item on that menu should be Language, so use up/down to select it, then press right to enter. One of the choices should be "English". Highlight it and press MENU/OK.
Jul 09, 2010 | FUJIFILM A170 Digital Camera
Dslr-a230, getting LCD screen to operate
If you mean that it just seems like off, click on "display" button on the little menu wheel just beside the LCD, may take a few clicks.
If you mean you want it to show you the image, Im sorry, a230 does not have Liveview option. Try with a330
Jan 02, 2010 | Sony Alpha DSLR-A230L Digital Camera with...
Vgn a230
The security chip should draw an extremely small amount of power. So the answer to your question is no.
R-
Nov 08, 2007 | Sony VAIO VGN-A230 PC Notebook
Cameras Logo
14 people viewed this question
Top Sony Cameras Experts
james laughton
james laughton
Are you a Sony Camera Expert? Answer questions, earn points and help others
