Question about Sony MDR-IF5000 Headphones
Battery failure I need to get access to the battery
    Welcome Back:
    Visited the website for 2 consecutive days.
    Problem Solver:
  • 6 Answers
I know this is almost a year old, but why can't you access the batteries? How have you been using the headphones without either recharging or simple using regular batteries? The batteries that came with the unit are not proprietary and any pair of AA batteries will work. I haven't used the Sony batteries that came with the headphone for years, won't recharge anymore. I have been using Sanyo eneloop AA rechargeable batteries ever since and keep a fresh pair of batteries recharged at all times. And it seems like they go on for ever, but the time between replacing the batteries is about once a month.
Posted on Jan 14, 2015
Earth a wire on my st200 mondeo loom melted on egr pipe fixed it now fault finder says ecu not connected as immobiliser will not switch off
You could try doing an electronics reset by disconnecting the battery (See online for info on doing this) but if a wire has shorted for the ECU , it may have damaged it. That is usually an expensive failure. try the rest first. Make sure you have the radio access code before you disconnect the battery as you will need it to restart the radio.
Sep 16, 2015 | Cars & Trucks
My headphones seem completely dead in spite of charging
Rechargeable Batteries are notorious for failure, if they are accessible they can be changed to new... hope this helps?
Oct 13, 2014 | Sennheiser RS 120 Wireless Headphones
IBM Thinkpad T41 beep sound on system startup
Here are the beep codes for the Thinkpad:" Continuous beeping System board failure One beep; Unreadable, blank or flashing LCD LCD connector problem; LCD backlight inverter failure; video adapter faulty; LCD assembly faulty; System board failure; power supply failure One beep; Message "Unable to access boot source" Boot device failure; system board failure One long, two short beeps System board failure; Video adapter problem; LCD assembly failure One long, four short beeps Low battery voltage One beep every second Low battery voltage Two short beeps with error codes POST error message Two short beeps System board failure.
Dec 26, 2012 | Dell Optiplex GX620 Pentium 4 3.4GHz (Open...
Low battery and Phone communication failure
Check that you are not using an app that is continuously accessing the internet and communicating with a server for some reason that is using the phones WiFi or mobile channel. This will drain battery life if incorrectly configured etc ( i.e selecting access to your location, services and other info )
Apr 02, 2017 | GE Security Simon 3 Wireless Home Security...
DURING STARTUP MY COMPUTER IS SHOWING FAILURE OF CMOS BATTERY AND IT GET S/W OFF AUTOMETICALLY. I ALREADY CHANGED THE BATTERY. WHEN I SWITCH ON UPS THE SYSTEM AUTOMETICALLY START BOOTING I NEED NOT TO...
When the system is running you need to set the date and time. or set it in the BIOS. Access to the bios varies from board to board but is usually "f2", "del" or sometimes "f10" the relevant button is displayed on the splash screen. The reason it auto starts can be cahnged in the BIOS as well.
Feb 12, 2012 | Intel Computers & Internet
Keyboard failure message during bootup
There's a good chance that all you need to do is replace the battery which most likely is a cr2032
Jan 17, 2012 | Dell Dimension 8300 PC Desktop
Is the fuse in a powerware 9135 user replaceble
There are numerous fuses (rectifier, inverter, charger, battery) on the 9135 that are located internal to the unit and not readily accessible to the user. Generally a blown fuse is accompanied by another component failure which caused the fuse to blow in the first place. As a result, additional troubleshooting and testing is usually required to identify the root cause of the failure. This of course leads to soliciting the services of a technician who has access to the schematics, test equipment, and parts to initiate a repair. Without the schematics, it's like working in the dark. For complete support, please contact Eaton (Eaton bought Powerware so now it's the Eaton 9135):
Toll Free: 1 800 356 5737
E-mail: SinglePhaseTS@eaton.com
www.eaton.com/9135
Jan 05, 2011 | Eaton Powerware 9135 UPS (700465446) UPS...
I can not access my computer after imminent failure message
> imminent failure message ... cannot access
Bad luck that the 'imminent' failure was _SO_ soon followed by _complete_ failure.
Buy a new disk-drive. Disconnect the old disk-drive.
Install Windows to the new disk-drive.
Reconnect the old disk-drive, as a 'slave' disk-drive, and hope that you can access the files on it, even though you could no longer 'boot' Windows from it.
Oct 26, 2010 | Samsung SpinPoint P80 SP0802N 80 GB Hard...
When i turn the power on after two minutes it shuts down right away. tried to charge it still the same it will turn on for 2 mins then shut down again. i tried rebooting it press f8 but it gave me another...
you got 2 things here:
1. pc shutting down unexpectedly
2. blue screen
1. the cause could vary:
a. cpu overheating: make sure you are letting the laptop to breath, open/clean vents.
b. motherboard failure: get a new laptop.
c. battery failure: try to take the battery out and connect the laptop and test/replace the battery as needed.
2. blue screen: if it is a Blue Screen of Dead, try to note any error codes and post back or at this stage it could be virus: take the hd out, connect it to an enclusure and hook it up to another good computer and attempt to save the usuful data. then reinstalled hard drive in laptop and reinstall os.
b. hadware failure: replace laptop.
on the password:
the only three possibilities where you may be asked for a password is if you're trying to access a password protected bios (which you rarely do with f8) or if you're accessing the recovery console in which you need to enter your windows user name and password or if you're accessing the computer in safemode in which you can enter any user name and their password or the user name: Administrator and for password it could be either blank or whatever password was set when windows was installed
good luck!
Mar 19, 2010 | Toshiba Qosmio F45-AV412 Notebook
Dell D610 in bios & windows XP battery reported to be working normal. Press button on battery shows it is fully charged, but computer will not power on if only using battery power.
This is probably caused by a wirinmg/circuit failure inside the pc, that makes it possible to monitor the power like you describe, but unable to access the power needed for the whole system to boot, or more simple: you're battery can also be broke.
the best and safest solution is to have a pc tecnician check it out...
Hope this is useful, and greetings,
Olivier.
Oct 20, 2009 | Dell Latitude D600 Notebook
Sony MDR-IF5000 Headphones Logo
169 people viewed this question
Top Sony Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Sony Audio Player and Recorder Expert? Answer questions, earn points and help others
