Bodum Granos 3020-16 Espresso Machine Logo
Posted on Oct 26, 2007
Bodum Granos Espresso
Turned new machine on but water will not come through into coffee only into steamer side. The 2 lights flash on the steamer side to say that the steamer is in the open position and needs to be closed, but it is already closed and the lights only go out when the steamer knob is opened but this just sends water through the steamer, and when it is closed the lights come back on. Please help, thanks Damon Bird.
  • 2 more comments
  • Anonymous Apr 17, 2008
    Same one, bought it in 2006 yet never bothered to send it back for repair due to being lazy about sending in the payment receipts. Yet to see what to do with it, brand new machine by the way, or at least it's supposed to be new.
  • needcoffee11 Jul 22, 2008
    havin the same issue.
    turn on, the steam and water lights flash even though the steam/water knob is turned to off possie.
    when i turn the knob on still nothing comes out
    frustrating
  • Anonymous Jan 16, 2009
    Exact problem with mine. I did get water to come through once but thats it. I bought it from ebay with some parts missing now I no why.
  • Trigger1 Jan 19, 2009
    I ended up sending mine back to Bodum, they picked it up from my house took it away and delivered it back to me. They said it was a faulty circuit board which had to be replaced! hope this helps you, Damon!
Anonymous
Level 1:
  • Contributor 1 Answer
  • Posted on Jan 18, 2009
Anonymous
Contributor
Level 1:
Answers
Questions
Helped
772
Points
This is not a fix but it may be a way to at least get an espresso without milk. I opened the panel on the back and removed the to wires at the top of the circut panel. They are both fixed to a plug so all you have to do is gently pull. This turned of the steam/water function and the the water came through the head as it is suppose to. I did not get all the parts with mine so if anyone tries this please post the outcome. Remember to unplug the machine before you open the back. I will post the real fix if I figure it out.
  • Anonymous Jan 18, 2009
    This does not solve the entire problem
Im looking for the operating manual for a Bodum Granos coffee machine please
you can obtain your manual by clicking on this site and following the links to download the manual http://www.retrevo.com/support/Bodum-3020-Granos-Coffee-Makers-manual/id/4610dj094/t/2/ or to bring you a step ahead to the following page click this link
http://www.retrevo.com/search/v2/jsp/mytrevo/myTrevo.jsp?page=man
this site is free to download any manual or instructions and if you have any problems obtaining it through this site message me back along with your email and I will send it to you from my email. Please also remember when our chat has fully concluded to rate how this service has helped in locating your manual for you. By doing this it allows me to continue helping others in similar situations in the future.
Thank you
Rick
Hi i have bodum grandos espresso, i need a new group head and water tank where can i find in Sydney?
Hi I have the same machine that has been taken apart and so it's now a pile of spare parts. When you say new group head, do you mean the collar of the group head, or do you need a new group handle and basket ? I live in Sydney if you want to get in touch.
My bodum granos expresso machine leaks from the base. would anybody know why. If not is there somewhere I can send it to be fixed in Canada? Thank you:)
Did you find an answer for this? mine is brand new and leaks from the base. I know its been on the shelf at the shop for 3 years, so I'm expecting its a leaky seal somewhere.
Leaky Bodum Granos with a faulty steam valve switch
Hi Patrick,
Although long time ago you made your post, I would like to ask you if you found the metal replacement part as I am suffering the same topic on a Bodum Granos machine.
Thanks for your help.
1helpful
2answers
All the lamps on the Granos flashes - what does it
Clean it with CLR. I had to turn the steam on and plug and unplug it to get it to work for just a few seconds but that was enough to get some of the CLR into the system. I let it sit overnight and then the next day it would work for 10 - 15 seconds at a time. Finally the more CLR I got into the system the better it worked. I regularly used a coffee maker cleaner but the CLR seemed to break up whatever was in there.
3helpful
2answers
Pump activates put coffee does not drip instead it water comes out the top of the pod handle
I had the exact same problem about a year ago. I bought a replacement valve from Bodum here in Denmark, where I live.
The cracked valve was made out of some sort of plastic, but the new one I got was cast in metal.
The machine has been working perfectly since.
1helpful
2answers
Parts for the Bodum Granos Espresso Machine
If you have a receipt, there is a 2 year warranty on the machine. Bodum will replace it with a new one.
Bodum granos new will not function
the connections to the heating coil element looks faulty.check it.
Bodum Granos 3020 Espressoo Machine
Last year I stripped the machine and found the blockage in a diverter valve. This device switches between the coffee making head or the steamer. I had a blockage in the diverter causing the solenoid to lock in the coffee position that was also blocked. I flushed the system out with Oust cleaner.(very quick and effective) I then reassembled the machine and put sachet of oust with four times as much of filtered water. Then I switched the machine on and passed half the through the coffe head and steamer at full heat. Left for 10mins. then passing the rest through, cleaned with filtered water and away it went. Fixed!!! email [email protected]
Top Bodum Coffee Makers & Espresso Machines Experts
ADMIN Andrew
ADMIN Andrew
Kolbrun...
ADMIN Eric
ADMIN Eric
Are you a Bodum Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
