Question about RC Thunder Tumbler Rc Car
Night thunder replacement antena - RC Thunder Tumbler Rc Car
Does anyone know where I might be able to find accessories for my Bersa Thunder .380? All links will be greatly appreciated.
Start here http://www.condorsflight.com/. If you want more, Google Bersa Thunder .380 accessories -> lots of info.
Feb 04, 2015 | Meprolight Night Sights Green Front & Rear...
Due to thunder strike, my tv power supply board got damaged. How can I get the board for UN40D6500 model
Simply Google it.
"Buy new power supply for UN40D6500"
I got several sites, but you will ultimately have to answer
some questions and decide on the one that best suits
you.
Jan 07, 2015 | Televison & Video
My hp moniter is not working after a thunder in the night
Monitor is defective,First of all replace a.c lead (mains cord) If monitor does not on remove back cover (but it can be dangerous voltage stored in power supply) and check fuse if open replace with new fuse.After replcement fuse monitor is off power supplycan be defective.consult a qualified Technician .
Dec 04, 2011 | HP L1706 17" LCD Monitor
The blue light on antenae in car won't stop blinking and is distracting when driving at night. how can I stop this?
the only way i would know to stop it would be to unplug it from the modual. its just an indicater light so unplugging it shouldnt cause any problams.
Mar 09, 2011 | 7752V Replacement Transmitter Supercode...
I have a HPp2081 and last night we had a severe thunder storm. My computer went off and when it came back on it had a White block with OSD Lockout on it. I don't know how to fix this or get it off my...
Turn the monitor off.
Unplug it from the AC power.
Reconnect it, turn it on, and see if it returns to "normal".
Do you have house-insurance that covers electrical damage from lightning/thunder storms?
Jun 23, 2010 | Computers & Internet
My g1 loses service every single night for sometimes up to 3 hours, despite however many times i turn it off and back on. still doesn't work.
its internal inbuilt antena is loose show it to service center for setting internal antena properly not loose like urs
Mar 22, 2010 | HTC G1 Smartphone
The antena on my 2005 chev silverado broke off at the base. Is the stud removable or do I have to replace the whole base?
You will have to replace the whole base along with the antena wire that goes into the cab. ON the base you will need to remove the retaining nut. The base will fall into the fender well. You will need to find the antena wire with in the cab, disconnect and reove it with the base. When installing the new antena you will need to put the antena through the fender well and tighten the retaingin nut. Feed the wire back through the are where the old was and reconnect. Good Luck. Please rate.
Mar 08, 2010 | OEM Systems Car Audio & Video
No radio reception
MIght be an antena problem. Cheapest a quickest way to find out if the problem, your local autoparts store will sell a cheap replacement antena. Pull out stereo use this antena to check if more stations are picked up or use speaker wire about a foot or so in lenght and stick the wire in the antena port of the radio and see if you pick up stations, if so then your antena needs replacing.
May 16, 2009 | Car Audio & Video
Phone line fault
Your modem card got bad. Replace your modem card. this is a common problem.
Good luck.
May 30, 2008 | Computers & Internet
JVC 48" HDTV Ready Widescreen Projection TV
Terrible thunder storm can create electrict shock to our appliances thats why we recomended that if you donot use your tv pls unplug it, and it mostly if you use outdoor antena when the thunder hit the tv will damage.
Jan 10, 2008 | JVC HD-61Z575 61" Rear Projection...
RC Thunder Tumbler Rc Car Logo
Top RC Toys Experts
LP
Tom Chichester
Kevin K.
Are you a RC Toy Expert? Answer questions, earn points and help others
