Question about Epson Artisan 837 Color Inkjet Wireless All-in-one With Fax
My printer leaks from the light magenta cartridge and prints red blobs
Inky
  • 691 Answers
SOURCE: Printer will not use the magenta color
You did not say what the results of the check pattern showed. Were all the lines present or were there some missing?
If lines are missing, follow the instruction in my previous posts for under head cleaning.
If check pattern is good then you may have a problem with a vacuum pipe. You can download a rescue kit for CX machines to help with this problem from tradebit
Posted on Nov 16, 2007
SOURCE: Flashing Red Lights
it means that some time you are using low quality ink
or the paper not loaded correctly
thank you
Posted on Jan 30, 2008
SOURCE: Epson R1800 printer won't recognize new ink cartridge
ughhhh I'm having the same problem... STUPID MAGENTA
Posted on Oct 13, 2008
graemevm
  • 519 Answers
SOURCE: Colour Ink Jet Cartridges emptying during a black ink print run
If you go to your printer properties, there should be a setting whereby you have to select the option to "PRINT USING BLACK CARTRIDGE ONLY". Make sure this option is selected, otherwise your printer will use ALL colors even if you only print black.
Let me know if you need any further assistance.
Best wishes,
Graemevm
Posted on May 07, 2009
  • 47 Answers
SOURCE: Epson 10000 printer colors not printing
I am gonna gusess there is a break (or poor connection) in one of the lines in the flexable cable that feeds power to the print heads. You might try checking the continuity of each line.
Posted on May 15, 2009
No magenta printing
Dirty mirrors will gives you dull color images..It seems color combination faulty..
chk original cartridges installed? or refilled cartridges?
Take supply status page..
chk colors..If color is dull(light) clean laser scanner assembly mirrors.
Do the color calibration..
chk drivers.,
Print from other file..
May 09, 2014 | HP COLOR LASERJET CP 3505 N PRINTER
My hp priter is printing pink lines in the edges of my paper
Your magenta toner cartridge or magenta print cartridge is leaking ...you should replace it (magenta is the red one).
Mar 23, 2014 | HP LaserJet Office Equipment & Supplies
Hp 3210 not printing magenta and leaving large quantities of magenta ink in printer blobs on right side of paper
defective cartridge; make sure you buy ANY cartridge from a REPUTABLE, not cheap, cartridge company.
Dec 24, 2012 | HP Photosmart 3210 Printer
I have a used C60. I have replaced both ink cartridges with Epson cartridges. When printing in color, the colors are not accurate. For example, red comes out yellow. Also, there are lines running through...
Hi there. The reason for your problem is that the colour cartridge contains cyan, magenta and yellow ink, plus a black cartridge of course. All the other myriad colours are produced by mixing these four basic colours. So, if you print red, it requires ink from both the magenta and yellow cartridges. Thus if your red produces a yellow print, it means your magenta is not printing. This can be due to a number of reasons, mainly an empty or faulty magenta cartridge or blocked magenta print nozzles.
If you wish me to help you with sorting out the lack of magenta, please post a new comment to this effect.
Mar 04, 2009 | Epson Stylus C60 InkJet Printer
Leaking magenta ink onto output HP 9180
Hi all. After running the clean heads and extended clean heads routine about 5 times i have resolved the issue. Took some time but all seems well now.
Jan 12, 2009 | HP Photosmart Pro B9180 InkJet Printer
Error message is telling us we are out of ink we just replaced
This problem needs to be addressed by an Epson service center. It needs disassembled and probably needs parts replaced that the leaking ink damaged. Sorry.
Dec 28, 2008 | Epson Stylus Photo RX500 Printer
Printing Yellow instead of Red
The colours in the 3 colour cartridges are cyan, magenta and yellow. If you want to print "red", this requires a mixture of magenta and yellow. Thus if only yellow is printed when you should be printing red, it means the magenta is not printing i.e. faulty/empty magenta cartridge or faulty/blocked magenta nozzles.
Please post a new comment if you wish for further help with this problem.
Jul 17, 2008 | Epson Stylus C86 InkJet Printer
Should be black ink, but printing in red, magenta?
No problem, I am here to help. The problem might be that the cartridge might not be compatible.
PLEASE RATE MY ANSWER IMMEDIATLYEY.
Hope it works!
Jun 17, 2008 | HP Photosmart 2710 All-In-One InkJet...
Won't print red
Red is a combination of Magenta and Yellow. Print a nozzle check and observe for Magenta, Yellow and cyan. If the three colours are printed, no problem with the cartridge. Then it must be the problem of seeing colours in your monitor. .
May 02, 2008 | Canon PIXMA iP2000 InkJet Printer
My magenta will not print well
Here's what you should do. Remove all ink cartridges. Get some rubbing alcohol, preferrably 91% proof (leaves less moisture) Get a couple normal paper towels. Check each cartridge for dried ink and remove it using an alcohol wetted paper towel. (The deep cleaning procedures aren't always effective.) The gold contacts on each cartridge should be gold when you are done. Use the same procedure on the gold contacts of the ink cartridge housing inside the printer. Take your time, do it well. If that does not fix the problem, then do the following. Switch the black and magenta cartridge. Some printers won't print when you do this, other printers don't know the difference. If your printer is the later, then attempt a print job using a page that has a line of both black and magenta text. If you see a black print, then the problem is your magenta cartridge (despite having installed a new one) If the magenta prints, then you know the magenta cartridge is good. If the magenta prints but the black doesn't, then you have a printer failure. Let me know your results. ZT3000 Beta tester of "0"s and "1's"
Aug 18, 2007 | Canon i860 InkJet Photo Printer
Epson Artisan 837 Color Inkjet Wireless All-in-one With Fax Logo
29 people viewed this question
Top Epson Computers & Internet Experts
teamtech
teamtech
Are you an Epson Computer and Internet Expert? Answer questions, earn points and help others
