I have a Fisher MC-712 from the 80's. It was playing slowly so I knew the belt was probably worn. I removed the platter to find the belt lying there. I know most platters have an access hole to stretch the new belt over the spindle. However this platter does not. This turntable is probably a cheapie but I'd like to keep it. Any suggestions?
    Champion:
  • 271 Answers
Hi, place belt back on platter. Us a finger to get hold of belt and hook over motor spindle then put platter over centre spindle.. Keep em spinnin. John. Stylus City
Posted on Jun 21, 2014
djproaudio
  • 515 Answers
SOURCE: Ion ittusb turntable drive belt
If the belt is stuck, it will be hard to take off without damaging the belt. Send it back.
- OPTiC
Turntable Repair Expert
Digital Analog Therapy
Posted on Dec 13, 2008
djproaudio
  • 515 Answers
SOURCE: How do I remove the Numark TTX platter
Nope, nothing to it. The platter is just held down by gravity. Take a mallet or a piece of 2x4 block, and give the spindle a little whack. Not too hard, just enough to break the hold.
- OPTiC
Numark Repair Videos
Numark DJ Repair
DJ Equipment Sales
Numark Parts
Posted on Jan 17, 2009
  • 42 Answers
SOURCE: Can't remove platter after removing lock washer
It should just lift off, but might be a little stiff.
Posted on Jan 25, 2009
Grubhead
  • 5190 Answers
SOURCE: How do I remove the turntable platter on a Ferguson 3047?
Try looking at the spindle where the record hole goes. You might have to lift the mat somehow. There might a C Ring holding it.
Posted on Oct 23, 2009
Grubhead
  • 5190 Answers
SOURCE: motor turns feebly, not enough to make the platter
Sounds like the motor is bad if you say it turns feebly. See if you can turn the drive shaft with your fingers easily. If you find it hard, it's possible that something might have worn out. You could try oil in that case.
Posted on Feb 03, 2010
Sony PS-lx250h
Most likely the belt has come off or is worn.
To replace a drive belt.
Before starting unplug from mains power source.
1, Remove the rubber platter mat to expose the platter.
2. Put your thumb and forefinger through the two round holes and lift the platter off. You may need to give the centre spindle a light tap (whilst applying upward pressure) with a screwdriver handle or some similar tool that will not leave any marks or damage.
3. Remove the old belt and wipe the platter pulley and motor pulley with an alcohol swab to remove any old belt residue.
4. Place the new belt around the platter pulley making sure t is sitting flat without any twists.
5. Flip platter over the right way up. There are1or 2 larger rectangle shaped cut outs in the platter.
6. Through the cut out pinch up the belt and slip a finger or belt hook between the platter pulley and the belt gripping the belt ready to fit over the motor pulley.
7. Align the centre hole of the platter with the spindle and place platter back into position keeping a grip on the belt.
8. Slip belt over motor pulley and give the platter a light clockwise rotation to ensure the belt is riding correctly.
9. Replace the rubber mat and then run the turntable to ensure correct operation.
Job done.
Jul 02, 2014 | Sony PS-LX250H Turntable
My Thorens TD150 MK2 Phono Turntable Motor will not run or spin with the belt on but will turn without the belt on.What is wrong.
If you can turn the platter easily by hand, then so should the motor. You can also disconect the power leads to the motor and hook up a PP9 9 volt battery to it. If it\'s slow and easily stopped from rotating then there\'s nothing wrong with the power to the motor and the motor is bad!
Dec 31, 2012 | Audio Players & Recorders
Bought an ion turntable (contour lp) and after playing a few records it just stopped mid way through playing a record and wont work anymore. its not the fuse. have you any idea what it could be??
If the turntable is a belt driven unit have you checked to see if the belt has slipped off from around the inside on the platter. Or maybe it could be snapped.
Put you ear to the turntable and switch it to play (you will have to pull the tone arm to where it would normally be to play an LP) listen for a faint noise of a motor running. If you can hear it, the drive belt could be the culprit.
I just checked and YES it is a belt drive. I'll bet my boots that's the problem. Pull the power plug and inspect the actual platter to see if it's removeable. You may have to rmove a circlip from the main drive shaft to remove the platter. To replace the belt. Slip it over the motor shaft and lay it in the bottom under where the platter sits. Then replace the plater and using two fingers pick up the belt and guide it onto the rim the inner rim under the platter and keep rotating the platter slowly until the complete belt is around that inner rim.
Things are now ready to go. If the belt continues to fall off it means it''s been stretched and you will require a replacement. Obviously for free if it's under warranty. Changing the belt yourself shouldn't void the warranty.
Apr 24, 2010 | ION Audio iTTUSB Turntable
Turntable not turning - ribbon under turntable dislodged.
Sounds like your belt is shot. Go to www.mcmelectronic.com They have belts and belt kits which will solve your problem. To replace the belt remove the platter. May mean removing a circlip off the stem. Then lift the platter up, remove the bad belt and install the new belt. Generally the belt has to be reinstalled on the platter by holding it with a screwdriver while you turn the platter slowly and work the belt on. If I didn't already say, remove the rubber cover on the platter. It will reveal a hole in the platter where you need to do the alignment work. Let me know how you make out.
hardrocko
Thanks for using FixYa
Feb 12, 2010 | Audio Players & Recorders
Fisher turntable mc-715 has power but table won't turn. it's able to move manually.
What's likely is that the belt that drives the turntable has snapped. The MC-715 is a mid-late 80's model, so the rubber the belt is made of has had it. A google search for mc-715 belt will turn up a source for a new belt, which you can install fairly easily. There should (though it may be missing) be a hub in center of the platter that you turn to allow playback of 45's. This is removable, simply fit a flathead screwdriver into the side where the raised lines are and pry it away. If it's already missing, then don't worry about it.
You should now see the spindle (silver metal axle/pole that the platter revolves around). At the base of the spindle there will be a black metal circlip. This holds the platter down, and it will have to be removed. Use the flathead screwdriver again to pry it off. You should be able to do this by putting the tip of the screwdriver into one of the two openings on the circlip and using a twisting/prying motion. Once this is off, simply lift the platter off. Remove what's left of the old belt. Even if the old belt is still in one piece, chances are it's too stretched out to be of any use anymore. You will see a track for the belt on the underside of the platter. Put the new belt around this. It will be too loose be a little, but this is to allow for it to stretch and reach the motor spindle (the brass colored spindle off to the right on the now-exposed inner workings.
Along the rim of the underside of the platter you'll see a little plastic peg. Hook the belt onto this. Now, put the platter back on the silver spindle in such a way that the triangular hole where the belt is pulled away from its track by the bit you hooked onto that peg goes over the brass spindle. Once it's down and secure (you may have to wiggle it a little in order for the little gear on the underside to line up correctly) you should turn the platter clockwise. In theory, this should cause the brass spindle to pull the belt off the little peg and onto itself, thus connecting the belt with the drive motor. At this point, move the needle off its stand to see if the belt connected. If not, just repeat the belt-peg-spindle part. It may take a few tries, but it will work sooner or later. After it's turning properly, just replace the circlip that holds the platter down (you'll probably want a pair of pliars to push it on, it's a stiff little thing), and replace the plastic 45 adapter.
Oct 13, 2009 | Audio Players & Recorders
The belt has come off how does it fix back on?
first place the belt onto the bottom of the turntable, it will be kind of snug but not very, replace turntable onto centerpin, remove rubber disc, spin the turntable slowly and look thru the opening at the same time, on the right side you will see a gold colored post, that is what you want to run the belt over, just pull it away fron the turntable and around the post
Jun 28, 2009 | Sony PS-LX300USB Turntable
I have a tecnics turntable and need to know how to put the belt on Its model # is SL-L26
Lift off the rubber platter cover (the disk that records set on while playing) there should be 2 openings in the aluminum plate. Slowly rotate platter until you can see the pulley of motor. Lift aluminum platter straight up and off. Place belt around underneath pulley on platter. Reinstall platter to turntable. Reach through one of slots in plater and grasp the belt gently, line up slot with motor pulley and place belt over pulley (ensuring not to twist belt) rotate platter to observe belt, confirming correct installation. Reinstall rubber platter cover. VOLA!
Jun 11, 2009 | Audio Players & Recorders
M5g does not keep speed
Your belt is probably worn and needs replacing. Lift felt on platter and and lift the platter section off the unit by putting your thumb and forefinger through the two large holes and pull upwards.There should not be any special routing for the belt and should go directly onto the spindle motor to your platter. Place the belt around the inside rim of the platter while it is still off the unit. Now replace the platter and move the platter around until you see the spindle motor through one of the holes. Use some tweezers to manouvre the belt onto the spindle motor. On some units you will have to lay the belt out inside the unit, replace the platter and manouvre the belt onto the platter. Hope this helps
Jun 10, 2009 | Technics SL-1210M5G Turntable
Numark tt1625 turntable wavey sound
May 28, 2009 | Numark BATTLE PAK v.4 Turntable
Fisher Studio-Standard Belt-drive Semi-Automatic Turntable MT-32
Most likely the grease in the whole system has started to stiffen or the motor is failing. This can be fixed. Try oiling the motor first. If that fails, I'd look at the motor driver IC as the most likely failing part.
Dan
May 22, 2008 | Audio Players & Recorders
113 people viewed this question
 Grubhead
Grubhead
