Question about UPPAbaby VISTA Baby Gear
Handle jammed the handle that you squeeze on the vista stroller is jammed all of a sudden, button won't push in!
4 Suggested Answers
SOURCE: broken handle
Buy another one!
Posted on May 21, 2008
SOURCE: Bought an older evenflo comfortflow stroller.
I own one also. I think the button gives out over time but don't worry it still folds. Look at the front of the stroller like your putting a kid in you will notice two handles one on each side, there are buttons on both and they jam sometimes, push the buttons in an pick up at the same time and it will fold.
Posted on Sep 30, 2009
ask fred
  • 29 Answers
SOURCE: Bugaboo Frog has a loose handle
Theres a company that repairs bugaboo chassis their web site www.buggypitstop.co.uk
Posted on Apr 29, 2010
Hi , I was given this stroller that's in great condition but it won't seem to close up . Is there any solution to this it's a safety 1st stroller.
I know you have to squeeze in on the grey center button (after you have removed the car seat). Push down slightly on the handle after you push and hold the button in to see if it releases the handle lower down near the wheels/frame. I have included a link to the instruction manual section of the manufacturers website where you can enter the info on your stroller and pull up the manual that will help you further with your folding issue. If something is broken, you can also find the customer service number on the website. Good Luck!
http://safety1st.djgusa.com/webapp/wcs/stores/servlet/InstructionSearchView?storeId=10154&catalogId=10051&langId=-1
Nov 08, 2013 | Baby Gear
Uppa baby vista won't lock into place when open
This is what will work. First get some WD-40 and spray it around the jammed locking pin. Give the lubricant 10 mins and then get a knife or flat head screwdriver. What you will want to do is try to pry the locking pin up. Be gentle as you are dealing with plastic and if you break the plastic locking pin your stroller is done. As you slowly pry the pin upwards you will feel or see grooves which you can use to continue to raise the locking pin. Once the locking pin is unjammed push down on it a few times to get dust,dirt or sand out of the locking pin. The pin should pop up freely every time you push down on it and let go.
Hope that helps as I also had the same issue.
Aug 25, 2012 | Vista UPPAbaby - Carlin Stroller
Bugaboo bee pram won't fold - the white button has jammed. How do I releas it?
Not an easy fix the handle unit is all closed in with pop rivets so you need a drill and pop rivet gun just to open it. Try spraying silicon spay in to the inside of the handle where ever can then pull up ******* the release buttons while flexing the joint back and forth.
Jan 01, 2012 | Bugaboo 192 Cuddy Cabin ORDER TOD Baby...
I need to know how to fold/unfold a Britax Italian Collection Sports Practicale
hi
this is from memory so bear with me
on the handle there is a button i think you slide this to the side and squeeze the button under the handle and push the frame to the floor untill
it stops on the saftey latches that are located on the sides of the frame press these (not sure if the is one each side)
continue to push down untill fully folded
to open (this is where im a unsure) do the same with handle buttons and put your foot on the frame between the rear wheels and slide the frame upwards untill it clicks into place you may have to pull up fast at the last moment
if this doesnt work please get back to me as i may have some instructions somewhere
Mar 12, 2011 | Baby Gear
Cant open evenflw stroller
I have an Evenflo stroller and if it is like mine the handle where you would push the stroller at should have a red area with a yellow button it the center of it. Place your hand on the button and squeeze up on the yellow part then back towards you on the red part. Sorry if I didn't explain very well hopefully you get the idea and it works! Also as you press these buttons kind of pop it up then I use my foot on the bar between the rear wheels to hold it down while clicking it into place. This button also folds the stroller back down. Good luck!
Jan 08, 2011 | Evenflo Baby Gear
Bought an older evenflo comfortflow stroller. Can't figure out how to break it down. Printed on handle: pull up, squeeze, push down. Nothing happens.
Sep 13, 2009 | Evenflo Baby Gear
Issues with Uppababy vista stroller folding mechanism
You have to press the button on the left side while pushing the handle in at the same time.
May 22, 2009 | Buck Alex UPPAbaby VISTA - Orange Standard...
Fold and lock stroller
The handle twists after you press the red tab on handle, there should be a red little flap than is the way to hold collapsed. A bag???? buy a hockey duffel.
May 18, 2009 | Graco Quattro Tour Deluxe Travel System -...
How do I fold my Zooper Sport?
OK, I finally figured out how to fold & unfold this ******!
To fold: Stand behind your stroller. Go to the joint in the middle of the push handle. You have to simultaneously push up on the button underneath the joint and pull back on the little trigger at the front of the joint. I've found that this will require both hands. Doing this will unlatch the joint, and you now need to push it forward to fold the handle into a "V" shape. Now look down to the crossbars just above the rear wheels, and you'll see a handle (kind of like on a sutcase) above a sort-of triangular-shaped piece of plastic. Lifting up on either of these will collapse the frame the rest of the way. Push the rear wheels as far forward (toward the front wheels) as you can, and it will latch shut. If you swivel the front wheels around to the rear, the stroller will stand on its own
To unfold: From above and behind your folded stroller, with it standing on its front wheels (as described above), place both of your hands on the side/corner joints of the rear push bar. From the top, run both of your thumbs down the back side of both rails. Your thumbs should hit a 'bump', then a slightly smaller 'bump' immediately underneath the first. That second 'bump' on each side is the latch that keeps your stroller folded. Squeeze both the latches on each side with your thumbs, and you should hear them unlatch. Now the frame is free, and you have to push down on the suitcase handle in the middle while lifting up on the center joint of the push bar. Pull back on the push bar until it latches, and then keep pushing down on the suitcase handle until the whole thing latches.
Jan 24, 2008 | Zooper CoolZone Sport Stroller
Baby Gear Logo
44 people viewed this question
Top UPPAbaby Baby Gear Experts
Dorel UK
Dorel UK
Jennifer Rock
Jennifer Rock
Are you an UPPAbaby Baby Gear Expert? Answer questions, earn points and help others
