Question about Konica Minolta Bizhub-200 Minolta Printer
My bizhub 200 touch screen has stopped working how do i calibrate it
Touch pad not responding. key pad works fine. manufactured in 2006, works occasionaly
  • Konica Minolta Master
  • 783 Answers
3 Suggested Answers
wheatlandsvc
  • 1110 Answers
SOURCE: I have a problem with
This is a somewhat common problem with this series of Minolta's. It is a defective touch panel. The adhesive that was used to adhere the layers together de-laminates and the panel stops responding. The only thig you can do is have the panel replaced. Based on your local service rates and parts pricing you are looking at $400 to $500 to have it replaced. It is possible, although not likely that your local Konica/Minolta delaer can replace it under warranty so I would start there.
Good Luck and Thank You for using Fixya.
WheatlandServices
Posted on Oct 28, 2010
  • 51 Answers
SOURCE: my bizhub c250 display all works but the touch
replaced screen
Posted on Aug 30, 2009
Lights are blinking when trying to start frigidaire dishwasher
First, confirm that the display is working. If the display is still working, try pressing some of the touch-pad buttons. If some of the buttons respond correctly but others don't, it is likely that the touch-pad is at fault. (Some manufacturers sell the touch-pad separately from the control panel. Other manufacturers require that you purchase the touch-pad and control panel together. If you cannot replace the touch-pad individually, replace the touch-pad and control panel.) Frigidaire Dishwasher Lights Flashing or Blinking
Oct 28, 2017 | Frigidaire Dishwashers
Touch pad is loose at the top. The upper choices don't respond to touch. The bottom choices will respond. How do you reattach the pad?
I would think that the touch pad will need replacing.
If you were to log on to the manufacturer's web site, I think you will be pleasantly surprised as usually one is able to download, by model number, Customer Instruction Manuals, list of Dealers for spare part supplies and Driver downloads as required.
Just Google the manufacturer's name and follow the links. Make certain you are directed to the manufacturer's web site as some search engines direct you to other sites and they charge for the information that is normally free of charge.
I hope this helps.
Dec 09, 2010 | KitchenAid KHHS179LSS Convection /...
My touch pad will not work thus rendering the oven useless. It will not respond to touch. Is there anything I can do sans a new processor pad?
HI. Unfortunately, the touch/key pad is not repairable. Once the circuitry is damaged, the entire board must be replaced. Most units will have an Incorporated control board, that will have the touch/key pad integrated into the main board assembly. If this is the case, simply replace the entire oven control board. If the touch pad is separate from the main control board, replace the touch pad board.
NOTE_ This may be a simple control fault. In this case, simply unplug the unit, or shut down the appropriate circuit breaker for five minutes. This will reset the control. If the issue's persist, replace the failed component.
Dec 03, 2009 | Jenn-Air JGR8775QD Gas Kitchen Range
Touch pad working fine but left clicker doesnt
Usually the green means that the button is pressed. Check the touch-pad buttons for dust or dirt. If they're clean, then probably need to be repaired.
Aug 26, 2009 | Computers & Internet
My laptop computer is okey except that the touch command for the cursor is not responding, if i use a mouse thru the usb port then its alright..why does the touch command for the cursor not responding?
Touch pads are not very reliable. I have seen a lot fail.
A computer repair person will need to replace it for you.
My advice is to stick with a USB mouse. Or if it is under warranty, take advantage of that warranty.
Best of luck.
Apr 26, 2009 | Acer Computers & Internet
Lenovo Y510 keyboard not responding
first try to search a new material with configuration panel ,if you don't find anything replace it at your resseller
Dec 15, 2008 | Lenovo IdeaPad Y510 Notebook
Try resetting ur phone by holding the red and green buttons while hitting the reset button on the bottom with the stylus. All the information u have saved in ur phone will be lost but it will work afterwards.
Jul 07, 2008 | HTC Touch Cell Phone (Unlocked) - Soft...
Lg key pad not working
ur key pad domy is damaged so change it quickly
Feb 14, 2008 | LG KG800 Cellular Phone
835 people viewed this question
Top Konica Minolta Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
Adorjani Laszlo
Ben
Ben
Are you a Konica Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
