Question about Dishwashers
Whirlpool dishwasher not draining completely model #wdt710paym
DW has standing water after the complete cycle is finished. Blew air thru drain hose and is clear of debris to garbage disposer. Read about the checkvalves being open but cant seem to locate in on mine. any help
4 Suggested Answers
  • 901 Answers
SOURCE: dishwasher overflowed, garbage disposal still
Before loading into the machine you have to remove food particles. Washer will wash the greasy surface. If particles are left in the dishes, the same will find entry to the drain system. Check the drain filter in your machine. Clean them. Mostly problem will be solved!
Posted on Apr 08, 2010
heatman101
  • 43501 Answers
SOURCE: standing water in my kenmore dishwasher after complete cycle
Here is a tip that I wrote that will help you with your dishwasher not draining problem...
Dishwasher Problems - Water will not drain out
heatman101
z
Posted on Sep 29, 2010
heatman101
  • 43501 Answers
SOURCE: Water does not completely drain? Garbage disposal
heatman101
Posted on Jan 03, 2011
The dishwasher does not completely drain.
Hi
Thanks for using FixYa. Dishwasher not draining properly or not draining at all issues can arise due to different reasons. Usually, these issues are related to kinked hoses, knocked out disposer unit (if connected with the dishwasher drain hose) & clogged drain pump & filter. Also note that dishwashers do not drain completely after a finished cycle and this is normal. Dishwashers are designed to leave some water in the unit to ensure that the heating element doesn’t overheat. If you suddenly begin to experience a large amount of water being retained in your dishwasher, you have a problem. Some of the most common reasons include that the drain hose isn’t working properly, the drain pump isn’t working correctly, or possibly there is a plumbing problem in your home’s drain lines. First check whether the drain is not clogged or blocked and the line is not kinked. Check all the hoses for blockages & also clean the air gap. If you have checked the drain hose and can’t locate the problem, then it is an issue with the drain pump of the dishwasher. Please do rate the solution if the issue is resolved or post a comment for further assistance.
Thanks
Rylee
Jun 10, 2010 | Whirlpool 24 in. DP940PWP Free-standing...
Won't drain completely after a cycle is completed
HI. check the following areas for faults.
1. Air gap / Drain hoses
If there is an air gap (located in the sink, near the faucet), check to see if it is clogged. Unscrew the top cap and see if there is anything blocking inside. Note: If there is no air gap installed, the dishwasher might not drain properly.
If the drain hose is clogged, the dishwasher would not drain. If there is an air gap installed, it is very common that a hose going from the air gap into the garbage disposer is clogged. Remove and clean the hose. Make sure to reattach the hose before starting the dishwasher.
Note: If you recently had a garbage disposer installed, it is common to overlook removing the drain plug.
2. Broken belt
Some dishwasher models use a belt to drive the pump. Replace the belt if found broken.
Note: Sometimes the belt would just come off the pump. Even though it might not be broken, it is recommended that you replace the belt, because it is probably too stretched out.
3. Pump
Some models have two impellers inside the pump - one, wash impeller, takes care of the wash cycles, the other, drain impeller, drains the water out. If the drain impeller is broken (broken blades, shaft), the dishwasher would not drain. Replace any broken pump components.
4. Drain solenoid
Some models (for example most GE dishwashers) use a drain solenoid to drain water out. Sometimes the solenoid gets stuck, preventing the water from draining out. Try to free up the solenoid. If unsuccessful, you might have to replace the pump assembly.
5. Motor
If the motor is stuck, it is sometimes possible to free it up by manually spinning the motor.
Replace the motor if defective.
6. Timer/control
Replace if defective (note: uncommon problem).
Aug 31, 2009 | Whirlpool Dishwashers
Maytag dishwasher doesn't completely drain!
First check to see if anything has gotten into the sump drain inside the bottom of the dishwasher tub. Sometimes a piece of plastic wrap, or other small item can become lodged there, causing the DW to drain slowly.
If nothing there, check the air-gap device at the sink, as these can become clogged over time and that would also prevent proper draining. The air-gap is the round (usually silver chrome colored) cap mounted on the corner of the sink). Pull off the cap, it comes straight up with a little twist and polling motion. Clean out the screen filter and also look down the hose to see if there are any obstructions in the drain hose.
If that is OK, check the drain hose from the air-gap down to the connection at the sink drain, or if you have a disposal, where it is connected to the disposal. Sometimes small bits of stuff can get stuck in the hose at these various points and any build up over time, will make proper draining difficult.
You can also flush the drain lines with hot water to make sure the lines are clear. If none of this works, you could have something in the DW sump pump and that will require removing the DW from under the counter and checking the pump area for obstructions. Sometimes you can easily remove the flexible pump body and get at the drain valves. Just be sure to disconnect the power and turn off the water supply before removing the DW to attempt any repairs.
Hope you find this Very Helpful and best regards!
Aug 28, 2009 | Whirlpool GU2400XTP Built-in Dishwasher
The G638 finished its cycle but didn't completely
pump maybe on it's way out, though i doubt it, is the washing machine on the same drain out? if so you may have back wash, another could be lengh of drain hose, i had the same problem with my miele dishwasher because of the position in the kitchen i doubled up the drain hose and though it pumped out fine, with the volume of water left in the hose it came back in untill i repositioned the drain hose so it could't run back, hope this helps.
Aug 03, 2009 | Miele 24 in. G638 Plus Free-standing...
Whirlpool dishwasher is not fully draining after cycle complete
THE PROBLEM SOUNDS TO BE WITH THE INSTALLATION OF THE DISHWASHER ITSELF. YOU NEED TO MAKE SURE YOUR DRAIN HOSE IS NOT KINKED AND ALSO THAT THE DRAIN HOSE FORMS A LOOP. IN OTHER WORDS IT SHOULD GO STRAIGHT UP BEHIND THE UNIT AND THEN DOWN INTO THE SINK OR DISPOSAL.THIS SHOULD TAKE CARE OF YOUR PROBLEM.
Apr 07, 2009 | Dishwashers
Seem like its not draining. soapy water when finished cycle.
found a kink in the drain hose, shortened hose-problem solved.
Mar 22, 2009 | Dishwashers
Water standing in bottom of dishwasher,after wash cycle is finished? This is a Kenmore model 665.1565591
My problem too recently.
I blew compressed air back through the drain line and let it bubble up in the standing water in the dishwasher. Then I put it through another cycle and everything was fine. Something must have gotten clogged and the air blew it out.
Mar 19, 2009 | Kenmore Dishwashers
Standing water in my kenmore dishwasher after complete cycle
heatman101
z
Jan 04, 2009 | Whirlpool 24 in. DU1100XTP Built-in...
Kitchenaid dishwasher - water standing at end of cycle
less than 2 cups of water in left after cycle complete
Dec 02, 2007 | Siemens 24 in. SE25A266 ExtraKlasse...
Dishwasher does not complete cycle
It could be a clogged in the drain line. Often the problem is at the point where the drain line attaches to the garbage disposer or household drain line. You should remove this line and clear it form any debris in the hose or the hose connection. Be sure to reattach the hose before starting the dishwasher again. Good luck!
Sep 09, 2007 | Miele 24 in. G638 Plus Free-standing...
Dishwashers Logo
158 people viewed this question
Top Dishwashers Experts
