Question about Dodge Vehicle Parts & Accessories
Transmission filter and fluid change - Dodge Vehicle Parts & Accessories
    Sergeant:
  • 406 Answers
  • If your looking to just change the filter and oil in the trans you can buy a kit and do it yourself, not all that hard but can be messy. Got to drain and drop the pan.but you will not be changing out the majority of the oil.much of it still remains torque converter so if you want to get a complete oil change go to a transmission specialist they have equipment to take it all out and replace with new..
Posted on Oct 03, 2014
Mitsubishi express van 2.4 auto not changing into 4th gear. Any ideas?
If it's hesitant to shift, or not shifting at all, it could be a simple fix.
The first thing you'll have to do is to check the transmission fluid. Allow your van time to completely warm up before doing this. I recommend you do this while it is running. If it is low on fluid, there's your problem. If the fluid level is okay, then you may need the transmission filter and fluid both changed. Changing you fluid/filter is relatively simple. It's similar to an oil change with the exception being that the filter is inside the transmission, visible only when you remove the transmission pan. The filter isn't like an oil filter, it's more akin to your filter on your home A/C unit. Some have a replaceable filter, and some have a permanent filter that you'll have to remove and clean before re-installing. If you do need to replace it, they are inexpensive and found at any auto parts store. If it's still giving you problems, unfortunately it may be an internal problem that you'll have to take to a transmission specialist. Make sure to find out exactly how much fluid it holds and what type of transmission fluid it needs before you change it.
Oct 15, 2016 | Mitsubishi Cars & Trucks
How to change my 2006 Lincoln zephyr transmission filter
2006 Lincoln zephyr transmission filter Paul, Check the attached links,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
Ford Transmission Tips 3 Recommended Fluid Change Intervals Examples
How To Service Change Transmission Fluid and Filter Ford Focus
Ford Fusion Transmission Fluid and Filter
Jul 02, 2016 | Lincoln Cars & Trucks
I have a1997 accent1.5 auto trans it do not want to drive when fluid get warm but rev.pulls better
Check fluid level and condition. If it smells burnt or is not a healthy red, then do change the fluid and filter. If it still does not work properly after the fluid and filter change, you will need to have the transmission looked at by a good transmission shop.
Feb 03, 2015 | 1997 Hyundai Accent
Locate transmission filter on 2002 ford escape
The '02 Ford Escape doesn't have a transmission (automatic or manual transaxle) fluid filter or even a fluid pan to house one. The transmission is mounted between the drive axle and intermediate axle, directly below the yellow transmission fluid dipstick. No need to mess with it. Change your trans. fluid at the regular specified mileage. If the fluid on the dipstick is clear, it's good. If reddish or rusty or dark, change asap.
Jun 01, 2014 | 2002 Ford Escape
Transmission filter
as long as fluid is changed it is up to you! if no problems, it is not necessary to change filter. but if shift problems change filter as well as the fluid.
Apr 03, 2014 | 2009 GMC Acadia
While i was doing off road driving a warnning light (a/t oil temp) turn on, i looked underneath the car and i found oil leak drop after drop, not too sure now should I change the transmition oil and filter...
Change the transmission fluid and filter. The light says fluid temp. is high, so you may have some burnt fluid-deadly for transmissions. Drop the trans. pan and look for metal shavings-too much will indicate failure of transmission parts. If not too much, you may be alright with fluid and filter change.
Stop the leak,. make sure it is trans. fluid, not motor oil. If motor oil, stop the leak and change oil and filter. I would do the transmission regardless, since the light came on.
Aug 29, 2013 | Cars & Trucks
Transmission slips in d &od with steam in cab
transmission slipping could be low transmission fluid level or need a transmission fluid and filter change.if transmission fluid was real low check for transmission fluid leaks around transmission oil pan gasket or fluid leaks around cooler lines or torque converter shaft seal. if you getting steam inside cab.your heater core is leaking.if transmission fluid level okay and filter been changed could have faulty over drive switch.
Dec 18, 2012 | 1998 Chevrolet Blazer
The transmission seems to slip when going in reverse in my Ford Explorer 1994 (OK going forward). Transmission fluid is OK.
have one myself w/over 400.000 miles suggest you change transmission fluid and filter,just add lucas transmission treatment to your fluid change. never had problems w.mine. but firm beleiver in lucas oil and transmission and fuel treatments. just trying to see how far i can go w/mine. the lucas treatment added to your fluid and transmission fluid and filter change frees up stuck valves in the transmission. sounds alot like you may have a stuck valve body in the transmission to me.pull your transmission fluid dip stick,this is going to sound strange but go with me for a second please, does the fluid smell burnt? do'nt be scared to put it on your finger and sniff it. if it smells like burnt expletitive,then it needs replaced and filter too. just please add lucas transmission treatment to your fluid change,you will not regret it. the treatment [lucas] will cost an extra $11.00 onto the fluid change,trust me, you will not regret it!fluid changes are a must for ford explorers 4x4 don't know why,but they demand baby formula. lucas,i've found is that formula. thank you for choosing fixya.com we are here 24/7 for you 7days
Jan 13, 2011 | Ford Explorer Sport Cars & Trucks
My tranny slips some times but it will catch after a few min
SOUND LIKE TRANSMISSION FLUID LOW OR YOU NEED A TRANSMISSION FLUID AND FILTER CHANGE.THE 4T40E OR 4T45E IF YOU DONT SEE TRANSMISSION DIP STICK.BEST TO DO A FILTER AND FLUID CHANGE.YOU NEED 7 QUARTS OF TRANSMISSION FLUID A NEW TRANSMISSION FILTER AND PAN GASKET.I WOULD BUY FILTER AND PAN GASKET AT DEALERSHIP.YOU NEED A LARGE DRAIN PAN TO CATCH TRANSMISSION FLUID.IF YOU HAVE A TRANSMISSION DIP STICK. BEFORE YOU FIRST BEFORE STARTING THE ENGINE CHECK TRANSMISSION FLUID LEVEL ON DIP STICK.SHOULD BE ON THE FULL MARK.IF NOT ADD FLUID TO FULL MARK.THEN CRANK VECHICLE LET IDLE UNTIL ENGINE HOT OPERATION TEMPERATURE ABOUT 10 MINUTES.THEN APPLY BRAKE PEDAL.THEN SLOWLY SHIFT TRANSMISSION SHIFTER THROUGH ALL GEARS 2 TIMES.THEN PUT TRANSMISSION IN PARK.CHECK TRANSMISSION FLUID LEVEL.IF NOT AT FULL MARK ADD TRANSMISSION FLUID UNTIL LEVEL CORRECT.
Nov 13, 2010 | 1999 Oldsmobile Alero
Transmission fluid change intervals
Ya but if nissan planted filter's in there tansmission's then they would grow,right?NISSAN does not install filter's in the tran's.It is a permanent screen and luckily for people all I have to do is undo the plug from the pan and drain while hot, screw the screw the plug back in and funnel your new fluid back in to the tran from the dip stick tube(my 04 sentra 1.8s 4speed automatic takes 5 quart's but holds 6-type D nissan fluid from dealer,change about every 15 to 20 thousand miles to keep it clean and thin.Remember trans fluid is petroleum and get's hot burn's and thicken's making restriction's on rotating metal).My car has over 90,000miles and shift's perfect
Oct 14, 2008 | 2004 Nissan Sentra
Vehicle Parts & Accessories Logo
Top Dodge Vehicle Parts & Accessories Experts
Thomas Perkins
Thomas Perkins
Colin Stickland
Colin Stickland
Are you a Dodge Vehicle Part and Accessory Expert? Answer questions, earn points and help others
