Question about Spirit Esprit ET4 Treadmill
Motor gets Hot
After walking on the treadmill for about 25-30 minutes the Baldor Industrial Motor starts to heat up...by 40 minutes it is real hot (starts to smell)..walking speed approx 3.8 and tilt at 2..All other functions apprear to be working normally...I lifted the cover up to get more air circulation but this did not improve the heating problem...I have never oiled the machine...and have only used the treadmill "lightly over the years that I have owned it...What can I did to remedy this heating problem with the motor???
    New Friend:
  • 32 Answers
I'm not familiar with the treadmill specifically, but here is some general information that might be helpful. When a motor is under heavier load, it draws more current and therefore gets hotter. If for example, you were able to stop the motor shaft from rotating with an extreme load, it would draw what is called STALL CURRENT which is very high. So the problem seems to be that the load is out of specification. I'm assuming it would probably get hot if it was running with nobody on it as well. That would mean that the drive mechanism driven by the motor is not moving freely. If you can somehow decouple the motor from the treadmill drive system so that it has no load, and then move the mechanism by hand to see if it feels like there is a lot of resistance in the belts, pulleys or whatever drives the treadmill, then you need to lubricate to make it move smoothly. Or if you cannot decouple the motor, just look for all the bearings and pulleys and lubricate those but be careful not to get oil on drive belts or surfaces that require friction such as the surface of the belts or treadmill band. Don't ignore that the motor could get hot enough to start a fire so it is important to resolve this. It is possible that there are shorted windings and the motor is no longer good. If you can decouple the motor and run it no load, and it still gets hot, that would be an indication of such a shorted winding problem. Hope this is a little helpful. G
Posted on Feb 07, 2014
4 Suggested Answers
  • 192 Answers
SOURCE: Your Problem: Spirit Treadmill motor will not turn on
I'd start by attaching a voltmeter across the motor contacts to see if you get any voltage when the unit is turned on. It's probably an AC motor but I'd check the label to be sure. If you get voltage but no turning either the motor or a startup capacitor is bad. If this is the case try moving the tread by hand with the unit turned on. If it moves on it's own after you start it moving then the start up cap needs to be replaced. Otherwise it may be time to replace the motor. If you don't have voltage across the motor contacts when the machine is turned on, I'd unplug the unit and trace the lines back from the motor to somewhere on the PC board. I'm guessing there's probably a relay on the PC board that controls the motor. I'd use an ohm meter to make sure the relay coil hasn't turned into an open circuit. Next I'd put a voltmeter across the relay coil, plug the unit back in, and turn the treadmill on and off several times. Ideally you should see the voltage across the relay coil go up and down as you turn the treadmill on and off. This voltage could be AC or DC depending on the type of relay used. If you get the proper voltage across the coil but the relay contacts aren’t' opening and closing to provide power to the motor then you need to replace the relay. If you don't get the proper voltage across the relay coil the problem is further back on the PC board.
Posted on May 15, 2009
  • 33 Answers
SOURCE: Belt won't turn.
HI, please replace the control board
Posted on Oct 02, 2009
SOURCE: I have a Spirit SR-918
We also have a Spirit SR 918. It may be the lower or upper boards powering the motor that malfunctioned.
We need a particular part replaced on it, other than those boards, so if you still have not trashed the unit, have replaced it, or are thinking about disposing of the unit, we will pick it up. We are in Chicago, as well.
It will cost us between $125 to $499 to replace our treadmill, but it is so heavy duty, that it comes down to finding the parts, since additional labor will come out even.
Posted on Dec 31, 2010
Why treadclimber shuts down Level 1, 2.5 mph in treadmill position
Will be 4 reasons;
1) Drive belt too tight loose the bolts motor, until deflection
1/8"
2) Too tight the walking belt, How To Adjust Treadmill Belt
3) Lube the walking belt with WD-40 with slight Maintenance Lubricating the Walking Belt
4) Controller board motor defective.
Blessing
cuadra2016@yandex.com
whatsApp:+50588611441
Oct 31, 2017 | Exercise & Fitness
I have a 995 sel treadmill.so im walking on the treadmill for a few minutes and all of a sudden it stops working.then i get off the treadmill and the treadmill starts working just fine, i go back on it, it...
1) Well examine the Lube of walking belt, DO it if you are NOT, must be every 40 hours of training. VERY IMPORTANT.
2) see if the Walking belt is tight? Normailly you must Lift with his finger 2-3" of Hight, IF NOT see Video. How To Adjust Treadmill Belt
The thermical relay tripped from the motor to due this problem.must wait for Normal condition, for elevated temperature.
3) See the drive belt of belt motor is tight, loose the Bolts motor and the deflectin will be 1/8" tight again bolts,
4) If after doing all the steps before,THE problem persist, Replace the Controller Board Motor.
Oct 24, 2017 | Exercise & Fitness
Treadmill gets a hot smell from motor after not being used for a while it is a hammer walk runner rpe
the motor could be overheating, you might contact the manufacturer and tell them about the hot smell
Mar 09, 2016 | Hammer Walkrunner Rpe Treadmill
It's over heating, have lubed the belt, taken the cover off and put cold air through the motor. at a loss as to how to fix this.
Most likely the vents on the motor are blocked with dust, etc. Turn off the power and have a good look at the motor. You may need to disassemble it to clean it properly. It may or may not fix the issue, if its really bad the bearings could be seizing up. You can tell that by testing when you have it apart. You may be able to replace the bearings for only a few bucks. If you need to replace them take them off intact if possible and take them to a local industrial supply outlet, they can usually match them up for you.
Mar 19, 2015 | Horizon CT 5.0 Treadmill Walking Belt
Treadmill stops but has power
the motor could be going bad or the control board.if you are able to remove the drive belt off the motor and then run it. this will determine the motor or board from the walking belt or other items being bad.the motor should not be too hot to the touch
Apr 17, 2014 | Nordic Track Exercise & Fitness
Spirit treadmill st200
That machine is way too old to put any money into it. The fix for that particular problem is to replace the deck and belt.
Oct 21, 2017 | Exercise & Fitness
Inconsistent Speeds and Motor Smell
A new treadmill is in order! It sounds like the motor is either old, or it has a factory default. Definitely do not use the treadmill if it produces burning smells this is in fact the wires in the motor heating up and melting this could cause a fire.
Jan 23, 2014 | Advanced Fitness Group AFG 1.0 AT Folding...
Spirit Esprit ET4 Treadmill Logo
151 people viewed this question
Top Spirit Exercise & Fitness Experts
Mister G
Mister G
Level 1 Expert
Richard Warren
Richard Warren
Treadmill Repair...
Treadmill Repair...
Are you a Spirit Exercise and Fitnes Expert? Answer questions, earn points and help others
