Magicolor 1600w Printer leaves a very light black vertical haze on each sheet, that's slightly darker on the top of the sheet. The Remote_Panel shows that all toner cartridges are 87% or more, and they've all been refilled once. The imaging cartridge is at 90%. When I click "P/H Cleanup," it says the message has been sent, but nothing seems to happen. Do I need to replace a part, or clean something? Thanks in advance!
SOURCE: Cartridge advancement to replace toner
It's done via the printers internal menu system: On your Menu Select button press the arrow down once, then press the right or left arrow until it displays Menu Engine, then press down arrow again, then arrow right or left until it displays Engine Replace Toner (not Engine change toner SZ), then arrow down again, then arrow right/left till it shows the toner color you need to change, then hit the Menu Select button in the middle. The cartridges rotate until the one you selected appears, open the door and voila!
Posted on May 09, 2007
Nicolomd
  • 84 Answers
SOURCE: toner end life
it is printing with this blinking or not?
Posted on Jan 04, 2008
  • 214 Answers
SOURCE: Magicolor 2430 DL vertical white blank stripes
remove PC drum and under that you can see laser glass, clean it and reinstall.
Posted on Sep 17, 2008
rylee_smith
  • 8619 Answers
SOURCE: Brother 4070 Printer will not recognize new toner cartridge
Hi
Just cover the eyes (on both sides) that you can see in the bottom of the machine after removing the imaging cartrige with a small piece of electrical tape.
With printer switched on push the switch which is located inside the upper left side of printer (it is a small white switch) and then release it.
Also try resetting the gear, take the cartridge out. On the gear side take off 2 screws, the black gear on top right side, with a small spring underneath. Just take it off and reset it (rotate clockwise) so it is not at the stopping point.
Please do accept this solution and revert for further assistance.
Thanks
Rylee
Posted on Apr 20, 2009
  • 192 Answers
SOURCE: After replacing black toner cartridge printer displays Drum Low
Ask you companey that surives you printer to look at it
Posted on May 20, 2009
How do I get to a paper jam on my Minolta 1600w magicolor?
will require a tech
How did the tissue paper get in there had to ask:)
Feb 02, 2014 | Konica Minolta Magicolor 1600W Laser...
How do you calibrate a Konica Minolta Magicolor 3300 printer?
More then likely the Cyan Image unit needs to be replaced
Oct 25, 2012 | Minolta Magicolor 3300 Color Printer
Hi, My Magicolor 1600W ran out of the starter black toner, but when I tried to change the cartridge, it did not auto rotate to the black cartridge. I tried to push the rotate button a few times, opened...
Hi Steve.
There should be an 800 number in your manual that you can call and talk to technical support. They should be able to help you over the phone... You may have to press certain buttons to reset it. Hope this helps.
May 26, 2017 | Konica Minolta Magicolor 1600W Laser...
How can u resolve all lights blinking on minolta konica magicolor 1600w
Unplug from PC, unplug from wall, leave unplugged for say 5 mins, and then plug back into the Wall, then, reboot PC, then plug into PC. Now should be OK. If NOT please use the manual below to troubleshoot whats wrong.
http://kmbs.konicaminolta.us/content/products/models/magicolor1600W.html
Apr 28, 2010 | Konica Minolta Magicolor 1600W Printer
My new Magicolor 1600w Printer hasthe toner light
Probably. Most color images have some black in them as well.
Aug 09, 2009 | Office Equipment & Supplies
23 people viewed this question
jasbo
jasbo
