Question about LG Televison & Video
LG flatron M2762D TV does not turn on no sytand by.
This tv does not turn the problem is in the power supply but I can not find a wiring diagram of the power supply model is PLLM-M901D. Hopefully puediesen help me solve this problem. Thank you.
epik559
  • 44 Answers
SOURCE: code number for sky remote
Call the manufactor of that remote and ask for Funai remote codes.
Posted on Jan 03, 2008
freetek
  • 5568 Answers
SOURCE: tv will not power up
If it's failing to turn on, the main power supply is probably at fault and without some technical background and a couple of test instruments, you will not be able to do the repair yourself.
What you can do though is; unplug the set, let it stand overnight or at least several hours, remove the back panel and look for a separate board with mostly larger components on it; it will have a ferrite core (no laminations as with a line-frequency part) transformer on it and several larger capacitors which are cylindrical and mounted vertically to the board.
Before touching anything inside, especially on that board, allow several hours to be safe since the larger capacitors can hold a painful voltage charge for some hours.
If you see signs of overheating such as discoloration of the board material, it may not be repairable but if you can find a part number on the board, you might be able to buy the power supply and install it yourself but it will likely have the same problem eventually unless they have altered the design.
If there are no signs of heat damage to the board, there may be companies offering to repair it as a subassembly instead of repairing the whole set which could be much more expensive.
If you choose to replace or have it done, the power supply still may not be at fault since most are capable of switching on and off if a downstream problem is causing an overload.
Posted on Mar 30, 2009
SOURCE: LG 26lx1d tv will not turn on. Power supply is
Have an LG26Lx1D for about 3 years, dropped off by my son.(Figures).Power light just blinking, but went back to red.Removed back panel, and metal cover. Just above antenna/cable input, its a small fan,mine was full of dirt. Blow off dirt, and make sure its turning freely.
Install back the covers, an voila....its a miracle...its working again.
Good luck
Posted on Mar 21, 2010
SOURCE: power supply for lg plasma tv
i have a 60 inch tv i just order the power supply kit i want to install it myself do i have to open the whole back of the tv.
Posted on Jul 08, 2010
dbTVfixer
  • 79 Answers
SOURCE: LG 32LH2000 My TV was turned of last night in the
most LG have a "vacation switch" on the bottom right hand side of the set very near that standby light.
it is placed poorly, where you can accidently click when grabbing the TV to move it or swivel it.
it is a toggle switch, a "master power" switch.
you may have bumped it to the off position. flip the switch, your standby light will come back on.
Posted on Apr 16, 2011
My Hyundai tv 74 cm The color it not show good
Nice big screen but CRTs are getting old So, if you can't set correct colors with your Hyundai it might have some serious issue with tube. Probably replacement might cost you more then a new new 27" Flat Panel. See some tutorial and info about bad color of CRT
Fix your own CRT Television Color Problem
How To Diagnose Bad CRT or LCD Monitor
http://www.electronicrepairguide.com/monitor-color-problem.html
LG M2762D 27 Inch Widescreen 1080p LCD TV Monitor Black
LG Electronics LG M2762D 27 FLATRON LCD TV widescreen 1080p FullHD HDTV...
RCA F27440 27 CRT TV
Samsung TXN 2798HF 27 Tantus CRT TV 1080i
Aug 02, 2015 | Televison & Video
Tv keeps turning off
Hi, It could be a problem with the power supply in the TV.
Take it to a repair shop. Good luck.
Aug 06, 2012 | LG Flatron L2320A 23" LCD Monitor
My lg 27 M2762D have black screen with normal sound, and after restarting tv ,screen is normal for while and return to black
Could you solve it? I have a similar issue
http://www.fixya.com/support/t19795450-lg_27_m2762d_black_screen_after_random
Jan 27, 2012 | LG M2762D 27 LCD TV
How can I get a free manual for lg tv model m2762d
You can download the instruction manual in PDF format by clicking this link.
Adobe PDF Reader is required to view this manual. Download Adobe Reader
Hope this helps. Thanks for using FixYa.
Jul 29, 2011 | LG M2762D 27 LCD TV
29" LG Flatron TV bought in 2007. On starting TV,
That kind of prolem is commonly caused by dried electrolytic capacitor on the low voltage power supply. Leaky capacitor affect the performance of the B+ once sense by the processor it will automatically shuts down the unit.
I've advice you to send it to qualified service center to isolate the problem because oscillator is also going to check for normal operation. This is quite technical and not DIY.
Thanks for using fixya.
Please rate my help.
Jan 17, 2011 | LG Televison & Video
Turned my tv off last night and then when i tried
power supply has blown. you need to replace the bad capacitors on it. common problem
Jan 01, 2010 | LG Flatron L1951S-SN 19" LCD Flat Panel...
Televison & Video Logo
97 people viewed this question
Computer Repairing
Computer Repairing
