No lights working on delonghi sospiri electric fire
Delonghi radiator
Is it plugged in? is the electrical outlet working properly?
Jan 27, 2014 | DeLonghi KH190715 Oil Filled Radiator...
I have a delonghi Beta90ss rangehood (No. 0238). Fan and lights not working but indicators light up. Any idea if this problem can be fixed please ? Some electrical repair people say on the phone that...
The DeLonghi model's problem appears to be the same as the Parex one found here:
http://www.fixya.com/support/t9437177-parex_beta_90_ss_rangehood. Solution is described therein.
Oct 26, 2010 | DeLonghi Kitchen Ranges
I have a Delonghi type Venice fireplace serial no 52013. Normally it has a nice flicker which goes up the back of the fire place and looks like a normal fire. Today the gentle flicker has turned to a very...
Did you fix it as I have a Delonghi Venice electric fire which has just stopped working for no reason? There is electricity going to the circuit board but nothibg is working. Could this be a faulty remote control?
Aug 28, 2010 | Heating & Cooling
Delonghi Metropolis Kettle
sounds like the element has gone in it. Contact a qualified repair person.
May 20, 2010 | DeLonghi KBM1511 Metropolis Cordless...
I have a elecric delonghi oven with a gas hob with 6 burners. the oven does not work at all no heat. the light comes on but no heat. the turkey is stuffed an no hat to cook it HELP PLEASE
if the temp indicator light comes on and/or oven fan circulates then its most likely the heating element. if neither then its thermostat or selector switch...
Dec 22, 2009 | DeLonghi DEBIGE 2440 Electric Double Oven
Delonghi Dragon Two, oil filled rad trips the main elec fuse
If it is tripping the breaker in the panel, there is a direct short in the heater. Scrap it before it causes a fire. Seriusly
Oct 24, 2009 | DeLonghi 6707E Oil Filled Radiator Heater
DeLonghi Debige 2440 Electric/Gas Double Oven Fan Failure Light
I had the very same problem. I slid the oven out of the wall about 6" or so, unplugged it, plugged it back in. It worked. I'm not sure if I jostled some connection, or if unplugging/repluging it in reset some sort of circuit fault.
Feb 02, 2008 | DeLonghi DEBIGE 2440 Electric Double Oven
Re:Electric Convection oven does not heat up. Convection fan works, light works.
It is probably and electrical service issue. If this is a North American unit, it uses two electrical circuits to provide power. You must find and reset the breakers and check that the wiring is operating as intended. Less likely: It could also be a manufacturing defect. DeLonghi uses screw compression connections on some products. Sometimes, they don't work well.
Dec 20, 2007 | DeLonghi DEBIGE 2440 Electric Double Oven
Electrics not working
sounds like the board on the b ack where the main cable goes in,this happend to mine,very cheap to fix
Nov 03, 2007 | DeLonghi DEFSGG36-SS Gas Kitchen Range
Heating & Cooling Logo
Top Heating & Cooling Experts
Paul Carew
Tim Whalen
