Question about Craftsman Arnold Mtd Snow Thrower Blower Light Easy Mount
30 in craftsman snow thrower,model no.247.883960,pulls right contionusly while operating in any gear
The snow thrower drifts to the right contiously in any gear when blowing snow.i have to keep pulling the left triger to try to keep the snowblower straight. is there an adjustment not mentioned in the manuel to solve this problem?
    Master:
  • Craftsman Master
  • 428 Answers
Howdie ther is a Pin in the shaft of the wheels look to see if it is Broken and away ya go it is easy to see
Posted on Oct 16, 2014
4 Suggested Answers
  • 417 Answers
SOURCE: craftsman 32" 10 hp snow thrower
Around the back of the engine, just below the cylinder cooling fins. The shut off should face you if standing in front of the recoil starter, for the fuel tank. The fuel line should wrap around I the side of the carb and be protected by the metal cover surrounding it.
Posted on Nov 22, 2013
  • 155 Answers
SOURCE: I just bought a Sears snow thrower, I put in oil and gas went to start it but the pull cord will not pull up. I then tried the electric starter but it just made a grinding sound. Why won t it start?
Check the crankcase and make sure it has oil. It sounds like the engine is frozen. If its brand new, take it back to Sears and have them start it for you.
Posted on Dec 16, 2013
  • 451 Answers
SOURCE: Craftmans Snow Thrower 247887001 Tire Flat. How to Refill.
The tires are probably tubeless type. If the bead is broken ( not sealed to the rim) the tire will not inflate. Taking the weight off the tire will some times allow the bead to seal against the rim and allow tire to be inflated. You can also put a small ratchet strap around the tread of the tire and tighten it up. This will squash the tire and make the bead seal up. MAKE SURE to loosen strap as soon as bead seals and tire begins to inflate. Hope this helps.
Posted on Jan 01, 2014
Can I use 0w 20 Mobil 1 oil in my snow blower
It can be used, although the manufacturer recommends;
Super S 5W-30 Snow Thrower Engine Oil - Sears
www.sears.com/explorer-5w...snow-thrower...oil/p-07188298000P
Sears Rating: 4.5 - ‎5 votes
Oct 21, 2010 - Explorer 5W-30 snow thrower engine oil is a premium formulation for use in all four cycle engines when temperatures are below 32 deg. F. Explorer 5W-30 snow thrower engine oil protects the engine by lubrication, cooling, cleaning and sealing internal moving parts.
Aug 23, 2015 | Craftsman Snow Blower / Snowblower Bottom...
Manual for sears snow thrower 536.886621
They are basic what do you need to Find in the Manual?
Feb 12, 2014 | Craftsman Sears Snow Thrower Manual Model...
30 in. craftsman snow thrower,model no. 247.883960,pulls to the right
If your blower uses the two wheels to drive which I think it does I would suggest that you have a shear pin on the right side that is broken. If that is the case you will have to pull the wheel off and replace the shear pin. You can tell if it's broken by lifting the right side and trying to turn the wheel by hand.If it turns easily its broken.
This is an idea only. You might want to check both wheels as I'm not sure as far as the steering is concerned.
Feb 07, 2014 | Craftsman 30 In 357cc* Dual-Stage...
Craftsman 30 in. snow thrower,model no. 247.883960
check the pin that hold s the wheel on
I think its the right side that has two holes
be sure the pin is in the rim and axle
Feb 07, 2014 | Garden
Auger does not engage on Ariens Model 924121 sno- Thro
first check shear pins in the auger ( try to turn big auger by hand, engine off)
then if they are good then try to turn impeller by hand, engine off
youll need to turn it a few times before the larger ones turn, but thats what you want
if they dont turn then you have sheared the gear box gears
be sure belts are good tooo
Dec 15, 2013 | Ariens Snow Blower. Sno-Thro Deluxe Drift...
Where is the throttle on a craftsman 536.881800 snow thrower?
Manual is available at http://www.searspartsdirect.com/partsdirect/part-model/Craftsman-Parts/Snow-removal-equipment-Parts/user-manuals/manual-downloads/Model-536881800/0247/1507200?modelNumber=536881800&diagramPageId=&documentId=
Dec 14, 2013 | Craftsman Sears Snow Thrower Manual Model...
Craftsman 32" 10 hp
3600+/- 20rpm. That's the top end, I'd say idle should be between 1200 and 1500, but I don't know what model motor it is. I'm assuming its a Tecumseh snow king engine
Nov 22, 2013 | Craftsman Arnold Mtd Snow Thrower Blower...
Auger shaft jamed
Try removing the belt and turning it by hand. If that doesn't work, you may have blown something into bits inside of the gear case.
Nov 03, 2013 | Ariens Snow Blower. Sno-Thro Deluxe Drift...
Engine on 30"Craftsman 2009 snow thrower won't prime. Primer button and connecting tube look good. Primer button won't send gas to the carb.
the priming bubble can look totally perfect, but all it takes is a pin hole and right around the retaining ring is hard to spot a crack and you should also check fuel lines in tank
Jan 07, 2013 | managemylife.com
Will a Craftsman 42" model 486248392 snow thrower
it shooed fit with no problems but first check the crank shaft
to make sure they are the same size that's always ben the
problem trying to switch motors let me no if you need more
assistance
i hope this helps you
bob
Jun 07, 2011 | Craftsman Garden
Craftsman Arnold Mtd Snow Thrower Blower Light Easy Mount Logo
222 people viewed this question
Top Craftsman Garden Experts
Dean Gruber
Roland W VanLue
Roland W VanLue
Dennis Key
Dennis Key
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
