Question about Samsung DV422EWHDWR 7.2 Cu. Ft. Top Load Electric Dryer
How to switch my door to other side - Samsung DV422EWHDWR 7.2 Cu. Ft. Top Load Electric Dryer
Remove hinges and screws, lay door on floor and remove screws around the edge of door then turn exterior of door around so handle is on the side you want (make sure the shape of gasket that seals the door is correct so it closes)and put screws back on edge of door . Remove all rubber plugs on side you now want to install hinges on and place hinges there . Remove door latch and place it on opposite , that should do you .
Posted on Feb 07, 2014
Remove interior door panel 2002 Chevy tracker
No you don't need any special tool . Find all screws on out side of door trim panel and the window handle , the mirror cover plate , then just pull on edge of the panel .
Gently pry the front side door trim panel (3) from the front side door by disengaging the plastic retainers which secure the panel.
Position the door trim panel (3) away from the door in order to gain access to the front side window switch electrical connector, if equipped.
Disconnect the window switch electrical connector, if equipped.
Remove the door trim panel (3) from the vehicle.
Remove the front side window switch from the door trim panel (3) by releasing the 4 plastic retaining tabs, as needed.
Use a cloth in order to pull off the snap ring which secures the front side door window regulator handle (1), if equipped.
Remove the window regulator handle (1), if equipped.
Remove the front side master window switch, if equipped. Refer to Power Accessory Switch Panel Replacement .
Remove the front side door inside handle (1). Refer to Front Side Door Inside Handle Replacement .
Remove the outside rearview mirror opening cover (2).
Remove the screw which secures the front side door pull handle (4).
Removal Procedure
Remove the screw which secures the front side door inside handle (1).
Slide the inside handle (1) forward in order to release the retaining tabs which secure the handle to the door.
Open the front side door inside handle rod retainer and remove the front side door inside handle rod from the inside handle (1).
Remove the inside handle (1) from the vehicle.
Check out youtube video showing how to do it !
How To Remove Install Front Door Panel Suzuki XL 7
Jun 10, 2017 | Cars & Trucks
2000 vw jetta. driver's side door lock switch will unlock door, but not lock it. passenger side locks all doors properly
Your probably correct in that the drivers side door toggle is broken. Check a junk yard to get this piece cheaply. A Volkswagen dealer will be very expensive. Call around and give them the year,model and make of your vehicle to find a used part.
Apr 24, 2012 | 2005 Volkswagen Jetta
1998 Jeep Grand Cherokee Laredo TSI, Passenger side windows do not work from master switch on drivers door. Both driver side windows work from master switch on drivers side. Passenger side windows do work...
It has to be the switch or the wiring, right? So pull out the switch and probe the back with a volt meter to see if power is coming out of the switch. If yes, trace the wires to the doors.
Jun 30, 2017 | Jeep Grand Cherokee Cars & Trucks
How to repair the problem on Canon Laserclass 9000L "check printer cover" alarm.
There are 4 doors that will cause the error. There are 2 on the right side of the printer. If you look closely, there is a white plastic switch on the right side of the doors. The toner door has a black plastic switch on the left side. Then there is the fuser access door on the other side of the printer that has a switch on the left side. Check the doors don't have any broken actuators that hit the switches. Check the switches by pushing on them manually.
Apr 18, 2010 | Canon LaserClass 9000L Plain Paper Fax
Power door lock problem. Driver's door only unlocks with switch or FOB. Passenger door the unlock switch does nothing for all locks. I took the door lock assembly out of the driver's side and hooked it to...
the wires between the door and the pillar may have cracked and create the short. its from swinging the door open and closed position in time. Some will do this mainly on the right side for the harness is so tighter from being shorter that the left side is. I had seen this happen in many Chrysler vehicles
Jan 16, 2010 | Chrysler PT Cruiser Cars & Trucks
Power locks don't work with remote or control from
The door lock/unlock input from the driver's key switch goes to the Door Multiplex control unit (main switch), the Door multiplex control unit then sends a signal on the BUS (CAN) circuit to the passenger's multiplex control unit; the passenger's multiplex control unit then controls all the door locks. The passenger's door lock key switch inputs to the passenger's multiplex control unit, if the locks work from the passenger's side key switch but not the driver's side key switch, the most likely cause is the driver's multiplex control unit (main switch) not sending the signal to the passenger's side multiplex control unit. This could also be the drivers side door lock actuator. Hope this helps!
Jan 07, 2010 | 2003 Honda Pilot
1959 pontiac 2 door bonneville. how do you hook up the wiring for the dome light? two wires coming down from the light. driver side door switch has two terminals. pass side door switch has one terminal.???
Negative from the dome light to one terminal on the door jab,and the other terminal,hook to,and run to the other door jam on passengers side.The hot wire from the dome light goes to the hot side on the fuse box.A additional light switch can be installed,to turn the dome light on from inside the car,by running a ground to the switch,and from the switch to the ground side of the dome light.
Nov 13, 2009 | 1978 Pontiac Bonneville
1998 Ford Explorer - The Drivers Side Switch will not lock doors.
check the wiring going to the driver door switch. Check where it goes into the door and check for a pin push out in the door switch connector.
Oct 07, 2009 | 1998 Ford Explorer
Passenger side window won't roll up using the driver's side switc
Before you replace anything, inspect the connector pins in both the driver's door switch and the passenger door switch. If you don't find any problem with these connector pins, replace the driver's door control switch.
Aug 18, 2009 | 2003 Hyundai Tiburon
Samsung DV422EWHDWR 7.2 Cu. Ft. Top Load Electric Dryer Logo
63 people viewed this question
Top Samsung Dryers Experts
Tim Whalen
Dan Webster
Dan Webster
Are you a Samsung Dryer Expert? Answer questions, earn points and help others
