Question about Brother IntelliFax-2820 Laser Fax
Sleep error message on brother fax machine - Brother IntelliFax-2820 Laser Fax
  • 47 Answers
SOURCE: Brother Fax 4750 System error 76
try resetting the machine by pushing the features button, and then *2864 in quick succesion, if done correctly you will enter test mode, then enter 91, and then after that clears enter 99 to exit test mode. make a copy to see if it works, and if it doesn't it is time to replace the fixing assy.
Posted on May 12, 2008
alvinbga
  • 130 Answers
SOURCE: Brother Intellifax 1270E plain paper fax
It could be either. take the machine to anothewr line see if the
error goes away.If it does not call brother customer service. There is an adjustment for input sensitivity of so brother fax machines. It may be in your operators manual
Posted on Jun 11, 2008
  • 215 Answers
SOURCE: change toner error brother 2820 mach has new brother toner ctg
with machine on, open front cover, press the "options" button, you should see "replace drum?" press the "start" key then 1 then 0. display should show accepted for a couple of secs. then show cover open. close front cover and message should be gone. if not, you will have to contact Brother.
hth,
razors
Posted on Jan 28, 2009
BigdaddyTDW
  • 62 Answers
SOURCE: I can send but cannot recievefax. Fax is on SLEEP all the time.
The machine is set with the sleep mode as a default. The fax part can be changed to recieve a fax by pressing the fax mode button. Press it until it says Fax only, not F/T. F/T means Fax/Telephone. This mode would make it to where you have to pick up the reciever and press start when a fax comes in. The Fax only mode means it will pick up everytime a fax comes in automatically. Let me know if this was helpful. Please give my helping a rating. Thanks!
Posted on Feb 14, 2009
  • 46 Answers
SOURCE: Our Brother Fax Machine 2820 stays in sleep mode.
Machine goes into sleep mode when not being used When it recieves or you copy something it will come out of sleep mode If its not recieving then you need to check your recieving settings
Posted on Jun 11, 2009
Error Code 77 on brother 4100 fax intelifox business class
( 76 Heater harness disconnected or broken. Or heater thermistor harness
disconnected or broken when the power is turned on, the front cover is
opened and closed, or the machine exits from the sleep mode. )
( 77 Power turned off and on at the occurrence of error 76 or 78. )
( 78 Heater thermistor short-circuited. Or heater thermistor harness disconnected
or broken when the machine is on standby. )
Nov 05, 2010 | Brother IntelliFAX 4100 Laser Fax
What does it mean when the fax is in Sleep mode?
This means that is has gone into power reserve mode and is consuming less energy, however, the machine should still receive faxes without error. If you would like to change this setting, you can go into the options menu and turn sleep mode off.
-David.
Nov 02, 2010 | Brother Office Equipment & Supplies
Unable to clean 50 error
I have a Brother MFC-440CN fax machine and I am receiving error message "unable to clean 50". Can anyone help me to fix this error problem
Jan 13, 2010 | Brother Office Equipment & Supplies
Our Brother Fax Machine 2820 stays in sleep mode. How do we get it out of sleep mode?
Jun 10, 2009 | Brother IntelliFax-2820 Laser Fax
Fax machine sleep mode
have you tried to unplug the machine from the wall and then plug it back in this reboots the machine
Dec 23, 2008 | Brother IntelliFAX 2800 Laser Fax
BROTHER FAX MACHINE 2800
Your Brother machine#s Sleep Mode function reduces power consumption while the machine is idle. You can adjust how long your Brother machine is idle (between 00 and 99 minutes) before Sleep Mode is initiated. Please note that the default setting is 00 minutes, and the timer automatically resets itself after the Brother machine receives a fax,receives data from your PC, or makes a copy. To adjust your Brother machine#s Sleep Mode setting, please follow these steps:
1. Press MENU/SET, 1 (General Setup), 7 (Sleep Mode).
2. Use the dial pad to enter the amount of time the fax machine is idle before Sleep Mode is initiated (00 to 99 minutes).
3. Press the MENU/SET key to confirm your choice.
4. Press the STOP/EXIT key to exit the menu.
NOTE: If you frequently print, copy, or fax, set the idle time long
enough to insure that you will not always have to wait for the Brother machine to warm up.
Dec 02, 2008 | Brother IntelliFAX 2800 Laser Fax
Cannot receive faxes...... display on the message panel sleep MNL
The machine is set for manual (MNL) answering - hit "receive mode" until is says "fax only" or "Fax/tel" etc. depending on what mode you want the machine to work in again.
Just resolved the same problem on mine.
Patricia
Jan 03, 2008 | Brother IntelliFax-2820 Laser Fax
Brother intellifax 4100e
Hi, the error code refers to the heater thermistor short circuited or heater thermistor disconnected or broke when the power was turned on, front cover is open or closed or when the machine exits from sleep mode.I hope this help!!
Dec 04, 2007 | Brother IntelliFAX 4100 Laser Fax
Brother IntelliFax-2820 Laser Fax Logo
14 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Victorman
Victorman
