Question about SIB 300Mbps Wireless N USB Adapter (885480349791)
My dell d600 will not recognize sib 300mbps wireless n usb adapter
  • SIB Master
  • 3,320 Answers
SIB-usa is an ebay store not the product brand. Contact the ebay store and ask for a replacement or refund and get a real wireless adapter.
Posted on Mar 14, 2014
Driver
Need to download the driver for wireless 802.11g speedtouch 121g adapter
Jul 05, 2013 | Ultra Products Ultra U1240524 Wireless N...
Thanks to the experts in Fixya. I can now see the wireles in my school but can not connect to it because each time i try to connect it will write " WPA not supported by your wireless adapter, contact...
this usually means that your wireless network adapter is not compatible with WPA security. try updating your wireless driver and if that does not work, your option would be to purchase a wireless USB adapter that supports WPA. else, check with the network admin at your school for other options. hope this helps
Apr 23, 2011 | Dell Latitude D600 (D6005C) PC Notebook
I formated my Dell latitude D600 and installed windows vista. As a result, the wireless lan stopped working. I have tried running different drivers to re-instal the wireless yet it has refused to...
Dell does not provide Vista drivers for the D600 because it is too old.
(See: http://support.dell.com/support/downloads/driverslist.aspx?c=us&cs=04&l=en&s=bsd&os=WW1&osl=en&SystemID=LAT_PNT_PM_D600&catid=-1&impid=-1)
I see two options:
Purchase an add-on Vista-compatible wireless adapter (USB or PCMICIA).
Go back to XP. It will run better than Visa on the D600.
If this helps please vote for my solution.
Oct 05, 2010 | Dell Latitude D600 Intel Pentium M 1.3GHz...
I require a wireless adaptor for a dell latitude
Hello
Youhave 2 options, you can either buy a internal wireless card for yur notebook, or you can buy wireless USB adapter.
I baught a wireless USB adapter, and i would recomend it to anyone. It is portable, easy to use and much cheaper.
Click on the link below and it will direct you to a page where you can have a look at the different options.
http://mobileoffice.about.com/od/laptopaccessories/tp/laptopcards.htm
Hope this can help.
Kind regards
Andrea
Nov 09, 2009 | Dell Latitude D600 Notebook
My dell latitude d600 is not recognizing any wireless connections. I believe the switch is at top of the keyboard and it doesn't seem to be working. Any advice
if it is not seeing any wireless networks, the wireless card may be defective, try having it tested, or check the device manager to make sure the drivers are installed correctly for the wireless network adapter
Jun 27, 2009 | Dell Latitude D600 Notebook
Can't recognize the wireless router
Here's a few things you can try:
1. You should see the wireless icon in the system tray, bottom right of screen (tiny computer with rays to the right of it)
2. Try the correct wireless function key: hold down Fn key and press the F key with wireless mast picture on it. (possible F4 or F8). This will turn on and off the wireless card.
3. Check if wireless card is installed in Device manager as follows:
click on Start, Control Panel, Performance and Maintenance, select System, then Hardware Tab. Click on Device Manager.
Expand "Network Adapters". You should see a wireless card listed. If not, you've installed the wrong wireless driver...
Uninstall the one you installed and look for the correct one on Dell site.
Jan 05, 2009 | Dell Latitude D600 Notebook
Dell D600 - Linksys wireless router/adapter
Seems there is a problem with the Linksys since there is not any lights coming on. Did you plug it into a switched outlet in the wall? Does it work if you plug the Linksys into an outlet in another room?
If you can get it to light up, the way you will access it is through your web browser. Type in 192.168.1.1 into your web browser and a login in screen should pop up.
Apr 28, 2008 | Dell Latitude D600 Notebook
Latitude D600 Network problem
unplug roughter then back in after 1 min and modem ok then rebooot give it a min
Jan 20, 2008 | Dell Latitude D600 Notebook
Wireless card not recognized
Make sure you are using the latest driver and software for the card. If you haven't already done so, I would also suggest trying the card in another computer, and a known good card in your D600, to see if the problem stays with your computer or follows the card. If it follows the card to another computer then it is most likely a problem with the card itself. If other known good cards also fail in your D600 it might be something with the D600 card slot. If the slot is the problem then I would recommend contacting Dell tech support. Larry Dell Customer Advocate
Apr 11, 2007 | Dell Latitude D600 Notebook
SIB 300Mbps Wireless N USB Adapter (885480349791) Logo
69 people viewed this question
Top SIB Computers & Internet Experts
Piyal Perera
Piyal Perera
Bios Pro
Raj Patel
Are you a SIB Computer and Internet Expert? Answer questions, earn points and help others
