Sony mhc vx77
Where can i get the main board for sony MHC-VX77??
SOURCE: Erratic CD tray behavior on SONY MHC-881 Shelf system
change cd head
Posted on Nov 27, 2007
SOURCE: Sony MHC-2800 setting the clock
Hi, it's simple. First press "Timer1" and Timer2" buttons together, clock on display will start blinking, by cursors "Up/Down" you can change the value of hours and minutes (switching between hours/minutes by "Left/Right" cursor). To save set time press "Memory". Enjoy your set clock :)
Posted on Jan 30, 2008
  • 12 Answers
SOURCE: My Stereo Is Always On Protect Can It Be Easily Fixed
Protect occurs when 1 or more of your speaker wires is touching somewhere. Power off the receiver, connect speaker wires to receiver and speakers again, power back on, should fix the issue.
Posted on May 28, 2009
smarthome2
  • 1114 Answers
SOURCE: dvd not playing.c 31 00 occur
The only thing you can do is get a CD DVD player cleaner with liquid. Found at any store these days, then run it a couple times. If it plays, Problem solved, if not, it must be repaired. They will put a new transport in the unit. Usually runs 100-150 to replace. Weigh the cost to fix vs. the cost to replace and the age of the unit before you get it repaired. Hope this helps
Posted on Jun 02, 2009
SOURCE: sony mhc-rg330
Get a lens Cleaning Disk and put it into the CD Player, there could be foreign objects on the lens itself, these and other shelf systems all have one common problem... Dust.
jon
Posted on Aug 12, 2009
Hi, I have a question about the Hi-Fi System of Sony "MHC EC55"... Since 3 days the EQ options toggle by themselve without pushing the EQ button. How can I Set them. thanks for ur help
There are two possible explanations that come to mind. First there is a fault on IC that controls the tone control and EQ that makes it switch them randomly.
The other option is that stored settings are being lost due to either an internal battery failure, or a faulty memory retention capacitor. The last one stores an electric charge to keep a Memory chip in operation, when the main power is off. They are small electrolytic capacitors, with a small UF value, plus under 6 volts. An image of one is below. If you find one of these on an area of the circuit board that deals with the tone controls replace it.
Nov 05, 2016 | Sony MHC-EC55 Shelf System
How do I remove the 5 way ribbon and 7 way cable from the main amp module of my mini hifi?
That unit looks like an economy model that is mass produced. It would probably not have quick connects on the boards. You are going to have to use a soldering iron.
Jun 27, 2014 | Audio Players & Recorders
Sony stereo mhc-gx9900 audio doesnt come out of speaker thou all lights show its playing
There is a intermittent problem on the main board, or the headphone jack is dirty or worn contacts, buy electronic cleaner, spray into headphone jack or earphone jack, slide headphone jack in and out as you spray the contact cleaner, do this several times in a attempt to restore audio.
Apr 06, 2012 | Sony MHC-GX9900 Shelf System
Stand by light just keeps on flashing red and i cant press any otehr buttons it just keeps flashing red
something inside the unit has caused it to go on protect mode it sounds. check the v supply from the fan as well as the audio output ic and main pc board.
Jul 05, 2009 | Sony MHC-GX555 Mini Hi-Fi System Shelf...
How do I connect ipod to sony MHC GX450? can i hook my ipod to my sony mhc-gx450
yes you can connect using rca phone jack to rca jack it depend on what cable you use from your ipod. connect from your ipod audio output to auxillary of sony mhc-gx450.
May 31, 2009 | Sony MHC-GX450 CD Shelf System
Standby led sony MHC-GNZ888D blinking (intermitent)
power amp.or power supply printed circuit board.
nuwan.
Jan 13, 2009 | Sony MHC-G100 Shelf System
14 people viewed this question
 Grubhead
Grubhead
