Question about D-Link DI-707P Router (DSDLDI707P)
DI 707P router stops working.
Several times each day my DI 707P router stops working. The lights all appear to be working except for the M2.
I unplug, and then plug back in the power cord to the wall outlet, and all is well. The M2 light comes on.
I suspected the power source was the problem and tried APC battery back- ups and suge protection, but still the same problem.
  • patty_boy Oct 29, 2007
    I should of mentioned that the system used is a Direct-way satelite. Thw router is plugged in to the Hughes net 7000 system's box (the box with all the pretty blue lights). The firmware is version August 2004.
    Thanks for trying anyway - Patty-boy
    Problem Solver:
  • 22 Answers
I'm not sure about your Router whether you use it for Cable or DSL.
If you use it for cable, unscrew the coaxial cable and do factory defaults your router and re-plug the coaxial.
- if it is DSL, isolate the filter/spliter and connect the phone cable directly from the walljack to the router and do factory defaults the device. re-configure the router.
- Check the firmware version of the device whether it is latest one.
Posted on Oct 28, 2007
Can't access D-link DI-614+ as admin
Direct from the D-Link FAQ's
This reset procedure applies to the following devices:
DI-704  DI-704P  DI-713  DI-713P  DI-714P+  DI-804HV  DI-808HV
  • Step 1 Power the unit off by unplugging its power adapter.
  • Step 2 Insert a paper clip in to the reset pinhole. Press and hold the reset button with light pressure.
  • Step 3 Power the device back on by plugging it in. Continue to hold the reset button.
  • Step 4 Watch the lights on the front of the gateway. The M1 & M2 should come on solid. When the M1 & M2 begin to blink slowly, release the reset button.
The unit will reboot itself and should be at factory defaults. If the M1 light is not blinking about once per second, recycle the power on the gateway.
If the M1 & M2 continue to blink rapidly, you held the reset button for too long. Power the device off and repeat the reset procedure. The default IP address is 192.168.0.1. The default username for our routers is admin. The password is blank. If your router asks only for a password, use admin (lower-case).
The following reset procedure will completely restore the default settings on your D-Link device including your password. This procedure applies to the DI-514, DI-524, DI-604, DI-614+, DI-624, DI-754, DI-764, DI-774, DI-784, DI-804V, DWL-700AP, DWL-800AP+, DWL-900AP+, DWL-1000AP+, DWL-2000AP, DWL-2100AP, DWL-6000AP, DWL-7000AP, and DWL-7100AP.
  • Step 1 Locate the reset pinhole on the back of the unit.
  • Step 2 With the unit powered on, press and hold the Reset button.
  • Step 3 Hold the Reset button for about 10 seconds.
  • Step 4 Release the Reset button.
  • Step 5 The unit will reboot. Allow 20-30 seconds before reconnecting.
  • Step 6 The device is now at factory defaults.
Note: Do not recycle power during the reset procedure.
The default user name for most D-Link devices is admin and the password is left blank.
When it says hold for about 10 seconds, don't hold for more than ten seconds or the procedure will likely fail, if ten seconds doesn't work try 5 seconds.
P.S.: If this information was helpful, please rate this solution.
Mar 12, 2009 | D-Link AirPlus DI-614+ Wireless Router
Dim Power LED on DI-707P
there is apossible hardware issue within the unit itself, the chipset may have been damaged through age, surge or impact.
aside from the hardware issue, it can be a firmware issue too, and an upgrade will be the best move to solve the problem.
please contact D-Link support to perform further troubleshooting and to check on the warranty status of the device as it is showing signs of being deffective.
http://support.dlink.com
phone: 1.877.45D-LINK (1.877.453.5465)
hope this helps
Aug 20, 2008 | D-Link DI-707P Router (DSDLDI707P)
DI 514 Wireless Router Problem
Okvassiw - Don't rate this til it's fixed please. Can I assume you reset the configuration on your router from defaults to your settings? First , unplug your modem and your router. Leave unplugged for a minute. Then plug in the modem. After 30 seconds plug in the router. Give it 15 seconds and try it. Let me know what happens and I'll tell you how to proceed. Thanks.
Jeff
May 15, 2008 | Computers & Internet
DI-Link model DI-704
I have the same problem... my connection after an hour will slow down but after i turn off and on the router again, my connection will back to normal again... Can u please help... thanks.
Dec 09, 2007 | D-Link DI-704P Router
Factory setting
Step 1 Power the unit off by unplugging its power adapter. Step 2 Insert a paper clip in to the reset pinhole. Press and hold the reset button with light pressure. Step 3 Power the device back on by plugging it in. Continue to hold the reset button. Step 4 Watch the lights on the front of the router. The M1 & M2 should come on solid. When the M1 & M2 begin to blink slowly, release the reset button. The unit will reboot itself and should be at factory defaults. If the M1 light is not blinking about once per second, unplug the power on the router and plug it back in. If the M1 & M2 continue to blink rapidly, you held the reset button for too long. Power the device off and repeat the reset procedure. The default IP address is 192.168.0.1. The default username for our routers is admin. The password is blank. If your router asks only for a password, use admin (lower-case).
Feb 16, 2006 | D-Link DI-704P Router
Factory settings
Feb 16, 2006 | D-Link DI-804HV - 4-Port Broadband VPN...
Factory settings
Feb 16, 2006 | D-Link Express EtherNetwork DI-804HV...
Scheduled Firewall
Unfortunately not. Active connections must be stopped before the rules take effect. For Example: If you have an active FTP download when the schedule takes effect, the session will not be terminated until the download is complete. Once the schedule is effective and the FTP download has completed, you will not be allowed to initiate another FTP connection until the scheduling permits.
Feb 16, 2006 | D-Link DI 707P (DI-707P) Router
Configure to print
You may print without the D-Link Printer software in Windows 2000/XP. Here´s how: Step 1 Go to Start>Settings>Printers>Add New Printer (WinXP - Start>Printers and Faxes>Add a Printer). Step 2 Select Local Printer. Make sure to uncheck Automatically detect and install my plug and play printer. Click Next. Step 3 Select Create a New Port and select Standard TCP/IP port. Click Next. Step 4 Enter the IP address of the router (192.168.0.1). Leave the port name with the default name. Click Next. Step 5 You will get a message saying that additional port information required. Step 6 Select Custom and then click Settings. Step 7 Set Protocol to LPR. Step 8 For the LPR Settings, queue name is lp. It is case sensitive! (LP lower-case). In most cases, check LPR Byte Counting Enabled. If you cannot print, then try unchecking this. Step 9 Select OK > Finish. Step 10 Continue with the Add Printer Wizard. Choose your printer from the list or click Have Disk and point to your printer driver disk.
D-Link DI-707P Router (DSDLDI707P) Logo
145 people viewed this question
Top D-Link Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a D-Link Computer and Internet Expert? Answer questions, earn points and help others
