Question about AT&T 2256 Cordless Phone
Warning check battery - AT&T 2256 Cordless Phone
I have a 2008 Accent, The battery warning kept coming on while driving and replaced a new battery but warning popped up again.but the warning showed again ?
The battery light comes on when the charging system is not operating correctly also .
so check the alternator and wiring from it for defects could also be a slipping drive belt for the alternator
Jan 25, 2017 | Refrigerators
Red battery appears on my dash board?
Polimar, Posted links to tell and show you why battery warning light may be on. Check the attached links,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
Ford Battery Warning Light What it means Checking It
How to Test an Alternator
How to Test Car Battery with Multimeter
Jul 04, 2016 | 2006 Ford Escape Limited
I have a '99 dodge grand caravan se, while in park the abs light came on, the battery light came on, and the check engine light has been on,
Looks like you have a few issues there.
1. The battery warning. This is indicative of a weak battery and if your battery is 3 years old or more I would replace it.
2. If you have a weak battery this can trigger other warning lights in the vehicle, typically the ABS warning but sometimes other warning lights as well depending on the electronic features in the car. If you replace the battery this should correct the battery warning and most likely the ABS warning if both of these warnings appeared at the same time.
Normally, once the ABS warning is displayed the anti lock braking system(ABS) will be shut down. Whilst your braking will be normal, if you brake too hard and lock up your wheels on a slippery road there is no ABS assist to prevent the brake lock up which you have when the system is working.
3. If the alternator on the engine is not generating sufficient power and thus not charging the battery at all, or very little, you will likely get a battery warning light. I don't know if your 1999 vehicle has a warning light to indicate a faulty alternator or not.
4. Check Engine Light.
You suggested the CE warning has been showing up for a few days and before the battery and ABS warnings popped up.
The CE warning can be caused by dozens of different engine issues.
The vehicle needs to be scanned with the appropriate scan tool to see what fault codes the onboard computer is generating because if you have a CE warning light there will be fault codes generated 99% of the time.
Once these fault codes have been pulled the mechanic can start to diagnose the cause of the problem or problems. Each engine fault code your car's computer is generating can be caused by different types of problems so it is important that they diagnose the issues correctly. Otherwise your Check Engine light will remain on as long as the causes are not identified and fixed.
Dec 29, 2015 | Dodge Cars & Trucks
I have a 2008 Sebring the battery is dead since the battery has been playing up the engine management light has been on could this be because of the battery ??
Yes, the check engine light will turn on for just about all things detected wrong through the computer of your car.
Dec 03, 2015 | Cars & Trucks
Battery warning light
When the warning light is on, the alternator is not charging the battery.
So you should have the alternator output checked when the light is on.
Mar 06, 2014 | 2005 GMC Canyon
Battery and brake light on
For some reason the brake warning light and battery light are connected, so either system could be having problems.
The battery warning light could mean the battery is not being charged, and the brake warning light could mean you are low on brake fluid.
I would start with the check engine light and see what the codes are.
Jun 26, 2012 | 1990 Toyota Corolla
2003 Cavalier. Battery warning light came on
Check for bad connection to the battery. Use a volt meter to check voltage from alternator to the battery, should be 14.5 volts to 15 volts. If you have anything less than that then look for a bad alternator wire from alternator to battery. Also check for a good ground connection to the battery. Do all the testing with everything off inside the car so you will not have a power drain from the system. hope this will help you.
May 12, 2010 | Cars & Trucks
check the wire from the battery to the starter to see if it has good connection. otherwise check your ground to block.
Mar 20, 2010 | Chevrolet Cavalier Cars & Trucks
2 of my 4 vtech handsets keep giving me a 'check battery warning'
Try to reset the handset from handset menu, maybe the eeprom setting for low battery warning threshold have been ereased . Also check ,if the battery is the oregional battery for the phone.
Jan 21, 2009 | Vtech Lands Phones
AT&T 2256 Cordless Phone Logo
18 people viewed this question
Top AT&T Lands Phones Experts
Paul C.
Are you an AT&T Lands Phone Expert? Answer questions, earn points and help others
