Question about Datamax I-4308 Thermal Label Printer
Datamax default password - Datamax I-4308 Thermal Label Printer
Zpl emulation with datamax i-4208
You can't, on this obsolete model. zpl is "Zebra Printer Language." This model of Datamax is dpl only ("Datamax Printer Language"). Most current models of Datamax printers are dpl and zpl compatible.
Able Label Systems Thermal Printers
Feb 01, 2013 | Datamax I-4208 Thermal Label Printer
Datamax I-4208 has different position than i-4308 or prodigy max
On the I-4208s, press Menu button on front of printer. Go to Print Control. Go to Custom Adjustments. Go to Row Adjust. Change Row setting as needed. Ok to go negative.
Feb 17, 2012 | Datamax I-4208 Thermal Label Printer
I need to know the user id and default password for a datamax barcode printer, could you help? Thank you.
You can try "sysadm" for the password using the user id blank. If you have a model number I might be able to get a better answer for you.
May 04, 2011 | Computers & Internet
Do you know the part number to order the ribbon or film?
After doing a little research, I can see why you are having a hard time figuring out the correct part number to replace the ribbon.
Here's what I found as a compatible ribbon on the CDW website:
http://www.cdw.com/shop/products/default.aspx?edc=2066585&RecommendedFOREDC=320985&RecoType=AP&cm_sp=Product-_-ComplAcc-_-Datamax+Pioneer+GPR+Plus+-+print+ribbon
The Datamax website has a chart with Media and Ribbon Requirements for I-Class models on page 111 of the following online PDF:
http://www.datamaxprintingsolutions.com/corp/88224101_p.pdf
Hope this helps. You may also wish to get purchasing help from the sales agents at a company like CDW or Tiger Direct (CDW's number is (800) 800-4239
Steve G.
Jan 20, 2011 | Datamax DMX-I-4212 Label Printer
Hi! I have a problem with my office Datamax E class printer. When i change tickets in the printer it doesn't print them the right size - normally they are too short. Do you have any idea how to solve...
If you are changing length(feed length) you may have to recalibrate the printer . Also ensure that your print format is the correct length for the stock.
You can look at the setup of the printer using the datamax-oneil printer configutation program, or if it is using IP connection, you can go directly to the internal web page for set up. make the cal length 3 times the label length, or leave at the default value.
Dec 29, 2010 | Datamax E-Class E-4203 Thermal Label...
We can not use our print DATAMAX DMX M CLASS
What type of stock are you using? Gapped, continuous, or reflective mark?
If you are using a standard gapped stock, and the stock is loaded in the printer and ready, press the feed button until 3-6 labels are passed beneath the media sensor.
If you are using reflective (eyemarked stock) go in the the media settings. Change the sensor type to reflective.
Make sure that the eyemark is presented to the sensot at the small white strip on the sensor. Do not move the sensor to a place where the sensor will see anything but the mark.
Dec 31, 2009 | Datamax I-4308 Thermal Label Printer
My datamax prodigy plus wont print out a word doucment
You need to download the Windows Drivers from Datamax Website, you can then use the printer with all Windows based applications
Apr 13, 2008 | Datamax Prodigy Plus Thermal Printer
Datamax I-4308 Thermal Label Printer Logo
Top Datamax Office Equipment & Supplies Experts
pkwc
Greg Cann
Greg Cann
Kevin Brown
Level 1 Expert
Are you a Datamax Office Equipment and Supply Expert? Answer questions, earn points and help others
