Astroplasma 250 No arc present, good air flow and unit comes on ok.
4 Suggested Answers
  • 23 Answers
SOURCE: unstable arc..Millermatic 250. arc not steady
Your windings inside are aluminum, they may have loosened up where the positive lead hooks on to the transformer inside.
I had a miller and the wire melted there, you can re-loop the wire and re-fasten it if it melted short enough if this is infact the the problem when you take the cover off..
Posted on Dec 25, 2009
bazzz7071
  • 338 Answers
SOURCE: 2001 yamaha ttr 250, starts, idles ok, bogs at acceleration
Has the bike been stored for any long length of time?
old fuel in the carburetor will turn to a varnish like residue blocking the jets,or possibly water in the carburetor.
Posted on May 03, 2010
Testimonial: "The bike was not stored and was ridden regularly, but it still sounds like it could be the carburetor. Thanks for your insight."
  • 74 Answers
SOURCE: Not very good air flow. Filters clean evap clean.
head is a bit high air temp ok for a retun air temp of 68-63 wrong fan speed ?
Posted on Jun 17, 2010
225Bobcat gen.runs but will not excite when trying to strike arc
#Tags bobcat 250 welder service manual
coop.bounceme.net/term/bobcat-250-welder-service-manual
Why does my miller bobcat welder generator not stay at an idle when swithed to low idle, insted it goes back and ... Won't strike an arc,fuses ok brushes and slip.
Aug 11, 2015 | Electrical Supplies
Pentair mastertemp 250 NA. heater will not fire, no error codes. starts fine, gas flows, igniter heating but still will not fire. It has a new valve, gas pressure entering valve from new regulator is 8.35...
All appearances - No fuel to ignite!
evrything else looks good, proper gas pressure, proper volts at igniter, etc - it should ignite! If fuel present, heater should Fire!
make sure all valves are open.
Gas valve is ON
AND purge any air from gas line.
IMPORTANT ****. If you bled gas line, don't try to ignite for a few minutes. Allow gas to dissipate first, use a fan to help.
Mar 05, 2015 | Pentair Mastertemp 250 Natural Gas Pool...
Not blowing cold air tough there is an airflow, how can I repair it?
if no air come from indoor unit then indoor fan motor problem and if air come but not cool then check it gas from out door unit if gas present then change its compressor capacitor it will be ok
Jul 25, 2012 | LG LS-K2430HL Heat Cool Mini Split Air...
Installed new 250 unit today, getting error code IF, Gas is on, gas valve in front panel is open, unit grounded, gas feed line necked down to 3/4 npt at shut-off valve, tried to increase gas pressure 1...
Did you bleed the gas line of air? In a nw installation it is not uncommon to sit there 20-30 seconds with the gas line union open and the shutoff open to get all the air out and a good flow of gas present. If that doesn't work post a comment with what else happens.
John
May 29, 2011 | Hayward 250fdn Low Nox Nat Gas Swimming...
My tig welder wont arc unless I touch the metal with it
my guess would be the type of welding machine you have.usually there is extra switch which says start control also continious cycle , sometimes smaller machines dont have these switches to allow a wider variety of tweeking the welder ,also its ok if you have to touch the base metal cause thats what starts the contact with the work peice ,keep a arc after touching about 1/4 inch away from work peice ,also a good steady hand rest will make a good welder in any situation this should allow the arc to remaim stable with a comntinious weld arc puddle. happy welding
May 22, 2010 | Miller SYNCROWAVE 250 DX TIG RUNNER WELDER...
May 03, 2010 | 2002 Yamaha TT-R 250
Put new in line fuel filter, but will not fill filter up with gravity flow. needs air to get the fuel flowing. is there a special filter to use on this?
The Lincoln Gxt 250 is supposed to have an electric fuel pump. Check to ensure the fuel pump is working correctly. Most of the inline filters I deal with dont fill up. There is always a good size amount of air present in them even during operation. I know it doesn't make sense, but they do work.
Jan 13, 2010 | Lincoln Electric Ranger Gxt 250 Amp...
Thermal dynamics cutmaster 50 2004 yr.
Check contacts in tip and be sure it is all lubed correctly. If you have good air pressure and flow it should arc after pulling the trigger for about 2-3 seconds.
Sep 27, 2008 | Welding Tools
Computers & Internet Logo
29 people viewed this question
David Payne
David Payne
