Question about Dryers
Newly purchased part 3977393 stops working in1 min after install...has happened 2x
Two kits have failed after installed....heating element was also purchase new from Sears Kennesaw Store ...have purch two part 279816 kits ...but only the 3977393 part continues to fail
  • 1019 Answers
SOURCE: Audio Driver issues
if you have the installation disk with this, the sound drivers should be on there.
ensure that your using the on-board sound card, if using a stand-alone card ( Seperate Card ) PCI/AGP. that you have the individual driver cd disk, for the actual card itself.
also check the motherboards user manual. sometimes a jumper-block connector, has to be setup on the main-board. to allow onboard-sound enable/disable.
Finally, check in device manager, to see if theres any yellow exclamation marks, by your sound card icons.
if so try, add/remove or re-install drivers for this device.
Mike @ Compurepair.
Posted on Jul 02, 2008
aclamonte
  • 81 Answers
SOURCE: HP C4180 printer - alignment failed
hi there,
  • try to update your printer drivers or
  • delete the printer icon and all unnecessary printers icon in printers and faxes windows at start menu and then click add printer at printer task and then on screen wizard in adding a printer
  • next select if it is local or direct connect to your pc or network
  • if network browse the printer and then double click the work group you belong and the printer your going to connect and click next and a confirmation appear click yes.
  • if local click use the following in drop down menu see where you attach if it is in USB then select USB. click next in install printer software at left is the brand at the right is the model. if your printer is not on the list then select to near model of your printer and then follow on screen instruction after installation, print test to check if your printer now working.
Posted on Nov 29, 2008
barkencoa
  • 3463 Answers
SOURCE: have a hotpoint tdc30p dryer that will not heat
Check to see if the new parts fitted are o/k,
If they are, then your problem is probably a faulty control unit or possibly bad connection in the wiring.
If the new parts are faulty, then something else is causing them to fail.
Make sure all filters are clean and that all air vents are clear
Posted on Dec 12, 2008
kachbibi1
  • 979 Answers
SOURCE: my dryer, whirlpool #wed5840swo stopped heating.
Does the drum turn? I know you have checked the breaker which can trip sometimes. There may be a small disc about the size of 7-8 stacked nickels that is actually a reset that is planted along in one of the lines. You can bypass it to see if it is the problem. If it is, then you can get a replacement at an appliance store. Make sure all your wiring is correct because you could be spending a lot of money for nothing. Was your old element actually bad(burned in 2)? This main thing I would want to know is if the drum turns or not. The other, probably not, problem could be in the control panel. If you are handy with an ohm meter, you can see if those parts are indeed O.K. You can call em at 803 463 5567 for clarification.
Posted on Jan 14, 2009
  • 10865 Answers
SOURCE: New Warmrails Towel Warmer Stopped heating
call the company directly at 877-927-6724. Explain the problem and they will assist you or replace your unit.
Posted on Feb 19, 2009
Thermal cutoff switch fails 2x in a year. Heating coil ohms out ok.
Whirlpool Thin Twin, dryer thermal cutoff failed twice - Appliance ...
forum.appliancepartspros.com > Appliance Repair Help > Dryer Repair
Oct 12, 2011 - 6 posts - ‎2 authors
Friends Whirlpool Thin Twin came with purchase of condo half a year ago. A month ago it stopped heating. I checked continuity and found the ... Whirlpool Dryer Thermal Cutoff
Jan 9, 2013
Thermal cutoff blew again (Whrpl Elect Dryer)
1 post
Jan 5, 2013
More results from forum.appliancepartspros.com
Why does the thermal fuse keep blowing in my dryer ...
www.shopyourway.com > Manage My Life > Questions
Dec 28, 2015 | Dryers
Dryer gets warm but not hot
I will assume you have the thermostat set on high and checked the dryer vent to make sure it is not clogged with Lint, Mouse Nests, or GI Joes. (I have seen all of these.) There are two common broken bits that can cause this.
First, and most likely, is the heating element. Most electric dryers have two strings of heating elements that run next to each other. If one of them fails then the dryer will get warm, but not really hot. Depending on your dryer you either have to pull the back of the dryer off or pull the drum to inspect the heating element. When it's cool and unplugged it should be very obvious if it's broken. The heating elements look like springs, and one part will be brown and broken, probably near a ceramic insulator. If you are not sure, you can measure the resistance of each string with a multimeter. For a TEMPORARY repair, you can stretch the existing element's broken ends and put it back together. I stress that this is a temporary repair only because it will cause hot spot in the element and could be a fire risk. (Full Disclosure: My Mom has a dryer with this temporary repair that has worked since 1998. I'll get to it eventually.) If this is it, you can get a fully assembled heating element for $$, or you can save a lot by purchasing a restring kit instead. With the restring kit, you keep all of the metal bits and replace only the heating element wire and brackets. There are very good videos on youtube about how to install these properly. The key point is to pre-stretch the element before installing.
It is possible to bypass all the door closed and belt present to run the disassembled dryer for a few seconds to see if both elements get hot and turn red. This is patently unsafe, and you'll probably die from burns, electrocution, or entanglement with the electric motor. YMMV. Emphasis on "seconds" here, as the elements will burn out pretty quickly without airflow.
The other thing this could be is a thermostat. I don't know of any way to test these other than by replacement. They are fairly inexpensive compared to a fully assembled heating element.
Good Luck.
Feb 19, 2014 | LG Dryers
Water in bottom of dish washer. power to washer, but nothing. no lights on controls, nothing. will not do anything
According to the information you gave, your model had an issue with the thermo fuse inside the control panel inside the door. This can blow for only one reason, the wires carried heat back to it. In the replacement kit link below, you will find a line break, this line break will prevent this from happening again. Fail to install this kit completely will end up doing it again.
Fuse Kit
Please install completely, you can purchase this from any part house or from the link I sent you.
Good Luck.
I’m happy to help further over the phone at https://www.6ya.com/expert/gere_bf68e6055dd61249
Aug 17, 2011 | KitchenAid 24 in. KUDI01ILBS Stainless...
While pre heating oven, heard a sort of explosion. The bake element was definitely broken. A new one was purchased, installed, but it does not heat up. The broiler also does not work, but stove top does....
i have seen elements short out and cause the main board to fail. if eeverything else works you know you have proper power , so i would say the board is bad
May 12, 2011 | Microwave Ovens
The dryer will not heat. Think the heating element is bad. Where is it located on the dryer?
it is located at the back of the drum inside an oval housing. if the element coil is not broken, you may need the thermal cut off kit which is part #3977393, it contains 2 thermostats. the element part #is 3403585. hope this helps.
Nov 07, 2009 | Whirlpool LER4634J Electric Dryer
I am replacing the thermostat on my Roper dryer. Model number of dryer is RES7745RQ0. I went to a local parts supplier and I received the ''Thermal Cutoff kit'' with the part number 279769. The spade...
it may be 279816. it can also depend on what thermal fuse you are trying to replace.part # 3977393 includes both the fuses that go on the
heating element can
Sep 26, 2009 | Dryers
My waffle maker will not hear up
Same issue with my mom's iron. Installed new $1 240C thermal fuse and it's working again.
Aug 29, 2009 | Waring WMK300 Professional Belgian Waffle...
Have a hotpoint tdc30p dryer that will not heat
Dec 12, 2008 | Hotpoint TDC32 Electric Dryer
Dryers Logo
32 people viewed this question
Top Dryers Experts
