Question about Acer Aspire AM3470-UR12 Mini-Tower Desktop 2.2 GHz AMD A6-3620, 4 GB DDR3, 500 GB HDD, DVDAAAARW, AMD Radeon HD 6530D, Windows 8
Long beep when power button is pushed
When power button is pushed there is a long beep and computer doesnt turn on.
2 Suggested Answers
  • 713 Answers
SOURCE: When you push the power
keep pushing f2 f2 f2 f2 when screen pops up push f2 change boot formate to f12 you can use arrow keys on key board ok now you will see boot dialog change it to f12 push f10 to save changes restart computer then push f12 then run windows under d:drive
Posted on Feb 18, 2011
Why won't t3500 power on?
Most likely cause is the power supply, if it really wont turn on, if it comes on but doesnt start, the you have a computer problem. Check and see if the fans work when you push the power button or if any lites come on, then the power supply is most likely OK. If the computor does actually come on, but does not start, see how may beeps it makes. then repost your question with that info.
May 05, 2014 | Dell Precision Workstation 490 - MT -...
My tab totally off....
Please describe more , you say when you press the volume button down then push power button to turn off screen, then you turn on again , and it doesnt work , what doesnt the phone or the function
Apr 22, 2014 | Samsung Galaxy Tab 2 7.0
Dell Inspiron 530 beeps 6 times when turned on and doesnt start. The fan runs during this process untill the beeps. Tried unplugging everything and then just the monitor and tower, same result.
you have to reseat the memory
Reseat means you have to remove the memory while the computer is unplug from the system
1. Unplug the power cable from the system
2. Press the Power button for about 5-10 secs to drain any electro static discharge
3. Locate the memory bay
Theres 2 white clips in each side
you have to press the 2 white clips on each side to remove it
if you 2 memory you have to remove both of them then put it back the way it was removed and push it towards the slot like you see in the picture.
you must heat that it clicks , thats the indicator that its properly seated.
please be careful and do not put too much pressure when pushing/pressing it down.
Hope that helps
Feb 23, 2011 | Dell Inspiron 530 Desktop Computer
Not sure witch jazzy chair i got but the joy stick blink and keeps blinking i have tried pushing horn button twice and also turning it on and pushing joy stick forward waiting for it to beep but no beep....
LOCKING/UNLOCKING THE VSI
The VSI has a feature that enables you to lock your power chair to prevent
unauthorized use.
To lock the VSI:
1. With the VSI powered on, press and hold the on/off key. After one (1)
second, the VSI should beep.
2. Release the on/off key.
3. Push the joystick to the full forward position until the VSI beeps.
4. Pull the joystick to the full rearward position until the VSI beeps.
5. Release the joystick. There should be a long beep.
6. The VSI is now locked.
To unlock the VSI:
1. Press the on/off key and power on the VSI. The maximum speed/profile
indicator should ripple side to side.
Good Luck
mimobility
Feb 17, 2011 | Pride Jazzy 1103 Ultra Standard Power...
I turn on my ps3 and the green light comes on for a short time and the it beeps three times shuts off and the green light turns red and starts to flash. If I push the power button again the red light stops...
this happens when the ps3 has overheated-try removing the hard drive and replacing then give the console a hoover out.....if this doesnt work try holding the power button on for 5 sec....if this doesnt work its back to sony im affraid
Mar 16, 2010 | Sony Playstation 3 (PS3) Console
I cant get my ps3 to reset. I was using it on a HDTV and I swicthed it back to a regular tv using AV cables and it will not show pic. just sound. Everybody says to reset it by pushing the button on the...
Try using a different Tv.
"First beep it turns on second beep nothing and third beep turns off.will not reset."
Your friends are wrong, pressing the button at the front of the console only turns the console on and off. If the problem doesnt change then contact the sony customer helpline.
Jul 29, 2009 | Sony Video Game Consoles & Games
All over sudden my boston horizon doesnt allowe increase the vol.
To fix: turn on unit, turn volume all the way down to 00, push and hold volume button for 10 seconds until beep then release, then turn volume all the way up to 50 (max) and push and release volume button.
May 17, 2009 | Boston Acoustics Duo-i Horizon Clock Radio
Getting power but wont boot up or anything
pull out everything in the computer except what's required to boot...so any pci cards or video cards (if you have onboard video). you can also try pulling out the ram (while unpowered AND unplugged) and then booting to hear beeps...if you pull the ram out and the computer doesnt make a sound, its probably a bad motherboard and needs to be replaced. if you hear beeps, try replacing the ram or disconnecting other parts...like harddrives, optical drives, modems and what not.
Apr 26, 2009 | E-Machines T2792 PC Desktop
Dryer will not start
There is a start relay on the computer control board. You probably hear a very dull click. That click is the relay on the computer board trying to engage, but it won't and therefore your dryer won't spin and your board sends a beep and perhaps an "E11" error code to the LED display (Not sure on Kenmores.).
In plain english, you have a bad control board now and will have to replace it. Cost about $130.
Dec 15, 2008 | Kenmore Elite HE4 Electric Dryer
Wont turn on
My only suggestion as last desperation, take your dvd player out of the vehicle. Open your hood, Take the yellow, red, and orange wire, tie them together and hook it to the positive post, and black to the negative. If your dvd player comes on like it should, Then it prolly a problem in your cars computer. Some newer cars automatially disable their radios when an alarm goes off, for theft reasons.
Jan 16, 2008 | Jensen VM9410 Car DVD Player
Acer Aspire AM3470-UR12 Mini-Tower Desktop 2.2 GHz AMD A6-3620, 4 GB DDR3, 500 GB HDD, DVDAAAARW, AMD Radeon HD 6530D, Windows 8 Logo
15 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
Steve Sweetleaf
Steve Sweetleaf
