Question about Bosch Nexxt 100 Series WFMC1001UC Front Load Washer
How do I replace the belt on a Bosch Nexxt 100 Series Washing Machine?
How do I tighten the belt, possibly tightening the belt would suffice?
  • 228 Answers
SOURCE: Hello! My Bosch Nexxt series 300 washing machine
e 13 is a door lock error if you are lucky you may have a manual release check where filter is for a red pull release this mechanically activates the door to retrieve trapped washing,if not lock will need replacing engineer visit unfortunately.
Posted on Aug 05, 2009
barkencoa
  • 3463 Answers
SOURCE: can't fit a belt to the Bosch washing machine. Is
There is no provision made for adjusting belt.
With the rear panel removed, fit the belt round the motor pulley first, and slowly feed it round the drum pulley, at the same time turning the pulley by hand..
Watch your fingers, it will be tight.
You will find it easier to do if you lean the washer away from you, this will give you more room to get your hands in..
Hope this helps you.
Posted on Dec 03, 2009
barkencoa
  • 3463 Answers
SOURCE: bosch 100 series will not drain
You need to check and clean the pump filter if you have not already done so.
This is located at the bottom front right of washer.
Unscrew anti-clockwise to remove and clean.
Posted on Mar 15, 2010
  • 1075 Answers
SOURCE: Bosch Nexxt 100 series washer stops at 1st spin cycle
take a look at your manual that came with your machine go to problems usually at the back and see what that says,or go to the bosch website and type in your model number its on the inside of the door.i would suspect a program fault.adrian,,,,,
Posted on Jun 29, 2010
mechanicsonl
  • 431 Answers
SOURCE: How I can clean fliter for washer machine bosch nexxt 100 series
just unscrew the filter plug located usually front bottom of machine.
Posted on Dec 21, 2011
Why does Bosch Nexxt washing machine act like it is unplugged, even when connected to power?
Either no power at outlet or electronic control module faulty
check power at point with say a hair dryer
if ok electronic control will need replace
Aug 05, 2014 | Bosch Nexxt 100 Series WFMC1001UC Front...
How to replace a drain motor on a bosch nexxt 100 series washer
Maybe you just need to change the motor brushes. YouTube has some great videos. Spares here on Fixya. Did you check out your filter?
Click if helped.
Mar 18, 2013 | Bosch Nexxt 100 Series WFMC1001UC Front...
Bosch Nexxt 100 Series WFMC1001UC Front Load Washer wont spin belt is on pump is free of debris
Possible that the main motor is jammed or does not get power from the program controller unit. It is important that you measure the voltage at the motor when the program is set to start after the inlet valve fills water. If there is no voltage then the program controller unit is faulty.
Click this link for support : washing machine tips
Jun 25, 2012 | Bosch Nexxt 100 Series WFMC1001UC Front...
Dec 13, 2011 | Bosch Nexxt 100 Series WFMC1001UC Front...
We have a Bosch Washing Machine nexxt 100 series wfmc1001uc, the water lines froze without us realizing, we started to washer while lines were frozen... in the end, we had to replace the hot water inlet as...
Bosch Washing Machine nexxt 100 This video will show you how to change the pump washing machine
Please remember to subscribe to our YouTube channel for all appliance tutorials
a 4 THUMBS rating is appreciated for answering your FREE question.
And don't forget to like us on facebook
Feb 05, 2011 | Bosch Nexxt 100 Series WFMC1001UC Front...
I have a bosch nexxt 300 series washing machine. The problem is it had beeped code E04 the hoses were somewhat dirty and i cleaned those,but now the pump doesnt seem to be running and its getting hot. ...
bosch nexxt 300 series washing machine This video will show you how to change the pump washing machine
Dec 31, 2010 | Bosch Nexxt 100 Series WFMC1001UC Front...
Jun 28, 2010 | Bosch Nexxt 100 Series WFMC1001UC Front...
The drum on my bosch wfmc1001uc won't spin but it does drain.
draining has nothing to do with spinning.
open the back of your machine and you can see the mechanical parts of your washing machine
try to turn it ON , just keep a distance enough for you to see,
1. check the belt if it is attached and aligned (if loose, tighten it a little bit)
2. check if the motor is running ( if not, check the capacitor-small aluminum tube with wires) if busted replace it.
3. check if there is any hamming sound from the motor, if make a humming sound but does'nt rotate, take it out and bring it to machine shop to replace the bearing or bushing
Nov 09, 2009 | Bosch Nexxt 100 Series WFMC1001UC Front...
Bosch Nexxt 100 Series washer
Look into your manual, clean outlet filter & refit. Machine will not spin out if filter is clogged.
Dec 21, 2007 | Washing Machines
Bosch Nexxt 100 Series WFMC1001UC Front Load Washer Logo
Top Bosch Washing Machines Experts
Tim Whalen
Dan Webster
Dan Webster
Are you a Bosch Washing Machine Expert? Answer questions, earn points and help others
