Question about Garden
Craftsman 30 in. snow thrower,model no. 247.883960
30in.snow thrower,model no. 247.883960,contenusly pulls to the right.have to keep pulling the left trigger to keep straight.is there an adjustment?
    Sergeant:
  • 416 Answers
Check the pin that hold s the wheel on
I think its the right side that has two holes
be sure the pin is in the rim and axle
Posted on Feb 02, 2015
3 Suggested Answers
pleasant_bil
  • 76 Answers
SOURCE: I have a craftsman weed wacker model 316.79197 It will cut off when i pull the trigger to give gas. what should i check ?
Be sure the exhaust port is not clogged. Be sure the choke lever is in the run position. Also you might try letting it warm up half choked before you "pull the trigger"
Posted on Apr 04, 2012
  • 451 Answers
SOURCE: Craftmans Snow Thrower 247887001 Tire Flat. How to Refill.
The tires are probably tubeless type. If the bead is broken ( not sealed to the rim) the tire will not inflate. Taking the weight off the tire will some times allow the bead to seal against the rim and allow tire to be inflated. You can also put a small ratchet strap around the tread of the tire and tighten it up. This will squash the tire and make the bead seal up. MAKE SURE to loosen strap as soon as bead seals and tire begins to inflate. Hope this helps.
Posted on Jan 01, 2014
Can I use 0w 20 Mobil 1 oil in my snow blower
It can be used, although the manufacturer recommends;
Super S 5W-30 Snow Thrower Engine Oil - Sears
www.sears.com/explorer-5w...snow-thrower...oil/p-07188298000P
Sears Rating: 4.5 - ‎5 votes
Oct 21, 2010 - Explorer 5W-30 snow thrower engine oil is a premium formulation for use in all four cycle engines when temperatures are below 32 deg. F. Explorer 5W-30 snow thrower engine oil protects the engine by lubrication, cooling, cleaning and sealing internal moving parts.
Aug 23, 2015 | Craftsman Snow Blower / Snowblower Bottom...
Service manual for craftsman 24" snow thrower
the only thing holding in the auger is the block bearings on each side (three bolts in each side) the center drive is hex splined and should come right out ,unless its bent as well.
if you call 1800sears parts with model and serial number they can get you a new auger assmebly mailed right to your door
Feb 24, 2015 | Garden
Manual for sears snow thrower 536.886621
They are basic what do you need to Find in the Manual?
Feb 12, 2014 | Craftsman Sears Snow Thrower Manual Model...
30 in craftsman snow thrower,model no.247.883960,pulls right contionusly while operating in any gear
Howdie ther is a Pin in the shaft of the wheels look to see if it is Broken and away ya go it is easy to see
Feb 07, 2014 | Craftsman Arnold Mtd Snow Thrower Blower...
30 in. craftsman snow thrower,model no. 247.883960,pulls to the right
If your blower uses the two wheels to drive which I think it does I would suggest that you have a shear pin on the right side that is broken. If that is the case you will have to pull the wheel off and replace the shear pin. You can tell if it's broken by lifting the right side and trying to turn the wheel by hand.If it turns easily its broken.
This is an idea only. You might want to check both wheels as I'm not sure as far as the steering is concerned.
Feb 07, 2014 | Craftsman 30 In 357cc* Dual-Stage...
Replace friction wheel in a snowthrower
it looks to me the only special tool needed would be
spring ring pliers.
just removing nuts or blots on the left side and spring clips on both slide axle out pull wheel over bearing then reverse put together
Feb 03, 2014 | Garden
I just bought a Sears snow thrower, I put in oil and gas went to start it but the pull cord will not pull up. I then tried the electric starter but it just made a grinding sound. Why won t it start?
Check the crankcase and make sure it has oil. It sounds like the engine is frozen. If its brand new, take it back to Sears and have them start it for you.
Dec 16, 2013 | Craftsman Arnold Mtd Snow Thrower Blower...
Where is the throttle on a craftsman 536.881800 snow thrower?
Manual is available at http://www.searspartsdirect.com/partsdirect/part-model/Craftsman-Parts/Snow-removal-equipment-Parts/user-manuals/manual-downloads/Model-536881800/0247/1507200?modelNumber=536881800&diagramPageId=&documentId=
Dec 14, 2013 | Craftsman Sears Snow Thrower Manual Model...
Can't get snow thrower to start
Does it have spark ??? I would check that first, and IF it does maybe add a tablespoon of gas down the sparkplug hole then try it..
Dec 30, 2008 | Craftsman 4 Cycle Blower/Vac
Garden Logo
63 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
john h
