Question about Uniden Cordless Phone
No display on base unit bt xd8500 - Uniden Cordless Phone
BT Freelance XD8500 - one handset has totally "died". Anything I can do to restore?
just change the battery for new one and you will have miracle...
if memory serve correctly there is two "aaa" batteries in the unit, look how polarity goes!
to test - just insert standard "aaa" batteries and see if unit is resurrected, if so buy re-chargeable batteries, insert and enjoy! check an dswap charger (base) unit, rotate handsets between bases as well, base maybe not charding correctly, check pins on the bottom of the base.
if these do not work - buy new unit, it is not really worth repairing...
hope this will help you solve the problem - do not forget to vote...
Feb 12, 2015 | BT Lands Phones
BT 4500 cant answer messages from base only phone help please
Master unit has On/Off answer button. Select option you require.
The extension units do not have a message facility.
Nov 12, 2014 | BT 4500 Cordless Phone - DECT - Satin...
Although my bt baby monitor 150 units are fully charged and within range they still will not link up. They have worked perfectly until yesterday. I have tried doing a factory reset & taking the...
I had the same problem, have just spoken to BT (helpline is 0808 1006554) and they advised this is how you re-link the base and parent unit.
1. Switch both units off
2. On the base unit press volume up (+) while turning on the unit. The word "registration" should appear on the display.
3. Then on the parent unit, press the power on and then as soon as all the lights come on, take your finger off the power button and press the volume up (^). The word "registration" should appear on the display and then the units should link.
It's a bit of a fiddle getting the parent unit to re-register and they both need to say "registration" at the same time, but we got it after several attempts, and now they are working fine.
Apr 16, 2011 | Toys
Base unit on bt synergy 3505 keeps beeping and handset keeps displaying base 1 and losing signal.... intermitent fault....have changed batteries in handset and switched unit on and off but still not...
If the handset displays 'Searching', 'Base' or 'Range out' on the screen, this indicates that the handset has lost its link with the base. The following procedure should be followed to help resolve the problem:
  • Confirm that the power lead has not been inadvertently disconnected from the base.
  • Ensure that the handset batteries are correctly installed and are fully charged.
  • Ensure that the handset and base are within range of each other.
  • Switch the mains power off, wait five seconds and then turn it on again. This will reset your product.
  • Carry out a reset procedure on both the handset and the base to return the settings back to the factory default. Your user guide will guide you through the correct procedure.
  • If none of the above remedies solve your problem, please contact the helpdesk.
Jul 20, 2009 | British Telecom Synergy 2110 Cordless...
BT XD5500 manual
BT Freelance XD 5500
Resetting the base & handset/s on a BT Freelance XD5500:
Hold the Find button on the base unit until you get a double beep then
tap the Find button 7 times.
On the handset:
remove a battery
hold the menu key and refit the battery
screen says SW VERSION
press up arrow key until screen shows REGISTER CLEAR
press menu
press menu again and wait for OK to appear
remove a battery and refit
Registering the XD5500 handset.
Then register the handset to the base as follows:
Hold Find button on base unit until you get two beeps
On handset:
Press menu
Scroll to register
Press menu
Scroll to Register Base
Press menu
Press 1
Wait
When it says PIN ? Enter 0 0 0 0 (four zeros) and press menu.
Note:
If you have more than one handset then repeat registering the handset to the base for each subsequent handset/phone.
If this procedure fails to solve the issue, then you have a unit with a
fault and if it is less than a year since purchase the retailer should
change it for you.
Aug 03, 2008 | Lands Phones
Both phones are flashing base 1 with no ring tone on a bt studio 1500
Hi
Had the same problem with my BT Studio 1500 phones both flashing "BASE 1" . Again could not find solution on web! BUT phoned the free BT helpline on 08001456789.
They told me to switch off electricity supply to the base unit then switch it back on.
(The fault is due to the base unit losing the signal and just needs to be "rebooted")
Hey IT WORKS!!!!!
Don't buy a new set of phones!!!!!
Groucho
Jul 14, 2008 | Lands Phones
BT Studio 3100 handset 1. Display flashing base 1, cannot go to setup menu, not changed pin code, turned off and on, removed batteries, turned off base unit, waited 20-30secs for all of above and still...
Help
My Bt Studio 3100 cordless telephone ( 2 Pack ). I have carried out the setting up procedures as per instructions.
Handset batteries are fully charged, but I am not getting the dialling tone.
Jul 11, 2008 | Lands Phones
Uniden Cordless Phone Logo
179 people viewed this question
Top Uniden Lands Phones Experts
Are you an Uniden Lands Phone Expert? Answer questions, earn points and help others
