Question about Artensoft Photo Mosaic Wizard
Artensoft Photo Mosaic Wizard 1.6 SERIAL - Artensoft Photo Mosaic Wizard
Good day i have a wizard big remote but no serial no. or so.im looking for the codes of it can u please assist me?
To which device do you want set-up codes to this remote control. Provide more details please. If you wish to get more, check the site linked here. http://electrohelponline.blogspot.com/ Pull up previous posts there, either by its left side bar, or view it in Mosaic / Timeslide option. Good luck.
Jul 16, 2013 | Televison & Video
Problem loading photo explosion delux version 3 disc 1
You can right-click on the program's setup.exe, select properties, then compatibility and set it to windows XP
then try to install it again
Dec 15, 2007 | Nova Development Photo Explosion Deluxe...
What is a mosaic?
A mosaic is a picture that's made out of lots of small pieces of glass or stone. all the pieces are different colours and are combined to make one large colourful picture.
Jan 10, 2013 | Crafts & Hobbies
Serial number for hemera photo objects
if you purchased genuine software, you will have the serial number. i suspect you have a pirate copy. contact company to get serial.
Jul 14, 2012 | Hemera Computers & Internet
Please find my authorization code for photoshop cs3 .... serial number 1330-1860-4356-5280-6440-7193
You can get the authorization code over the telephone or via the Internet. You will need this authorization code and the serial number to activate your Photoshop software.
Instructions
  1. How to Activate Photoshop CS3
    • 1 Insert the disc(s) into your computer and follow the onscreen directions of the Installation wizard. When prompted, input your serial number. You will then be given the option to activate the software via the telephone or over the Internet
    • 2 Activate by phone by calling the activation line on 866-772-3623. Give the representative the activation number that appears on your Activation screen, and the serial number.
    • 3 Activate via the Internet by clicking the "Activate Now" in the Activation wizard. When the "Activation Successful" message appears, click the next button to activate the software.
Tips & Warnings
  • If you have problems activating the software, contact Adobe Live Chat via the Adobe website. You can also call technical support at 800-833-668. Make sure you have your serial number on hand.
Jun 11, 2012 | Adobe Computers & Internet
I can't find the serial number in magic photo editor.
Welcome to FixYa! Since we are talking about Serial Numbers for Magic Photo Editor, this will depend on what Magic Photo series or version you are using. I suggest go to Google.com then just type "can't find the serial number in magic photo editor". In there you will find links that will provide you serial numbers that will assist you in your Magic Photo Editor. Hope this helps. Thank you for using FixYa!
Jul 04, 2011 | Computers & Internet
I need a diagnostic tool for RAID falure code 0. Initial boot indicates degraded condition. DISK scan does not seem to remedy the issue. Did the drive actuually fail? Is there a fix? Primary disk still...
It looks like you have two arrays here. The first one being a mirrored RAID array and has only one disk. This means that the other disk has failed in some sort. This does not mean that the drive is bad, just the RAID failed for some reason. You will need to rebuild the RAID if you want to maintain the same level of redundancy.
You can just attempt a rebuild the RAID to the same drives but if this fails you will want to replace the bad drive. In order to do this you will need to make sure you can tell which drive is which. You do not want to mirror the bad drive to the good one.
If attempting a rebuild to the existing drive does not work or is not an option (because the failed drive could really be bad), you will need to determine which physical drive needs to be replaced. You may be able to hot-swap the drive but if you can power things down, that is always safest. Once the new drive is installed, you can rebuild to it and all should be well after that.
Jan 04, 2011 | Dell Dimension 9100 PC Desktop
Polaroid P310 Photo Printer: i need drivers for...
http://www.driverwizard.org/wizard/w?ms.driversfor.wizard
May 18, 2010 | Lexmark Polaroid P310 Photo Printer
The s/n that i have on my disc wont work when i try to use it in the setup wizard so i can put my pics in my pc
ivitar Entries
May 29, 2008 | Vivitar Cameras
Adobe photoshop 7
yes 1 choose the filter mosiac from the filter menu. 2 choose any options form your window 3 choose "ok" in your special filters you will find the following Pixelate: Color Halftone, Crystallise, Facet, Fragment, Mezzotint, Mosaic,Pointillize. of course you will choose Mosiac. you may want to down sample your photo to 300 dpi then adjust your brightness and contrast to your desired likeness. You can also change the grayscale doing this.
Sep 14, 2007 | Adobe Photoshop CS2 for PC
Computers & Internet Logo
104 people viewed this question
Top Artensoft Computers & Internet Experts
David Payne
David Payne
Are you an Artensoft Computer and Internet Expert? Answer questions, earn points and help others
